    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.1k Views 175 Watching
    • U Offline
      unclex
      [Plugin] ExtrudeTools - Zipped Set 20110525 Installed
      [Plugin] Shape Bender Beta v0.55 Can't work...
      Need Help !!!
      ThanX
      • H Offline
        hebeijianke
        @tig said:
        I translate All the plugins in ExtrudeTools into chinese
        This is the translation file
        chinesetranslation.zip
          Need Help !!!
          ThanX
          I [and many others] have both toolsets installed without any interconnected problems πŸ˜•
          Can you explain the nature of the problem a bit more ?
          Are there any error messages [either at startup or when it's run with the Ruby Console open]? if so please post them here, or perhaps more logically in the ShapeBender thread, as that's the broken tool.
          Nothing has changed between recent versions of the EEby... tools that I could think might affect ShapeBender in any way. that tool itself has been around for some time...
          Please check you have progressbar.rb installed in the Plugins folder [available free from Smustard.com] - this is a frequent cause of tools failing that need it [it's not needed for any of the EEby... tools though!]
          πŸ˜•
            I'll include them with the next update of the toolset.
            Meanwhile Chinese locale users can install them into the TIGtools folder and feedback...
              Jim
              Hi TIG,
              Shouldn't there be a Toolbar? I don't see it. I have all the EEb Tools in the Plugins menu, but no Extrusion* in Toolbars.
                There should be a file in ../Plugins/ #extrusionToolbar.rb makes the Toolbar/Sub-Menu.
                It starts with a '#' so it loads first - it then checks to see if any of the possible EEby...rb files exist and if so it adds the 'Extrusion Tools' toolbar referenced as ' $extrusionToolbar' and an 'Extrusion Tools' submenu referenced as ' $extrusionToolsSubmenu'. As each of the EEby...rb files loads it checks for these $ references and if they don't exist then there is no toolbar/button and the tool's menu item is added direct to Plugins-menu rather than into a subfolder...
                Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
                Note that the EEby... tools also 'require' deBabelizer.rb ?
                  Jim
                  Ah, I renamed it without the #. Guess I can't do that.
                    NO! It needs to load before the other tools so they find the toolbar/submenu ready-made...
                    The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created...
                    Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings...
                    πŸ˜’
                      Jim
                      And I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
                      Thanks.
                        Jim
                        I made these mods to make it portable:
                        starting @ ~ line 50
                            eePlugins.each{|plugin|
                        	path = File.join(File.dirname(__FILE__), plugin+".rb")
                        	#if Sketchup.find_support_file(plugin+".rb","Plugins/")
                        	if File.exists?(path)
                        	    gotPlugin=true
                        	    break
                        	end#if
                          Here's an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                          The tool now makes the Extrusion Tools toolbar/submenu even if the various .rb files are not located in the standard ../Plugins/ folder and are loaded from elsewhere [it now uses File.dirname(__FILE__) rather than the .find_support_file() which is limited to a standard set of folders]. It just requires that all of the files [including those in the ../TIGtools/ submenu] are kept in the same relative locations rather than the previous absolute ../Plugins/ location...
                          It also includes the latest Chinese lingvo files, thanks to 'hebeijianke'...
                            > 	    gotPlugin=true
                            > 	    break
                            > 	end#if
                            I had just made very similar changes - you posted as I uploaded it - see updated set... πŸ˜’
                              Jim
                              Frequent updates are another advantage of using a shared Plugins folder! πŸ˜†
                              Thanks again.
                                I think I'm done for a while on updating this tool... πŸ˜’
                                • U Offline
                                  unclex
                                  Sorry , my mistake
                                  the reason is another Plugins
                                  Thanx for ur replied
                                    manson666
                                    I'm new Sketchup user
                                    now learning it
                                    I founded out sketchup plug in is strong tool
                                    thx share
                                    • O Offline
                                      openhatch
                                      If I haven't said this before, awesome tools, thx. πŸ‘
                                      This doesn't play well with SketchyPhysics; this newest version won't extrude edges by rails successfully if SketchyPhysics is installed. So I keep the two installed in different versions of Sketchup. 😞
                                        I know about the SketchyPhysics issue - it can also affect other tools... http://forums.sketchucation.com/viewtopic.php?p=300111#p300111
                                        The fix is relatively simple BUT it means recoding a few lines in one of the SketchyPhysics rubies...
                                        http://forums.sketchucation.com/viewtopic.php?p=300105#p300105
                                          Destors
                                          How i need to make these things, help me please πŸ˜„
                                          http://pix.playground.ru/download/gallery/664241/e8dc3ff2a2429a9a221028809dbf41d6.jpg
                                          http://pix.playground.ru/download/gallery/664241/f57318be4e038aa96c6285ff3df68a19.jpg
                                          • O Offline
                                            openhatch
                                            Okay, I knew you knew; I guess I might have clarified I was wondering if it's an outstanding problem (I hadn't read those posts you link to here). But the fix you link to will do (assuming it works, as I haven't tried it yet), thanks!
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 31
                                            • 32
                                            • 18 / 32
