    1.5k Posts 478 Posters 4.3m Views 478 Watching
    • C
      cfarrell10
      Conor,
      Can you try with the updated file at the following post and tell me if you notice any improvement.
      Hey,
      I tried it @ lunch and BOOOOOM, works great!!! Thanks so much Fredo.....legend!
      • fredo6F
        NEW RELEASE: RoundCorner 2.3a- 26 May 11
        This release fixes the slow navigation issue for some Mac users.
        It also requires you upgrade to LibFredo6 3.7
        Please see main post for download
          shoeb_cars
          πŸŽ‰ better just got best thanks man... πŸ‘
            rjjvirusx
              manson666
              really powerfull plug in
              thx a lot man πŸ˜„
              • COSEDIMARCOC
                COSEDIMARCO
                Italian translation for Round corners
                RoundCorner_IT.zip
                [floatl:2wjeiugn]COSEDIMARCO - The Website[/floatl:2wjeiugn]
                • L
                  lavangmuathu
                  thank you so much , great
                  • B
                    brandonsh
                    Please, PLEASE help me here. I'm trying to round edges on a cube but I never get any green lines to show where it's going to round, and if I press enter anyway my model just completely explodes everywhere, turning into a mess of whatever. Can anyone give an idiot some simple instructions?
                    • fredo6F
                      Watch the Offset value (indicated in the button palette). It may be either too big or too small relative to your cube.
                      • C
                        caktusbill
                        thanks for plugin, very, very usefull.
                        Maybe a quad chamfer like this http://www.scriptspot.com/3ds-max/scripts/quad-chamfer in future versions? It's better to edit uv's and apply subdivision later.
                        Thanks again.
                        • fredo6F
                          RoundCorner allows specifying the number of segments, so with '4s' you will obtain what you refer to as quad chamfer (unless I missed something!).
                          Note however that Roundcorner is not able to support the concave / convex corners with 6 rounding which is shown is the picture (regardless of the number of segments for the rounding).
                            Jim
                            Yep, all the faces are quad faces, not that there are 4 segments that make the curve. Quads are better than tris if you use subdivision in your workflow.
                            • fredo6F
                              Jim
                              OK I got it!
                              The problem is that this quad faces would not be planar, and therefore would be build from 2 triangles in Sketchup. Let's not forget that Nurbs-based modelling tools display shapes with quads which are usually not planar (that's what Curviloft doe in preview mode), but it does not really matter because the rendering is also taken care by the software without going to the true geometry with facets.
                              • dereiD
                                derei
                                I think this plugin somehow does "somethnig" to the CPU that stops Twilight from work.
                                How it happens: I have a SU instance where TW is rendering... I work something else in another SU instance and I use the plugin. It is slow responsive, especially when I try to open the inputbox to change rounding and precision values. In the end I can use it. But, when I look on the other SU window, where the render goes on... the passes counter is stopped. If I pause the render, then I resume it, everything works again.
                                If this is TW related, rather thant RoundCorner issue, maybe Fletcher should be advised?
                                Thank you.
                                DESIGNER AND ARTIST DEREI.UK
                                • fredo6F
                                  Dereeei,
                                  I don't have twilight and I would need to install it to investigate.
                                  In the meantime, maybe some other Twilight users could try to reroduce your case with 2 instances of SU and advise if there is this performance problem.
                                  By the way, is it just for RoundCorner or for other plugins like ToolsonSurface?
                                  • dereiD
                                    derei
                                    I will try with TOS too, as soon as I can and I will post the conclusions.
                                    Thanks for your attention.
                                    • T
                                      TonyGasz
                                      I do not understand anything, set as indicated.
                                      when doing surgery just gives an error.
                                      They are used - Google SketchUp 8
                                      -LibFredo6 3.7c - 07 Jun 11
                                      -RoundCorner 2.3a - 26 May 11
                                      what could be the problem, do put a small block parameters 0.10 and 6. help
                                      sorry for my english I'm from Russia
                                      • dereiD
                                        derei
                                        If you don't tell what error (maybe a print-screen), I wonder how somebody could help. πŸ˜•
                                        • T
                                          TonyGasz
                                          I think I figured out in your plugin, I stood apart from the fact that I listed above - Podium render, when I removed the folder completely plug and insert a blank without any plug-ins in addition to the required course, then it worked. so here, but about the Scrin is a common mistake Google's screen. πŸ˜‰
                                          • K
                                            kimley2011
                                            Very helpful! thanks a lot!!!
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 74
                                            • 75
                                            • 21 / 75
