    [Plugin] Autoloader
    13 Posts 8 Posters 13.1k Views 8 Watching
      Diggsey
      Yes it will see new files as well as existing modified ones;)
        AndriyG81
        works like a dream.
        πŸ˜›
        Thank you
        http://andriyg.com
        • Bob JamesB
          Bob James
          Now thisis a timesaver πŸ‘
          • Didier BurD
            Didier Bur
            works like a dream
            @AndriyG81: does it reload modified files that are in sub-folders of the Plugins folder ? It doesn't do that for me... 😒
            DB
              Diggsey
              Currently it only reloads files in the plugins folder.
              • Bob JamesB
                Bob James
                But does it "see" newsub-folders?
                More precisely, if I've put a new plugin into the plugins folder while SU is open and that new plugin contains a folder, will Autoloader "see" the new sub-folder and allow the new plugin to work?
                  When you get a list of entries in a Directory it will include files and folders.
                  It loads scripts it finds by files by their extname [.rb etc], but you can also find directories by their filetype.
                  So it's also possible to get a list of any subfolders and then reiterate through those to get their .rb files etc etc...
                    Diggsey
                    Yes, of course. It doesn't affect the way the plugin is loaded, it just loads it.
                      Jim
                      Hi Diggsey,
                      Nice idea, thank you. However...
                      Sketchup::load (if I remember) is an alias for Sketchup::require, and doesn't reload scripts that are already listed in the $LOADED_FEATURES array. In short, I don't think anything is actually getting reloaded.
                      Also, it would be helpful to wrap the load in begin..rescue..end to catch LoadError's and SyntaxErrors and report them as coming from the file being loaded instead of from autoloader.
                      Related Topic
                        archipod88
                        cool...i tried it thanks a lot..!!! πŸ‘
