    HOW i CAN MAKE REAL WATER IN VRAY
    renderpluginsextensions
    17 Posts 6 Posters 10.3k Views 6 Watching
    • jamalitoJ
      jamalito
      @thomthom said:
      Please, when postings - do not use all caps. It's bad forum manners - seems like you are shouting. If you do not care about capitalisation, then at least use lower caps.
      For water materials I just use a 100% diffuse layers and a reflection layer with a Fresnel map. To get the ripples you add a bump map.
      If you post a picture of what you have, that would help to give more specific tips.
      Remember that lighting and the environment reflected in the reflection will affect how realistic the water looks.
      Iam sorry πŸ˜’ Mr thom but I like this render it is not posting to them but I want to say how I can to did it
      thnx to to your advice I will make my render and give me your advice
      Albert Einstein:
      ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
      • kaluK
        kalu
        Hello:
        I try the settings that I read in the web in some tutorial but I have no luck what so ever in the final render. I learn Caustic now but I want the same results as the render final I will ad later caustic. I just want to see the same bumps that I missing. Also the color is not right for some reason. VR 1.48.89 Sketchup 8 Pro, Windows 7 - 64.
        I post the model and some samples for help.
        Water render final (I try to get this effect)
        http://i637.photobucket.com/albums/uu100/artechedesign/water.jpg
        I have this render
        http://i637.photobucket.com/albums/uu100/artechedesign/waterrender.jpg
        How I can ad bump map for ripples where I can find a map for ripples?
        I hope you can help me with the settings Thomthom...Thanks.
        THE ONLY DIFFERENCE BETWEEN FICTION AND REALITY IS WHEN FICTION HAS TO BE CREDIBLE
        • kaluK
          kalu
          Got it...After 6 hours of learn caustic and try make this water render...
          http://i637.photobucket.com/albums/uu100/artechedesign/test-03.jpg
            Ah, you wanted caustics. Did you do that with just the V-Ray sun? OR did you use a different light source?
            • kaluK
              kalu
              I use Vray sun, It take me 6 hours to learn the caustic and put so many options that I am proud of the results. After I make the same results that I wanted and the begin of my question, I move in to the caustic so I can more realistic view of the pool. Now I can do the pool and the sea...Great work, but allot of learn...
              Thank you ThomThom for always great help!. πŸ‘
                I think you did most of it - I've never really used Caustics much. I'd probably have to ask you about it.
                • N
                  nightwishzm
                  mr kalu
                  can you explain us pls how did you get that result ? πŸ˜„, maybe screens of parameters ?^^
                  • kaluK
                    kalu
                    I am out of the country for vacation, I will post a result after I back in a month.
                    • H
                      Hayduke
                      Still waiting for the follow up post:-\
                      • 0
                        06100143
                        try this tutorial...
                        http://www.youtube.com/watch?v=vbHdi5bEdlI
                        hope this would help you.
                        • H
                          Hayduke
                          yeh - that's great - found it after looking for a while. Think i dled the model from the ASGVIS site to follow along but that went down:( wonder if Chaos Group is going to fix the forum and all the materials and tutorial links 😞 would have dled a lot more had i known:(
