    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.2m Views 329 Watching
      @islevegan said:
      Greetings,
      I use Sketchup 8.0.4811 on linux via Wine. It is stable and works well.
      I put the .rb and related folder in the plug-ins folder and got an error upon starting Sketchup.
      Fyi; Just wanted you to know.
      If you keep the error message your secret we can't help you... πŸ˜’
      How about I guess ?
      The error said something about 'progressbar.rb' ?
      Get it free from Smustard.com, put the file into Plugins and retry...
      If my guess is wrong tell us the error and we can try to help you... πŸ˜•
      • I Offline
        islevegan
        Apologies. Yes, you are exactly right. I haven't used SketchUp much and not at all in 2+ years. I missed the detail you mentioned.
        Now SketchUp starts without error and I see Shape Bender in the Plug-ins listing. Again, I apologize for this and thank you for your gracious response.
        Aloha
        @tig said:
        @islevegan said:
        Greetings,
        How about I guess ?
          πŸ‘
          • U Offline
            unclex
            [Plugin] ExtrudeTools - Zipped Set 20110525 Installed
            Shape Can't work...
            Need Help !!!
            ThanX
              Unclex, that's a completely different plugin.
              Did you also install Shape bender? And what about progresbar.rb. Any error messages in the ruby console?
                Shape Can't work...
                Need Help !!!
                ThanX
                Are there error messages?
                Either at startup or in the Ruby Console when it's run.
                If so please post them here.
                As Gaieus said... do you have progressbar.rb installed in your Plugins folder [free to download from Smustard.com] ? It's need by this tool to work properly.
                I know of no recent changes to the EEby... tools that might cause a clash.
                I have both tools working fine on my PC with all previous and current versions...
                Please give us as much information as you can to help us help you - your present message is particularly unhelpful...
                • U Offline
                  unclex
                  Sorry , Shape can't work with [VirtualWind]This One,
                  not ExtrudeTools
                  Can U fix this?
                  ThanX
                    vwSketchupExtensions.rb Replace this file in the 'Virtualwind' subfolder... it previously made a missing method - group.definition - BUT it had a basic error in its code - returning the 'group' rather than its actual 'definition', which would break any other tools that also define and use it, in anything but the most simple way - like 'ShapeBender' does !!
                    It's very bad to overwrite built-in class methods and risky to make new ones, without checking they preexist in your code, especially if there's a basic mistake in yours πŸ˜’
                    The rewritten form ensures that if there's an earlier made method it stands...
                    It should not change the way 'Virtualwind' itself works, but now allows other scripts to work too...
                    I don't have 'Virtualwind' so I had never come across it before πŸ˜•
                      Jim
                      Hmm, how do we handle this type of issue in a way that is easy to search for and find?
                        driven
                        hi TIG,
                        I stopped using VW but, from memory it also has a clash with progressbar.rb this won't help that will it?
                          The 'classic' is group.definition so it's easily found and then fixed with my 'trap code'...
                          Otherwise I use Baregrep to search for text like class Sketchup:: etc in all my .rb and .rb.txt files in Plugins and/or subfolders to see if there are new or modified built-in class methods etc.
                          Other greps could be for class Geom::, class Array:: etc depending on the possible type of error...
                          Unfortunately compiled .rbs are impossible to grep - you can only 'find them' by the half/half/half method of moving Plugins out of the Plugins folder... They can then be disabled but not 'fixed'... πŸ˜’
                            Jim
                            Sorry, I meant how to make it easy to find on the forum...
                              @driven said:
                              hi TIG,
                              No it wouldn't...
                              The vwProgressBar.rb file in the 'Virtualwind' subfolder redefines the ProgressBar class that might be otherwise been loaded earlier from the original progressbar.rb script.
                              The versions of all of the 'Virtualwind' files in the attached zip now make/use a new class vwProgressBar so it's separated from the original ProgressBar class !
                              This zip has all of the fixes in it !Virtualwind.zip
                                We can't find them without downloading, testing, grepping etc...
                                • U Offline
                                  unclex
                                  Get it!
                                  U r So Nice~~~~~~~
                                  ThanX
                                  ThanX
                                  THanX
                                  • U Offline
                                    unclex
                                    @unclex said:
                                    Get it!
                                    U r So Nice~~~~~~~
                                    ThanX
                                    ThanX
                                    THanX
                                    2nd Botton @ the virtualwind toolbar , can't work , means it can't not export vws files.
                                    VirtualWind is a software for flow calculating such as wind, modeling by using SU ,then export to VW.
                                    Even have no VW soft, the plugins for SU can working for export.
                                    so....
                                    need help.....
                                      driven
                                      unclex,
                                      you should probably search the VirtualWind thread, as people who downloaded and it might still get notified if you ask there.
                                      I only ever used the plugin and I know VW development was stopped.
                                      good luck
                                      • U Offline
                                        unclex
                                        @driven said:
                                        unclex,
                                        good luck
                                        Yes, VW has been Shut Down.
                                        But Somebody said, it could be purchased by a big company.
                                        and VW is a good flow software.....
                                        Thanx for help, Sorry for help
                                        • bobpineoB Offline
                                          bobpineo
                                          Hello Chris,
                                          Bob Pineo here, architect from Charlottesville, Va. We met at 3d basecamp in Bolder.
                                          How are you?
                                          any new plugins lately? Love your work.
                                          I'm dabbling with the idea of learning how to write ruby scripts.
                                          Can you recommend a book I might start with?
                                          thanks
                                          BP
                                          Bob Pineo, Design Develop LLC http://www.designdevelop.org.
                                          • Chris FullmerC Offline
                                            Hey Bob, good to see you on the forum here. How are you doing? Nothing new really at the moment. I've got a few that I've started on and never really completed, but they are nothing that asmazing really.
                                            Most people recommend a book called "the pickaxe", I think because it has a pickaxe on the cover:
                                            http://pragprog.com/titles/ruby/programming-ruby
                                            But it is actually called "Programming Ruby (2nd edition): The Pragmatic Programmers' Guide" and you can get it online for free:
                                            Programming Ruby: The Pragmatic Programmer's Guide
                                            (www.ruby-doc.org)
                                            But the online version does make references to page numbers which are lost in the online version. But the online version is searchable, making it inredibly valuable.
                                            Also, my favorite tutorial for learning ruby is by Chris Pine. The tutorial chapters are on the left of the webpage, chapters 0 - 11:
                                            http://pine.fm/LearnToProgram/
                                            That one was really nice for a quick intro into ruby. Then beyond that, I've put together a few different tutorials on beginning interfacing SketchUp through ruby - which to me was more confusing that it needed to be. Its really pretty simple once you get the hang of it. I'll have to see if I can find links to my tutorials. They wre posted on this website at one point, but I think they've gone offline 😞
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 63
                                            • 64
                                            • 38 / 64
