Would you like to sit down? EDITED
thank you for consideration.
You can see what happen if you laterally load a rib with force 500N on the picture 5 and 6 (Obr_05 and Obr_06).
cheers
Intersting concept - your FEA is also interesting but I suspect that you have missed the point of the comments that have been made. I don't think that the strength of the elements themselves is in question. The issue is very definitely with the fixing. Think about how you can use a claw hammer to lever out nails that are otherwise very strong - something similar to that effect could be a problem for your design.
I don't know how those stress programs works, but it looks like everybody else here thinks that the construction will not work very well without any lateral/sideways support.
Like on this little image.
Here's an example of a similar concept, the Scandia chair.
As you can see - lots of lateral support.
thank you for comments.
it was a question. solved.
this is why i made FEA.
Like on this little image.[attachment=1:2bvrvpb6]<!-- ia1 -->bench.jpg<!-- ia1 -->[/attachment:2bvrvpb6]please, look a little bit closer to ansys outputs and you find out that the situation, you draw with red color, could not happen.
variant with distance block, you draw, would made structure more rigid. but the ribs are supposed to be flexible. distance between ribs is 30mm.@bjornkn said:
Here's an example of a similar concept, the Scandia chair. [img]scandia_lounge_2.jpg[/img]
As you can see - lots of lateral support.scandinavian furniture's design is always inspiring, e.g. peter opsvik's work.
Well, all commments here disagree with Ansys.
Did you tell Ansys that these ribs are fixed with 2 small points/bolts at the ends of the rib, made of laminated wood with fibers mostly following the curve, and that constant flexing/twisting may also eventually lead to water penetrating into the wood around the bolt holes and maybe cause rot?
There are no indicators on the Ansys charts to show where the fixed points are located?
Have you had an engineer or carpenter look at the design? -
here's a little project for you:
- go drill 30 3/4" holes in concrete
- report back with redesign
hi,
I do like the design...
having consulted on a number of 'street furniture' contests I'd like to suggest you consider 2 fairly common requirements.
installation time- simply how long will it take to erect on site [minimum being best]
cleaning and maintenance around the 'object' [hosing, sweeping, mowing, etc.]
with these in mind,
I think you could incorporate a footplate extrusion which allows for pre-construction, rising off the actual substrate and include spacers to alleviate some of the stability concerns raised in this post. The attached image is simply to explain what I mean, not an attempt to hijack your design.
yes of course. without that, the calculation would be completely useless.
there is no way how to take into consideration these factors. maybe use some coefficients. calculation is made with perfect material (just like you describe before).
one mechanical engineer and one woodworking engineer.
@driven said:
hi,
with these in mind,
brilliant idea and you are right (installation time, maintenance, lifetime, etc.). thx for pic - one picture say more than a hundred words
Like on this little image.[attachment=0:gl9mkt48]<!-- ia0 -->bench.jpg<!-- ia0 -->[/attachment:gl9mkt48]Exactly. And by hiding the cross brace, you still maintain the openness that makes it so cool.
Any lateral movement of this design is dangerous to the user. Limbs/extremities can and will get caught between the expanded gaps that will be created by lateral forces.
Very nice looking concept. I do have some questions for you. I don't expect answers but just for your consideration;
- What is the rational for the allowables. It would seem to me bending wood will have a considerable variations. Wood is some what like a composite so are there any requirements on moisture content control in the process of allowable establishment ;
- What knock down factors are used for the bolt holes;
- What muff factors are you required to use as you go form preliminary design to final drawing release. You should probably have say about 1.3 at start and 1.1 at end;
- Are any proof load test planned as part of build.
- What is the rational for the design loads. It seems to me the 180 lb force ( 800 nwt may not be adequate given the multiple seating). That is the reason for the muffs. Once you have all the allowables established then a total FEM with multiple loads will result in some elemnets loaded more that others ? You will assume differnt modulus and allowables etc for the elements?
- What is the rational for one load at a time vs x,y,z ( children playing adults seated and leaning etc. ?)
1)12,9MPa โ compressive strength (radial); 55,5MPa โ compressive strength (longitudinal); 109MPa โ bending strength; 11,6MPa โ shearing strength;
w = 12% ; for beech โ composite will have better properties.
2)Sorry, I donโt understand at all. Knock down factor โ what does it mean?
3)Sorry, I donโt understand at all. Muff factor โ what does it mean? Donโt know what muff is.
4)It is a standard.
5)800N (180 lb) on one lamella. Maybe, itโs too much.
6)X = 500N, Y = 800N, Z = 800N
Sorry did not mean for discussion.
FYI: The question is you have allowables ,but where did they come from and how good are they. Composites are not by definition " better". They are very process sensitive and not like metals and you can not depend totally on text book values. You have to look for bonding voids, moisture control etc. We would run ultra sound and proof test etc on each item we build. Of course we were building for some rigorous application. Ask the aircraft engineers what they do for composites on planes they build.
When you have bolt holes etc. one gets a reduction in strength ,so knock down factors are applied to account for such things. For example in your case the bolt holes cause a material reduction so do you use the same strength there?
When one normally starts a design there are some unknowns. For example the material properties, loading etc. There is typical a 'muff'( sorry for the slang) aka safety factor will be applied at the start and then that is reduced as one goes through the design process. So say at the very start you may have a 1.3 and then when the drawings get final approval it may be reduced to 1.1. The values we used were established either by the customer or the chief engineer.
4)It is a standard.
6)X = 500N, Y = 800N, Z = 800N -
hmm.. where i come from, muff means something totally different and in the case of this particular bench design, i'd be more concerned with the ball factor as opposed to the muff factor.
John's illustration illustrates exactly what I suggested in my original crit...a steel spine running along the base with all the members slotted into it, so that it would require much fewer fastenings into the concrete. But your response was:
It will definitely stay how it s designed.
http://wood.mendelu.cz/cz/sections/Props/?q=node/56 good source
they have better properties than just a wood, that's why they are made e.g. glulam, paralam etc.
it's about ensuring quality in technology process, I don't want to build a plane - it is just a bench.
it's a little bit expensive, isn't it
it is not the spot where the lamella could crack first.
you meant safety coefficient, I suppose. in this case the muff factor is 4,2 than.
maybe in another dimension.
not any more please
Like I have said more than once I was not looking for any answers, was trying to give you some items to think about and gee I did not know you were not building an aircraft. I also specifically stated my experience base came from more rigorous applications. You are the final designer and will have to take full responsibility for the design. You need to under stand (if nothing else) composite designs can be very good but they are only as good as the process controls in the build. It is NOT like buying some metal part. You must consider the effect the attachment methods have on you design.
thank you all for your consideration and comments.
Great to see that you are defending the design and have given so much thought to our comments. Here is a picture of someone who also had a great idea and through the process of (RE) design ended up changing the world.
As the saying goes...
"IF at first you don't succeed TRY TRY again"....
Build a full size prototype sit in it. Have a well built fellow "AKA someone like me with a beer gut" push on the side of the end rib at top curve with the intent of pushing over the rib...and then you can decide was the structural analysis software correct or not.
With your input, this post could be even better ๐
