    What was that plug-in that creates multiple faces???
    10 Posts 6 Posters 1.2k Views 6 Watching
    • utilerU
      utiler
      Anyone know?
      I remember seeing a post about a set of tools for when you're working a large CAD file you can select all and it starts building faces. If any left over you can run it again and again until you've got what you want.....
      Cheers,
      Just Curious...
        d12dozr
        MakeFaces?
        http://goo.gl/f7ooYh
        • utilerU
          utiler
          No, it was a toolset from memory, Marcus. I do have makeface but with large models it doesn't work too well....
          πŸ‘
          Just Curious...
            Maybe the Ghost Comp by Fredo 6 ?
            But this one does not create faces it's simplify face for a tempo for manipulate big files more easily
            and restore them after
              Tools on Surface adds a context menu "Generate Faces".
              • utilerU
                utiler
                No, neither are what I was referring too..... cheers. it's bloody driving me crazy!!
                Just Curious...
                • utilerU
                  utiler
                  I know what it was, now! PowerCEMF was it!!!!
                  'Power clean edges and faces' by purplewind but for some reason I can't find it here. I recall it was in chinese but did see a cool video of an imported CAD file being 'clean-up and adding faces as it goes....
                  really cool but. Any ideas why it wouldn't be here? πŸ˜•
                  Just Curious...
                  • N
                    numerobis
                    @utiler said:
                    I know what it was, now! PowerCEMF was it!!!! ...but for some reason I can't find it here. ... Any ideas why it wouldn't be here? πŸ˜•
                    ...maybe because it looks like this
                    http://www.powersutool.com/wp-content/uploads/2011/02/PowerCEMF_2.jpg
                    so... where is the "Make Faces"-button?!? ... 😲 πŸ˜• ❓ πŸ˜’ πŸ’š
                      πŸ˜‰ http://www.powersutool.com/?page_id=18 this might help... πŸ˜‰
                      All you have to do is translate it from Mandarin to English πŸ˜•
                      Moreover increased the line to interlock the automatic reduction function (i.e. before to deleting end, did not need to interlock this order in manual execution model) and completely automatic processing (deletion end, closed curve, title page) 0.1b edition: Increased the plan double thread function 1: Plan continual double thread 2: Plan rectangle double thread 3: Plan circular double thread 4: Plan arc double thread displacement line function 5: Many lines displace 6: When repair displacement produces mistake 7: Displacement single track function displacement entity function 8: Including linear displacement, 9: Circular displacement, 10: The arc displaces 11: The establishment contour line function publication echo clicks on here to cancel the reply. The name (must) the email (issue) (not probably) the homepage echo recent article product function register article RSS to comment RSS WordPress
                      The dialog is a bit tricker πŸ˜’
                      • utilerU
                        utiler
                        Yes it is tricky, TIG but I recall seeing a video of it in action and looked neat....
                        Just Curious...
