    Rename all scenes
    6 Posts 2 Posters 424 Views 2 Watching
      jorge2011
      Hello everyone.
      I have a question.
      There is some plugin to rename all the scenes together?
      For example sometimes I think some scenes and adding cutscenes then I have something like:
      Scene 01 - Scene 10 - Scene 03 - Scene 08
      and if I have 50 scenes all mix between if you wanted to rename them all together, this is not possible
        I think there's a tool available at Smustard.com... BUT it does cost $0 [so probably worth the cost !]
        see here http://www.smustard.com/script/SceneRename
        Perhaps that Todd for giving it to you... πŸ˜‰
          jorge2011
          oo, Great Mr. TIG.
          Thank you very much
          but, is strange.
          plugin does not appear in the menu.
          For what reason?
            Read the notes at the start of the .rb [open it with Notepad].
            It appears in the View menu.
            BUT I have downloaded and tried the file and I confirm it loads 'true' BUT never makes the menu item or the class to make .new()!
            I copied the code and pasted it into a new file and it shrunk a little in size AND then works OK - I must assume that the file has somehow acquired hidden characters that are messing it up - I have told Todd...
            Here's a fixed version - please try it and confirm yours is now OK too...scene_rename.rb
              jorge2011
              exelente your Fast response. thank you very much.
                This version doesn't have the annoying message telling you it's loaded - I added it temporarily to prove to myself I wasn't going mad when it wouldn't work before because of the 'hidden characters' - forgot to remove it 😳 ...scene_rename.rb
