    Problems with exporting in 3ds max (.3ds)
    10 Posts 3 Posters 607 Views 3 Watching
      disoa
      Hi everyone,
      i have some problems with exporting file in Max 2011 (.3ds),
      terrible geometry after exporting, some one know what it's can be. Show you my exporting preference.
      P.S. The same problem with .skp format.
        Well, I rarely use the 3ds exporter but try without standalone edges.
          disoa
          actualy, this option is turned off, i accidentally turn it on on screen shot.
            disoa
            What is it 3ds exporter ? some kind of plugin ?
              And what do you mean by "same problem in skp"? Is the geometry messed up there, too?
              (The native exporters are not plugins as far as I know...)
                disoa
                Yes(((
                  Well, if you modelled it in a way that it is messed up, an export will not help.
                  Did you model it at all? Is it an import? Can you share the file (upload as an attachment below the post where you are typing)
                    disoa
                    Yes, i modelled it by myself and with model in sketchup everything ok (i think so).
                    I attach rar archive with my model. Sorry for my english )
                    arch.rar
                      Diosa
                      Had you used Model Info > Statistics > Purge Unused the model would have been ~1Mb instead of ~5Mb and you could have attached it without compressing it as a .rar file...
                      The modeling looks OK - apart from stand-alone edges your export-settings also seem OK...
                      Do you set the units in options to be the same [mm] for export AND import ?
                      This is what I get - looks OK to me [the triangulation is required by 3ds format] Capture.PNG
                        disoa
                        I haven't know about the"Purge Unused" function until you showed me.
                        Yes, measure units are the same in the 3D MAX and SU (mm).
                        However, it is a bit strange that the model looks fine when reproduced through my PC with SU
