    [REQ] VRML importer
    13 Posts 6 Posters 9.0k Views 6 Watching
    • dereiD Offline
      derei
      @tig said:
      As you can already covert wrl to dae [e.g. with Blender]
      I was looking for an automated process, because the VRML files are coming from a specialized engineering software that is not capable to make presentations. And there are many files and things must go fast. On the other hand, one more software used to convert this file will make the workflow slower. Now we use Cinema4D to convert wrl to dae. At first, C4D was used to make renderings, but it't time consuming to make the materials. So, I suggested Sketchup + Twilight. You must agree that TW has the fastest material editor πŸ’š But I would like to get rid of third software, as I am using it only for conversion.
      A quick-fix for textures was to duplicate the Textures folder from the original computer, on that one where the import is made. So, same location is present on both. Still, if there is a new texture, somebody must be sure that both directories are updated. This is why I was hoping to a automated texture search, trough network (in a specified directory).
      • Dan RathbunD Offline
        Dan Rathbun
        Sketchup 8 Pro can export VRML, can it import as well ??
        I'm not here much anymore.
        • dereiD Offline
          derei
          No, it can't. That is why for now I'm stuck with wrl -> dae.
            Dan Rathbun
            Other threads on this topic:
            SketchUcation:
            • import VRML (.wrl)
              Google Groups:
            How can I import VRML files into Google Sketchup??
            • import VRML (.wrl) [old archive group]
            An old post on VRML export from Sketchup:
            • [www-vrml] What is a good workflow for sketchup?
            I checked SYCODE, but they do not have a VRML import plugin. (Perhaps you could ask them to create one? .. volunteer to be a beta tester for such a plugin.)
              bjornkn
              As this sounds like a job with a budget, why not use a dedicated converter like PolyTrans?
              It will take your files directly to skp.
              For synchronizing folders between computers Dropbox may be a solution?
                The VRML file format 'wrl' code IS quite readable and it would be possible to make a parser to read it in and then use it in creating new faces, materials or instances etc - somewhat like my olde OBJimporter.rb [that works slowly and with some flakiness]...
                However, it would really be a major undertaking... So if you are serious about doing this as a project then it's unlikely to be 'free' - so PM me with your budget and I'll let you know if I think that I [or someone else] could be reasonably expected to produce such a juggernaut within a reasonable timescale... πŸ€“
                • dereiD Offline
                  derei
                  Thanks TIG, I will discuss the matter and if it will be considered as an option, I will PM you. πŸ‘
                    bjornkn
                    In case you didn't know - behind the .wrl format there are two different VRML standards, VRML (VRML95) and VRML2(VRML97). Many programs can write both, but only read VRML, so I suppose the VRML2 is quite different, and more difficult to parse.
                    Maybe you should check what version you're getting?
                      Dan Rathbun
                      Yup, SYCODE sells commercial import/export plugins.
                      I suggested volunteering as a beta tester because they are often rewarded with a free license of the released version.
                        Jim
                        In addition, I thought X3D was the successor to VRML?
                          daamayzn
                          Go to:
                          http://www.ctrlview.com/file_upload.php
                          -navigate to your file location & upload your *.wrl file
                          ON NEXT SCREEN
                          -specify which *.wrl file (vrml or vrml 2)
                          -choose your specifics (true color, rotation, view mode, view type)
                          -in the "convert to format" drop down menu, select your preferred output format (I choose dxf, skp output wasn't valid output format at this time) in conversion
                          -press the "view/convert" button
                          -select the link "Click here to get converted file" (in blue), it will begin your converted file download
