    [Plugin] Pen Tool +
    126 Posts 40 Posters 101.1k Views 40 Watching
      shades like ThomThom has
      what shades?
      Those things over his eyes. What are those things anyway?
        Eyebrows?
        There's a fix coming on the VCB issue and an extra Edge Draw mode that doesn't create faces
        • jason_marantoJ Offline
          jason_maranto
          Very cool idea -- thank-you! β˜€
          Best,
          Jason.
            Little update with Thom's and Dave's suggestions [not Eric's πŸ˜• ]
              Well, Rich, congrats, really. I remember when Remus also wrote a plugin - now "non-scripters" are slowly becoming a minority here... πŸ˜’
              I remember a wise man once answering this question:
              Do you build or have you built any SketchUp Ruby Scripts?
              like this...
              There are so many talented and generous ruby scripters out there that it would be a waste of resources to start playing with it and keep hindering them in their work with my basic questions...
              And sorry for not having been able to me of more help - I have just come back home.
              Nice icons, too!
              πŸ˜‰
                Thanks Csaba, there are still some little gremlins [not Mike] to iron out
                  Thanks Rich.
                  Out of curiosity, is this what I should see when I open the ZIP file?
                    try again
                      Cool! 😎
                      • H Offline
                        hebeijianke
                        try again
                        There something wrong
                          Bit more info?
                          • H Offline
                            hebeijianke
                            Bit more info?
                            Weld Draw is not work well
                            • kenK Offline
                              ken
                              I use rollers, wheels and axles that I wish to add a guidelines though the center for alignment that will be part of the group. It would be nice, if I could draw a guideline between two points, maybe only 12" apart, and have the guide line that is drawn be the size as indicated in the measurement tool bar. So if I wanted to add a guideline to a wheel that is only 12" wide, however, I wish to have the alignment guideline to be 10' long, I could enter the 10' into the measurement tool bar, draw the line between the two center points that are only 12" apart, and have the guideline be drawn 10' long.
                              So thank you for you plugin.
                              Ken
                              OOPS. Didn't see that I could add the length to the guidelines in the VCB. My bad. So disregard the above.
                                Weld Draw is working fine for me. It all works fine except my second request. But, beggars can't be choosers so I'm not complaining.
                                  Version 1.2 (remove old before installing)
                                  thanks to TIG for tweaking again for squashing some bugs.
                                  See first post for latest.
                                    Now Weld Draw doesn't seem to draw welded edges.
                                    Soft Draw will convert unsoftened edges to softened but doesn't draw softened wedges from the start.
                                      It seems it's only welding when aligned to an axis? Can you confirm?
                                        No, it seems to toggling on/off....strange? TIG?
                                          It isn't even Friday the 13th.
                                            Updated to v1.3
                                            Note:
                                            Weld Draw does not draw welded loops. It will also split if it intersects with any edge and get a little funky. It's primary function it to create a simple curve from drawn edges[lines]
                                            • 2 / 7
