    LightUp v2.1e
    extensions
    36 Posts 10 Posters 3.4k Views 10 Watching
      😞 nope
        AdamB
        OK, interesting. Thomthom it used to work for you, right?
        Does the standalone (code-signed) LightUp Player work on your PC?
        LightUp for SketchUp
        Sketchup realtime lighting plugin
        LightUp for SketchUp (www.light-up.co.uk)
        Adam
          I've had problems on my office computer - as I reported in the thread about the web-viewer.
          It works fine in IE9 - on the same machine.
          What's odd is that I got the loading screen initially - now I don't.
            How is it supposed to look btw? "Falling Water"? Anything animated? I don't see anything water-ish except for a light blue surface.
              Same on IE9 for me?
                driven
                hi Adam,
                works on Safari 5.0.6 on 10.5.8 and in a WebDialog inside SU (which is nice;)
                the F1 key for scenes dosen't work? is that deliberate, using R to restart animation dose the same thing [I guess].
                it would be handy to have the nav guide on the page if it can't be toggeled
                W,A,S,D work for nav, L works for lighting and P for post
                I did discovered you can crash Safari and or System if you open the standalone player [to check the keys] at the same time as the WebPlayer.
                there's also a bit of flotsam in the demo...
                debris
                  @adamb said:
                  You can embed a weblink in the watermark. So it will open up another webpage (with potentially a different model etc).
                  I know - what I meant is that clickable objects inside the player (and of course, dynamic components would be some extra cream on top so we couold open/close doors for instance)
                  πŸ˜„
                    Now that would be fantastic.
                    • E Offline
                      EarthMover
                      Are there any exterior night lighting examples made with LightUP? I'm particularly interested in doing night lighting animations and wasn't sure if LightUp is capable of processing a dusk type scene with exterior lighting. If so, I would purchase the program for that alone, as currently no other "realtime" animating solutions can do this.
                      Content Creator at Skapeup
                      • E Offline
                        Ecuadorian
                        At the risk of stating the obvious... "Falling Water" is the name of the house.
                        http://www.fallingwater.org/
                        A cool CG animation of the house made by a Spanish guy:
                        http://www.youtube.com/watch?v=9CVKU3ErrGM
                        -Miguel Lescano
                            AdamB
                            LightUp supports IES lights, simple point lights, sunlight (doh) all of which are fully filtered by any transparency materials (think stain glass windows etc)
                            As to dusk, that would be down to choosing a suitable Panorama / Skybox and using it for Image-based lighting (IBL) + your IES lights.
                            And you can then export for LightUp Player and/or a webpage for others to navigate.
                            Adam
                              AdamB
                              πŸ˜„
                              Dynamic Components have been supported in LightUp since the beginning: (http://www.youtube.com/watch?v=u97RAAxScaA)
                              [BTW Ignore the framerate on the video - LightUp runs at 30Hz - the video capture got borked somehow]
                              Its a completely arbitrary choice that I left that code out of the Player - but something I could certainly add in if there is interest.
                              Adam
                                AdamB
                                @driven said:
                                hi Adam,
                                [attachment=0:11cbgjba]<!-- ia0 -->lightup_fragments.png<!-- ia0 -->[/attachment:11cbgjba]
                                Well LightUp Player is a standalone Application with a little menu etc.
                                LightUp WebPlayer is a browser plugin with the expectation you'll add some HTML / text around it as part of your webpage. Seemed like re-inventing the wheel to add text rendering..
                                re: Flotsam. Nice catch. I'll push out a fix today.
                                Adam
                                  AdamB
                                  @adamb said:
                                  @driven said:
                                  hi Adam,
                                  [attachment=0:34jvvy28]<!-- ia0 -->lightup_fragments.png<!-- ia0 -->[/attachment:34jvvy28]
                                  Adam
                                  Now fixed (only effected Mac).
                                  1. Delete /Library/Internet-Plugins/LightUp WebPlayer.plugin
                                  2. Visit http://light-up.co.uk/resources/webplayer/playertest.html to get later version (v2.4.6)
                                  Adam
                                    driven
                                    my comment was just for your web page, if someone has never used the standalone they wouldn't know how to navigate Falling Water, or the others...
                                    while on the topic of Your html text... the plugin doesn't 'self' instal, but the screen text implies simply restarting Safari will make it work... it's easy enough to figure out , but a lot of people wouldn't bother and assume it's crap.
                                    Yes, we have no flotsam, however it crashed safari when I switched tabs to reply here??
                                      Well, finally, after some experimentation with LUp, I started to apply things and play around with a bigger project of mine.
                                      I appreciate, Adam, that you come here all the time to support all the lazy but I know you have your own forum, too.
                                      Should I ask here or should I go there (I've been a member and occasional lurker there for quite long actually)?
                                      My first question would be: is it possible to add unicode support to the Player? Unless I only use English characters, my scene names get messed up.
                                        bravoddb
                                        How long takes to make a file to be played?
                                        what uses cpu or gpu?
                                        thanks
                                          AdamB
                                          Ah yes, good idea. Thanks.
                                          I'll amend the text for the Safari "Download plugin". If you have the crash.log, can you email it to lightup. Thanks.
                                            AdamB
                                            Fonts are one of those 'interesting' technologies that you hardly give a second thought to, however, handling Unicode in general is a really huge amount of work. So much so that video games teams will have an engineer who may be fulltime solely supporting fonts.
                                            The more you look into it, the more complex you find it is. I'll certainly have a think about how I could leverage Windows / OSX font support rather than having to build my own.
                                            Thanks.
                                            • 2 / 2
