    [Plugin] Extrude Edges By Offset v1.0 20110525
    15 Posts 12 Posters 20.7k Views 12 Watching
    • TIGT Online
      extrudeEdgesByOffset.PNGYou can download it as part of the zipped set of 'Extrusion Tools' from here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      Copyright 2011 (c) TIG
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      extrudeEdgesByOffset.rb
      Usage:
      Select two or more Edges, Curves etc to be Offset.
      Anything else in the Selection, such as Faces, will be ignored.
      The selected edges must be 'coplanar' and should be 'connected' and not
      'branching' - otherwise the tool might stop, or unexpected offset results
      can occur.
      Run the Tool from Plugins > 'Extrude Edges by Offset'.
      or click on 'Extrude Edges by Offset' in the 'Extrusion Tools' Toolbar.
      [Activate this Toolbar from View > Toolbars if it's not loaded]
      If there are < 2 edges or they are not coplanar then a dialog warns and
      the tool stops.
      A dialog opens, enter the required offset distance in current units or
      other units with a units suffix - e.g. if you are working in 'mm'
      entering 100 offsets 100mm but entering 4" would offset 4" [101.6mm].
      OK to continue, Cancel to stop tool.
      Entering a -ve value offsets 'inwards' rather than the default 'outwards'
      Note that you cannot enter 0 as the value - you are warned and the dialog
      reopens so you can retry, entering 0 again [or Cancel] stops the tool.
      The offset entered is remembered across tool uses in the same session.
      The selected edges are replicated inside a group and offset by the
      desired distance. A loop of edges creates an offset 'doughtnut' form;
      a set of edges with open edges is finished with two 'square' ends.
      Faces are added to these edges and subdivision coplanar edges are added
      across each pair of vertices. You are prompted Yes|No to reverse the
      faces [the default is 'up'], then to erase the coplanar edges and finally
      to explode the group so that the new geometry merges back into the
      active_entities' geometry.
      Donations:
      Are welcome by PayPal to info @ revitrev.org. PayPalButton
      Version:
      1.0 20110525 First release.
        SketchUpNoobie
        You're on a roll TIG! Thanks a bunch for these awesome tools. πŸ˜‰ I'll have to try this out this afternoon.
        SketchUpNoobie: the complete noob in all things SketchUp.
        • srxS Offline
          srx
          πŸ˜„ Thank you again!
          www.saurus.rs
            Miracles take a day. I'll make a note of that!
            Thanks TIG
            • PixeroP Offline
              Pixero
              Thanks.
                http://news.sketchucation.com/files/2009/06/projections.jpg
                You do it! Bravo!
                I am anxious to see if repetition is inside β˜€
                Ah there is not! πŸ’š
                Next selection should be the new external result!
                And a "Do you want Enter a new Distance if not Satisfy" will be also cool πŸ‘
                Because result is not always predictable πŸ˜’
                This tool + Extrude Edges along a vector = a mega super tool 😎
                • EarthMoverE Offline
                  EarthMover
                  Woo-hoo! Can't tell you how many times I've wished for this!!!! TIG you are the MAN!
                  Content Creator at Skapeup
                    And if after the first selection you can just move the mouse against enter a value
                    and repeat at the end of the process that will be a task! β˜€
                    Left click + Move = Offset, Right click = extrusion πŸ˜‰
                      Jean-Luc Clauss
                      Very nice plugin TIG. Thank you so much.
                      Auteur de guides et de mΓ©mos sur SketchUp aux Γ©ditions ENI
                      http://archi-com21.blogspot.fr/
                        And also because the CTRL + Z lost the first selection! πŸ˜‰
                        • N Offline
                          numerobis
                          WOW! very cool! Thank You!!! 😎
                            if possible
                            Mouse + click down pressed without release = Offset ,
                            mouse x y without click down pressed without release = extrude along vector πŸ˜„
                              shoeb_cars
                              πŸŽ‰ amazing how you do it....i always think n thank u for making such amazing tools whenever i rescued by your tools
                              respect ++
                                rv1974
                                Ofsetting.. Outstanding
                                Bravo!
                                  james123
                                  Thank You....
