    1.5k Posts 471 Posters 3.4m Views 470 Watching
    • fredo6F Offline
      I am still scratching my head where it can come from, why it is only on Mac and why only for Roundcorner (the palette package is the same for other plugins like Curviloft and TOS).
      Several Mac users have reported the problem, so there must be a rational explanation.
      Still investigating
      • fredo6F Offline
        By the way, can you confirm the follwoing point:
        When you start Roundcorner on an empty selection
        1. Do you have to wait to see the button palette appear for the first time ?
        2. or slow behavior is only when you move the mouse(which refreshes the palette) without clicking ?
        3. Or is it only when you select edges that you have the slow behavior?
        Also, can you open the Ruby console when you run RoundCorner, in case there are messages displayed.
        • jeff hammondJ Offline
          fwiw, here's roundcorner on my laptop (15" i7) but it works the same on my desktop (2.66quad macpro)..
          [flash=853,510:3hfz6m0m]http://www.youtube.com/v/CFV33Eu8Y6I?fs=1&hl=en_US&rel=0[/flash:3hfz6m0m]
          as you can see, everything works fine.. i used this example because it had so many edges to round but even then, it only took 6 seconds.. a simple box is basically instantaneous..
          also, orbiting etc. works fine as well when the palette is up..
          i wish i could make roundcorner work not so well in order to help find a solution but i've tried literally 100 different things to mess it up and i can't do it..
          • fredo6F Offline
            Jeff,
            Apparently the issue of performance appears for some Mac users, not all.
            And also, it seems to be related to the selection mode , not to the generation of geometry. I understand that it is related to the display and refresh of the button palette.
            PS: on my slow laptop on XP, your model takes less than 2 second to round, with 6 segments for rounding.
            EDIT: if the Arc curve is exploded, then it takes around 7 seconds, like in your video
              that reminded me of some issues with the Render[In] plugin.. (though it affected both macs & pcs)..
              basically, normal SU selection was hit very hard and would take minutes to select instead of instant..
              here's the thread on that:
              http://forums.sketchucation.com/viewtopic.php?f=15&t=31401
              i'm wondering if another plugin could be causing this?
              can some of you with the roundcorner/mac problems post the contents of your sketchup plugins folder? (and maybe the tools folder while you're at it?)
                cfarrell10
                Hi Fredo,
                If I have the palette minimized from the previous time I used it, there is no lag(the little palette in the top left pops up straight away).
                However if the palette was open the previous time, it takes a minute or two to appear. From there(with the palette open) the tool is slow in everyway. When I move the cursor over a part of the model, it does not change colour depending on what type of edge/face you are selecting(like it does on windows), even moving the cursor is not very responsive. If I then decide to select an edge without seeing the colour change on the cursor, i could wait maybe 1 to 2 mins to see the selection highlighted. Its not workable at all.
                Unfortunately, I've only bought a Mac recently and I am unsure how to bring up the rubyscript thing you mentioned, maybe some1 could explain??
                Thanks for your help.
                cf
                πŸ‘
                • fredo6F Offline
                  Conor,
                  Can you try with the updated file at the following post and tell me if you notice any improvement.
                    cfarrell10
                    Conor,
                    Fredo,
                    Sure will do, I'll be home for lunch, can do it then.
                    Cheers
                    Conor
                      cfarrell10
                      Conor,
                      Hey,
                      I tried it @ lunch and BOOOOOM, works great!!! Thanks so much Fredo.....legend!
                      • fredo6F Offline
                        NEW RELEASE: RoundCorner 2.3a- 26 May 11
                        This release fixes the slow navigation issue for some Mac users.
                        It also requires you upgrade to LibFredo6 3.7
                        Please see main post for download
                          shoeb_cars
                          πŸŽ‰ better just got best thanks man... πŸ‘
                            rjjvirusx
                              manson666
                              really powerfull plug in
                              thx a lot man πŸ˜„
                              • COSEDIMARCOC Offline
                                COSEDIMARCO
                                Italian translation for Round corners
                                RoundCorner_IT.zip
                                [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                                  lavangmuathu
                                  thank you so much , great
                                    brandonsh
                                    Please, PLEASE help me here. I'm trying to round edges on a cube but I never get any green lines to show where it's going to round, and if I press enter anyway my model just completely explodes everywhere, turning into a mess of whatever. Can anyone give an idiot some simple instructions?
                                    • fredo6F Offline
                                      Watch the Offset value (indicated in the button palette). It may be either too big or too small relative to your cube.
                                        caktusbill
                                        thanks for plugin, very, very usefull.
                                        Maybe a quad chamfer like this http://www.scriptspot.com/3ds-max/scripts/quad-chamfer in future versions? It's better to edit uv's and apply subdivision later.
                                        Thanks again.
                                        • fredo6F Offline
                                          RoundCorner allows specifying the number of segments, so with '4s' you will obtain what you refer to as quad chamfer (unless I missed something!).
                                          Note however that Roundcorner is not able to support the concave / convex corners with 6 rounding which is shown is the picture (regardless of the number of segments for the rounding).
                                            Jim
                                            Yep, all the faces are quad faces, not that there are 4 segments that make the curve. Quads are better than tris if you use subdivision in your workflow.
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 73
                                            • 74
                                            • 20 / 74
