    Pipes
    21 Posts 7 Posters 2.0k Views 7 Watching
      Pilou, please, again, in the Newbie section let's start with the easy stuff. For an exhaust pipe, you do not need a professional piping system!!!
      Hi Paul,
      I find it hard to exactly understand your workflow but complex pipes are generally easy to create with the Follow me tool
      Have a look at the example below
      FollowMe.skp
        Sorry i never read the section's name! 😳
          Yes, I know... ("Speedy" Pilou)
            Paulfury
            hey guy's ty for replying this addon is what i'm looking for great thanks=) also i Use the follow me tool to but it looks nasty on the edges and i have to do alot of repair jobs lol ty again=)
              @Gaieus 💚 😉
              • numbthumbN Offline
                numbthumb
                Not an inbuilt SU tool, but worth checking out in any case : http://forums.sketchucation.com/viewtopic.php?f=323&t=12354&hilit=plugin
                Comfortably numb...
                • mitcorbM Offline
                  mitcorb
                  With all due respect to the intent of this subforum, but since Paulfury is in the game, also look at pipe along path and tube along path, which have the capability to make smoother transitions under certain circumstances.
                    I am certainly not against discussing plugins here - I only mean that throwing in two links to some extremely complex plugins will not be helpful for a newbie who (and IF he) does not even know how to use the Follow me tool.
                    Certainly these two ones are great (and quite simple to use) plugins but let's see what Paul says (and "where" he is in the learning curve).
                      mac1
                      Then why not tell all about the follow me tool?
                      Paulfufry:
                      I notice you are using a rectangular cross section. The follow me tool comes with a characteristic in that it will rotate that face you are trying to extrude in certain cases. There is some plugins that solve that problem. To check try the round case and see if you still get the "edge" problem
                      • mitcorbM Offline
                        mitcorb
                        @Gaieus:
                        Sorry for the lapse in judgment on my part.
                        Sincerely,
                        mitcorb
                          That's exactly wht I did above:
                          http://forums.sketchucation.com/viewtopic.php?p=329740#p329740
                          Mitcorb; as it seems that Paul has not come back to tell us where he is in the learning curve, I relally have no grounds to criticize anyone. Those two plugins you mentioned are really excellent and I would also recommend when we have something more concrete from him.
                            mac1
                            Sorry my bad, still on 7 here and did not go thru the hand spring to open your attachment. 😞
                              Oops - now as you say, I have just checked that Paul is also on 7 so saved it in v.7 now.
                              (I generally check but as you can guess, often forget) 😳
                                Paulfury
                                Hey guy's I've been using the follow me tool since the beggining i've done alot of research before even atempting my 1st model lol Just realised that 1st addon is 169 Euro but 60 day free so it's cool but it doosn't seem to be doing the job i need done lol, is there anyway i can post a pic of what i need doing? i'm new to forums ty
                                  There is an "Upload attachment" tab below the text area you are typing your post. Unfortunately the multiple upload function does not wok so once you selected a file, you have to press the "Add file" button to attach it and then you can add a new one.
                                  If, besides images, you could upload an skp as well, that would be even better.
                                    Paulfury
                                    Hey again I can't attach a file atall now lol I think it's completely broken.
                                      No, it's not.
                                        Paulfury
                                        ok it's not working for me keeps going to another page and say's internet problem. I pres diagnose and it's say's can't identify lol do i have to change the file type it's striaght from MS Paint?
                                          Jim
                                          Paul,
                                          When you save the file from MS Paint, select either the .jpg or .png file-type. I'm guessing the forum does not allow .bmp uploads because they take more band-width than the other formats.
