    Rename all scenes
    6 Posts 2 Posters 619 Views 2 Watching
      jorge2011
      Hello everyone.
      I have a question.
      There is some plugin to rename all the scenes together?
      For example sometimes I think some scenes and adding cutscenes then I have something like:
      Scene 01 - Scene 10 - Scene 03 - Scene 08
      and if I have 50 scenes all mix between if you wanted to rename them all together, this is not possible
      • TIGT Online
        I think there's a tool available at Smustard.com... BUT it does cost $0 [so probably worth the cost !]
        see here http://www.smustard.com/script/SceneRename
        Perhaps that Todd for giving it to you... πŸ˜‰
          jorge2011
          oo, Great Mr. TIG.
          Thank you very much
          but, is strange.
          plugin does not appear in the menu.
          For what reason?
          • TIGT Online
            Read the notes at the start of the .rb [open it with Notepad].
            It appears in the View menu.
            BUT I have downloaded and tried the file and I confirm it loads 'true' BUT never makes the menu item or the class to make .new()!
            I copied the code and pasted it into a new file and it shrunk a little in size AND then works OK - I must assume that the file has somehow acquired hidden characters that are messing it up - I have told Todd...
            Here's a fixed version - please try it and confirm yours is now OK too...scene_rename.rb
              jorge2011
              exelente your Fast response. thank you very much.
              • TIGT Online
                This version doesn't have the annoying message telling you it's loaded - I added it temporarily to prove to myself I wasn't going mad when it wouldn't work before because of the 'hidden characters' - forgot to remove it 😳 ...scene_rename.rb
