    CAM / CNC ?
    29 Posts 12 Posters 5.2k Views 12 Watching
      dedmin
      Jim, that is nice! How is that working? Is the way SketchUP draws curves present an accuracy problem?
      • E
        errror404
        Thanks guys... exporting a .stl is not a problem. I use Rhino 3D and SketchUp
        errror404, what do you want to do with the CAM/CNC software?
        It's for a hobby CNC machine that I'm building in my basement...
        I'm modifying a X2 mini mill into a CNC machine
        This is what I'm trying to do:
        http://www.youtube.com/watch?v=r4md9aeTCbg
        The CAD part I have it figure out... it's the CAM part which I need some help finding cheap solutions.
        I would like to mill semi-complex things out of aluminum and copper. 2.5D and 3D 😄
        thanks for all the input, and sorry for taking so long to respond
        Oh... maybe in the future, I'll add a 4th axis
        http://www.youtube.com/watch?v=nvG_dmjA-pQ&feature=related
        http://www.youtube.com/watch?v=NzY-OqckqpI&feature=related
          Jim
          I've heard good things about EMC2 (for Linux.)
          Also, PhlatScript can export g-code directly from SketchUp; and I've heard they are working on 3d support.
          Not working so well at the moment - I am having trouble with one of the axes going beserk and haven't been able to track down the cause. It's just a process of trial and error to eliminate the possibilities at this point.
          SketchUp's segments are visible on larger-radius curves, but for the most part the default number of segments has been fine. My machine isn't designed to be super-accurate.
            dedmin
            Thanks, Jim. There are not so many people to give us first hand experience with CNC and SketchUP. And that is bogging many users that love SketchUP and want to use it for machining.
              Jim
              I've experimented with Shapeways, also. They accept COLLADA files directly from SketchUp; although I had trouble with textures (Colors worked fine, just not image-based textures.) I made a Shapeways uploader using their API, if anyone is interested. I never posted it because it's too rough.
              It seems clear to me that 3D printing will soon be on-par with other methods of machining/molding for many manufacturing processes - when the technology improves just a little more. From the press coverage, we appear to be a tipping point for 3D printing. It has become affordable for hobbyists to build 3d printers, and they are able to print copies of some of their own parts for repair or reproduction. Some of the avaialable materials that can be printed may surprise you.
              Here are some images of a SketchUp Logo I had made: http://picasaweb.google.com/jim.foltz/Shapeways1?authkey=Gv1sRgCMbns9qi8q6q4QE&feat=directlink
              https://lh5.googleusercontent.com/_ogonR-k5OoM/S5xnA9rFyUI/AAAAAAAAPpg/8qX3lpOiPbw/s144/P1010217.JPG
                Jim
                I'm cutting this license plate sized piece today - hope it doesn't go haywire while I'm inside reading the forums...
                Chevelle Logo.skp
                  d12dozr
                  Jim, did you use only the full color sandstone for the SU icon?
                  http://goo.gl/f7ooYh
                    Jim
                    I had it made in 4 pieces using just the "White, Strong and Flexible" material (which at the time happened to be available in the colors I needed.)
                    I wanted to make the icon as a single piece using the full-color sandstone, but at the time I couldn't figure out how to get Shapeways to accept the textured model. I believe Shapeways has improved their .dae importer since then.
                      Jim
                      I jinxed myself - I went out to check and one of the axes had quit on me. 😠 Another piece for the scrap pile.
                        d12dozr
                        @jim said:
                        I had it made in 4 pieces using just the "White, String and Flexible" material (which at the time happened to be available in the colors I needed.)
                        Ah, gotcha...thank you!
                        • E
                          ericschimel
                          I have a homebuilt CNC machine that I made a while back. Right now I am only using it to cut 2D parts. My current workflow is to draw the parts in Sketchup, export them to DXF, then bring them into Vectric Cut2D. From there I can setup my toolpaths then I can dump the GCode right into Mach3 to actually run the router and cut my parts.
                          Error 404 (Not Found)!!1
                          (sketchup.google.com)
                          That is the design I made, and there is a video of it running in the description.
