    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 293.9k Views 172 Watching
      @tomot said:
      v.0.5.4 : only produces one statement in the Ruby Console after it installs the Ivy leaves.
      quietly_force_sync_mats_cb just called
      but otherwise works flawlessly.
      That is generated by V-Ray for SketchUp.
      • jamalitoJ Offline
        jamalito
        @jamalito said:
        hi guyz
        how is it do this plugin ?
        I downloaded it but can not use it πŸ˜•
        is anyone tell me how is this work ?
        Albert Einstein:
        ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
        • F Offline
          function
          extract the rar file (http://www.win-rar.com/) into your Sketchup Plugin folder, located in the Google program files: Both LiveIvy.rb and the directory LiveIvy should be directly in the Plugin folder. Restart sketchup, select the faces you wish the ivy to grow on and access the plugin the the dropdown menu "Plugins" The GUI should appear, click the tab Usage for a full explanation of ...usage.
          btw: Pierreden - this is my favorite GUI of any sketchup plugin, bravo πŸ‘
            tomot
            I thought I would be able to add a 4th leaf to the LiveIvy.tool.rb script.
            Having made a new ivyleaf_4.skp file and adding the following code paragraph
            unless ;;Pdn;;LiveIvy;;Definitions.present?("ivyleaf_4")
                    #path = File.join(pathname, 'Textures/ivyleaf_4.skp')
                    pathname = Sketchup.find_support_file "ivyleaf_4.skp", "Plugins/LiveIvy/Textures/"
                    definitions.load pathname
            I thought would have worked ......it did not! 😞 any ideas what else needs to be changed to accept a 4th leaf? I also made the leaves into actual cutouts, the procedure is similar to making "face me components". I will post the new revised leaves soon.
            [my plugins](http://thingsvirtual.blogspot.ca/)
            tomot
            • soloS Offline
              Oh yes,I agree the leaves need to be .png's with alpha channel, especially for render purposes, I'd like to have something similar to fur plugin that I can choose what to use as leaves if possible.
              Face me would be awesome.
                tomot
                have a look at the attached Texture folder, it contains the Ivy shown above.
                let me know how it works!
                (if you only have winzip just rename texture.rar to texture.zip and open it with winzip)
                Textures.rar
                tomot
                  mukul.ar
                  0.6.3 is the version I'm using now... The ivy is not closing on shift + click. Was playing with 0.5.4 earlier and it worked perfectly. I've playing trying it out on sketchup 8. (yes i deleted the previous version) Just reporting... No complaints..πŸ˜„ great work on the plugin mate..!
                  My Works
                  • N Offline
                    nomeradona
                    first of all thanks for this pluggin. its wonderful. I have the following request.
                    1. two skp files were done in su8, its better if they are done in SU6, they can be opened in su7 and su8. if they were done in SU 8 then it has error in SU7 and SU6.
                    2. Please make the leaf textures as png file with background as transparent. its easier to render. instead of tiff or jpg
                    3. HOw is the possibility where user can load its own skp files. rather than depending on the three skp file leaves.
                    again my honest to goodness thanks to you pierre.
                      mukul.ar
                      This is just a workaround IMHO. There are 3 skp files in the rubies folder these are the 3 leaves each... you can save your own png textures instead of these leaves, but i'd recommend you place them on the same position as the existing leaf as it might affect leaf position otherwise. (you can save these in the skp format you use)
                      As solo and a few others have also said it would be definitely great to have some control as to what components to use as "instances" for the leaves like we have in the make fur plugin. It would add more control as to the kind of things we can make with this wonderful plugin... ( FRUIT LADEN TREES is definitely something i might play with πŸ˜„)
                      My Works
                        a3rosmith
                        is an excellent plugin from the beginning was working fine....but now it seems not work properly.....I got this console ruby ivy version 0.6.3
                        Error: #<Errno::EDOM: Domain error - acos>
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb:35:in acos' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_branch.rb:35:in grow_stem'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:204:in grow_stem' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:203:in each'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:203:in grow_stem' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:202:in times'
                        C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:202:in grow_stem' C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/LiveIvy/LiveIvy_tool.rb:90:in onLButtonUp'
                          gaonirico
                          @pierreden said:
                          @gaonirico said:
                          I installed the version 0.5.4 but from the previous version 0.3 the menu not shows correctly and function the change of parameters. Happens because my monitor functions only to 800x600? or I must have installed some update of internet explorer?
                          @gaonarico: I dont know im afraid. It might be a javascript issue, if so, updating you IExplorer might help. But this problem is noted and i really hope to solve it soon.
                          I resolved the problem. The cause went for some spyware or badware. I decided create a new account of user which solved also other errors in my pc
                          • Alan FraserA Offline
                            Alan Fraser
                            All it needs now is a parameter to add bunches of grapes...and the designers of Greek tavernas will be very happy. πŸ˜„
                            3D Figures
                            • leedeeteeL Offline
                              leedeetee
                              Any idea what I'm doing wrong?
                              My ivy leafs appear with borders?
                              (Thanks to Earthmover for answering previous question).
                              • soloS Offline
                                What render engine?
                                The answer is because they are jpg and have no alpha channel, they need to be .png or you need to have the alpha mask in the right slot.
                                  leedeetee
                                  Just playing with SU output at the moment, Solo.
                                    driven
                                    hi
                                    question for the experts?
                                    I'm going out to the garden to collect some english dog rose stem, leafs, buds and flowers to make up a set.
                                    what would be the best size, resolution, etc... to use with this. The originals seem huge to me, is that necessary?
                                    Obviously transparent background png's
                                    • FrederikF Offline
                                      Frederik
                                      Looked so to me as well, nonetheless, you need to use png-files where the white parts are actually transparent as Solo already have pointed out...
                                      If you don't have one, you can play with this ivy leaf EarthMover posted earlier...
                                      Cheers
                                      Kim Frederik
                                        leedeetee
                                        Super, thanks, and thank-you Solo.
                                        • PixeroP Offline
                                          Pixero
                                          @driven said:
                                          hi
                                          That depends on how close the camera will be. A general rule is to use sizes such as 256x256 pixels, 512x512 etc. since they use the least amount of memory compared to it's size.
                                            tomot
                                            I don't know where all this **"png with alpha channel"**stuff is coming from, certainly one can do a precise cutout using PS and SU only, that's how I make the new Ivy leaves I posted in my rar file. Granted its a little more work. Also everyone in the photo-reproduction industry I know, is NOT a .png fan, and will always ask to convert to .jpg before printing.
                                            If you use my .jpg ivy files they will also load easily into the fur plugin.
                                            tomot
                                            • 36
                                            • 37
                                            • 3 / 37
