    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 769.1k Views 175 Watching
      prismcnd
      just wanted to say thank you for your amazing efforts.
      β€œWhatever the mind of man can conceive and believe, it can achieve.” -W.Clement Stone (American best selling Author and Founder of Combined Insurance Co (now a part of Aon Corp.), 1902-2002)
        costa
        you are really great!!! fantastic work, thank you
          Here's an updated set http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
          A new tool ' ExtrudeEdgesByOffset' has been added.
          Its details are found here http://forums.sketchucation.com/viewtopic.php?p=331303#p331303
            d12dozr
            Wow, TIG, a tool a day? πŸ˜„ Thank you for these!
            http://goo.gl/f7ooYh
              The 'Extrude Edges By Vector To Object' tool has been improved considerably:-
              A new algorithm has been added for the intersecting with objects: now walls extend to soffits with additional apex vertices and so on so it extrudes fully to the faces/edges.
              'Ghost' extrusions now show intersections as red dots.
              The original selection is kept, unless the is group exploded.
              Some ES lingvos updated by Defisto [thanks].
                Here's another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                The 'Extrude Edges By Vector To Object' tool has additional traps added for rare glitches when a faced edge-selection was used.
                  Here's yet another update http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
                  The 'Extrude Edges By Vector To Object' tool has had a glitch fixed with 'undo' if you'd reversed faces etc...
                    The 'Extrude Edges By Vector To Object' tool has had glitches fixed with 'commit' and extruding faces inside groups to objects outside...
                    • W Offline
                      Wildchild
                      DUUUDE! Exactly what I was talking about!
                      Here's a few tests:
                      et1.jpget2.jpget3.jpget4.jpgThis last one took a little bit to work it out but then it did it just fine
                      I have a couple more tiny requests to ask, but now i don't have time! πŸ˜†
                      Eternity is very long, especially towards the end. Woody Allen
                      • U Offline
                        unclex
                        [Plugin] ExtrudeTools - Zipped Set 20110525 Installed
                        [Plugin] Shape Bender Beta v0.55 Can't work...
                        Need Help !!!
                        ThanX
                        • H Offline
                          hebeijianke
                          @tig said:
                          I translate All the plugins in ExtrudeTools into chinese
                          This is the translation file
                          chinesetranslation.zip
                            Need Help !!!
                            ThanX
                            I [and many others] have both toolsets installed without any interconnected problems πŸ˜•
                            Can you explain the nature of the problem a bit more ?
                            Are there any error messages [either at startup or when it's run with the Ruby Console open]? if so please post them here, or perhaps more logically in the ShapeBender thread, as that's the broken tool.
                            Nothing has changed between recent versions of the EEby... tools that I could think might affect ShapeBender in any way. that tool itself has been around for some time...
                            Please check you have progressbar.rb installed in the Plugins folder [available free from Smustard.com] - this is a frequent cause of tools failing that need it [it's not needed for any of the EEby... tools though!]
                            πŸ˜•
                              I'll include them with the next update of the toolset.
                              Meanwhile Chinese locale users can install them into the TIGtools folder and feedback...
                                Jim
                                Hi TIG,
                                Shouldn't there be a Toolbar? I don't see it. I have all the EEb Tools in the Plugins menu, but no Extrusion* in Toolbars.
                                  There should be a file in ../Plugins/ #extrusionToolbar.rb makes the Toolbar/Sub-Menu.
                                  It starts with a '#' so it loads first - it then checks to see if any of the possible EEby...rb files exist and if so it adds the 'Extrusion Tools' toolbar referenced as ' $extrusionToolbar' and an 'Extrusion Tools' submenu referenced as ' $extrusionToolsSubmenu'. As each of the EEby...rb files loads it checks for these $ references and if they don't exist then there is no toolbar/button and the tool's menu item is added direct to Plugins-menu rather than into a subfolder...
                                  Your screen-shot suggests that #extrusionToolbar.rb is missing as there's no 'Extrusion Tools' submenu ??
                                  Note that the EEby... tools also 'require' deBabelizer.rb ?
                                    Jim
                                    Ah, I renamed it without the #. Guess I can't do that.
                                      NO! It needs to load before the other tools so they find the toolbar/submenu ready-made...
                                      The existence of the EEby...rb tools are checked by it 'by name' so renaming all of those would also stop the toolbar/submenu getting created...
                                      Its filename doesn't have to start with a #, it just needs to list somewhere before the other tools in alphanumeric order... I use a leading # on the name of for my tools if I want it to load early - like the '#HolePunchTool.rb', as I want its items high up on the context-menu listings...
                                      πŸ˜’
                                        Jim
                                        And I use C:\Plugins rather than the default so I can share plugins between versions. EEbX isn't portable in that way either.
                                        Thanks.
                                          Jim
                                          I made these mods to make it portable:
                                          starting @ ~ line 50
                                              eePlugins.each{|plugin|
                                          	path = File.join(File.dirname(__FILE__), plugin+".rb")
                                          	#if Sketchup.find_support_file(plugin+".rb","Plugins/")
                                          	if File.exists?(path)
                                          	    gotPlugin=true
                                          	    break
                                          	end#if
                                            The tool now makes the Extrusion Tools toolbar/submenu even if the various .rb files are not located in the standard ../Plugins/ folder and are loaded from elsewhere [it now uses File.dirname(__FILE__) rather than the .find_support_file() which is limited to a standard set of folders]. It just requires that all of the files [including those in the ../TIGtools/ submenu] are kept in the same relative locations rather than the previous absolute ../Plugins/ location...
                                            It also includes the latest Chinese lingvo files, thanks to 'hebeijianke'...
                                            • 11
                                            • 12
                                            • 31
                                            • 32
                                            • 10 / 32