                          -Eric
                          http://plugin.sketchthis.net
                          Sketchup Kitchen Design Plugin
                          Custom Models
                          • B
                            Bertier
                            @tfdesign said:
                            ... adding a STL export option to SketchUp would be very useful for many
                            +1
                            • jbacusJ
                              jbacus
                              @bertier said:
                              +1
                              How would you use an STL export? And have you tried any of the existing STL export options for SketchUp, like CADspan?
                              "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
                              John Bacus
                              jbacus@sketchup.com
                                driven
                                so now my 2 cents worth,
                                a lot of the development of Sketchup for use in Cad/Cam workflows has come from the users of SU 'FREE', partly because it's their hobby, without Pro User deadlines etc...
                                when they took away native DXF import/export they cut off a major route to other software/hardware. So, firstly, I think that needs rectifying.
                                STL and X3D for 3D + SVG for 2D should also have native import/export support, with as many options as possible and/or be scriptable.
                                I feel these formats should be part of the free version where people have the time and inclination to really explore what can be done with SU-CAD/CAM.
                                I'll push the boat here and say Solid Tools should be fully functioning in 'free' to aid these pioneers...
                                • B
                                  Bertier
                                  Hi John
                                  indeed CADspan is in my plugin folder, but I am not going to order 3d prints from Colorado to be delivered in Brittany... think 100kgarages 3d printing !
                                  what I am thinking is that 3D printing is the obvious result for 3d modeling, not 2D printing ...
                                  what I draw in sketchup mainly is to build it.
                                  therefor, I believe it would make sense that *.STL is a native export format :
                                  as in SU8 : File --> Export --> 3D Model --> *.STL
                                  actually, I may be mistaking, STL as a 3rd party extension maybe not the best solution :
                                  would you / SU / Google create a SU native 3D printing file format, with the now growing market of 3d printing and the reducing cost of the equipment, that would set a standard, wouldn't it ?
                                  Eversince I've been using 3d modeling tools, I've been thinking digital 3D --> physical 3D
                                  unconference: https://sites.google.com/site/3dbasecamp2010/unconference-sessions/sketchup-for-3d-milling-printing-etc
                                  Bertier
                                    d12dozr
                                    jbacus,
                                    Have you seen this new format, AMF (Additive Manufacturing File Format), developed specifically for 3D printing? It may be worth taking a look at incorporating into Sketchup, article here. Groovy features like color info and multiple materials are able to be included...great for making color 3D prints of homes textured with multiple images 😄
                                    • B
                                      Bertier
                                      I was just about to mention that article... 😉
                                      *.amf will replace *.stl
                                      sounds great !
                                      all about it : http://creativemachines.cornell.edu/amf
                                      here is some more on this topic : copyright breach and 3d print : the new issue
                                      http://t.co/wE5Q2oO
                                      paste the link in google translate !)
                                      • jbacusJ
                                        jbacus
                                        DXF export was never a feature of free SketchUp.
                                        DXF import was removed from free SketchUp in v.8 and we focused our attention on the open COLLADA format for 3D asset exchange in the free product. I discussed that on our blog at length here.
                                        I think AMF looks interesting, and will keep an eye on it as it evolves. I don't think that STL is a panacea in the near term.
                                        John Bacus
                                        jbacus@sketchup.com
                                        • B
                                          Bertier
                                          go AMF ! 😉
                                          • piratebrianP
                                            piratebrian
                                            For 3d Carving, I am using the following process:
                                            SketchUp Pro ---> (export as IGES using IGES plugin) ---> MasterCam. --> Thermwood CNC
                                            For 2d Cutting with drawing based control of cutting depths and tool use:
                                            SketchUp Pro --> (export dxf) ---> Thermwood CNC
                                            Thermwood CNC's can accept DXF drawings where the drawing layer tells the G-code generator what to do.
                                            I wrote a Sketchup guide for my specific Thermwood CNC. Some information is applicable to other CNC's.
                                            http://sketchucation.com/forums/viewtopic.php?f=183&t=51468
                                            I hope it is of some help to people trying to navigate the software end of cnc machines.
