    How to divide a circle ?
    9 Posts 5 Posters 7.8k Views 5 Watching
    • E Offline
      erzane
      hi
      I would like to know how to divide a circle in equal points ?
      I would like to do this and I think I need to start be dividing one or 2 circles ?
      http://img402.imageshack.us/img402/3685/iuoizoiuzouiz.jpg
      http://img269.imageshack.us/img269/3308/sansre1copie.jpg
      thanks
      • charly2008C Offline
        charly2008
        Hi erzane,
        Select the circle and click the right mouse button to open the context menu. Select Divide. Drag the mouse right or left or enter a number in the VCB.
        Charly
        • E Offline
          erzane
          hi
          thanks for your reply
          I dont find the context menu.
          where is it pls ?
          I searched any menu of right click but didnt find ''divide''
            The context menu is the right click menu (called "context" because its content depends on what context you are using it in).
            If you draw a circle, simply right click on its perimeter (the edge) and there should be a divide item in your menu.
            • E Offline
              erzane
              thanks for drawing explanations charly, I didnt saw it before
              hi gaieus, thanks for reply
              so, I found the divide menu on right click menu now
              the problem was that I tryed to make it a to long time after making the circle
              it should be possible only just after creating the circle ( I m not sure but that's I saw)
              but, now after choosing the number of parts I pushed ''enter'' and nothing happends
              p.s. I'm using version 8 now
              • gillesG Offline
                gilles
                let say you want a circle with 31 divisions, select circle tool then type 31s hit enter
                or if you already have a circle, right clic the perimeter choose entity info then set 31s for the number of segments.
                if needed, right clic the perimeter choose explode the curve.
                • Rich O BrienR Online
                  Select circle tool
                  Type segment count
                  Draw circle
                  To change segment after drawing select the circle edge and in the Windows>Entity info dialogue box type segment count.
                  Have you tried array the gear teeth around the circles edges?
                  • E Offline
                    erzane
                    it doesn't work
                    if I type the number of parts directly when making circle it resize the circle as its circunference
                    other methods doesn't work to
                    p.s. I can go to entity menu it's ok and I can type the number I want
                    but it dont do anything on my circle, it stay the same
                    -dividing by ''right click'' and ''divide'' works but I dont see result
                    -dividing it across ''entity menu'' works to but I dont see any physical result on my circle
                    what charly caputed on screen I see well
                    sketchup shows me red parts etc... but after putting ok (enter) nothing appears
                    I m so confused
                    • E Offline
                      erzane
                      ok I see now
                      I understood how sketchup proceed
                      what I imagined is, after selecting parts of segments sketchup will creat a sort of cheese with all parts selected but I just see that I need make lines myself
                      so, now it's ok
                      I finaly created the form I wanted
                      http://img542.imageshack.us/img542/2315/capture01n.jpg
                      thanks !
