    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 312.9k Views 172 Watching
    • soloS Offline
      The "i" does not work for me, yes I'm an IE user.
      • EarthMoverE Offline
        EarthMover
        @robert111 said:
        good work earthmover
        but can you say how to increase the thickness ofr your ivy plz?
        Not really sure. I left all the settings as default and what you see was my first quick attempt. I did scale the foliage up a little but the vine itself is on default settings using the 0.6.2 beta build with imperial units.
        Content Creator at Skapeup
          driven
          Solo,
          oxer pointed out that it needs to be
          key == 73 on PC's and key ==105 on Mac's
          but it was changed to that for 6.0.2 so if your using 6.0.2 then maybe 73 is the spanish keycode for i.
          I don't have a PC to check.
          you can change line number 69 in Liveivy_tool.rb to whatever you know works, it was 82 for [r]...
          Also it was previously on line number 73, so maybe there was a typo...
            driven
            hi all,
            I should have at least tweaked the current version... ahhh
            the <h4> headers need to be tweaked as well to be bold and centered
            <span style="margin-left; 50%; font-weight;900" class="label">Branch</span>
            NB: this may just be for safari...
            0.6.2
              driven
              hi
              sorry if the 'i' caused havoc for IE users,
              maybe someone can see if this breaks anything first,
              the formating in the main.html is broken in safari, which makes it hard to change settings.
              it's easily fixed by adding breaks between the list items, but I'm not sure what that does in IE...
              this may be just a safari thing,,,
              also can show_modal for mac return, I use a snippet I nicked that I believe works for both
              snippet REMOVED not working properly, will investigate???
              great work
              • sadyoS Offline
                sadyo
                Nice Plugin,but just for the report...
                When i trying v0.6.2,
                All feature inside Parameters it seem appearing and worked properly.
                Ctrl+click and Alt+click worked fine
                But when i try shift+click, nothing happen, so i cannot see the leaf 😢
                I Hope this problem would be solved on the next release
                Thanks in advance
                I,m Using SU 8 M1 Pro and Win7 64bit
                • rodrigonotorR Offline
                  rodrigonotor
                  Hi, i want to say: great plugin!, I try it and this is the result:
                  http://img846.imageshack.us/img846/6592/ivyz.jpg
                  Also, I translate to spanish, here are the file, only rename to main.html
                  Me he tomado la libertad de traducirlo al español, solo hay que renombrar el archivo a main.html
                  main_es.rar
                  • Sketchando.net • www.arqcad.net •
                  • srxS Offline
                    srx
                    When I start SU it begins with this:
                    Error Loading File LiveIvy.rb
                    Can't insert empty component.
                    This is solved with replacing version 8 leaf components with version 7 in Textures folder...
                    but still not working:
                    Error: #<NoMethodError: undefined method -' for nil:NilClass> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:241:in birth_stem'
                    C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in each' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:234:in birth_stem'
                    C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:223:in birth' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/LiveIvy/LiveIvy_tool.rb:99:in onLButtonDown'
                    www.saurus.rs
                      @pierreden said:
                      (face.classify_point seems buggy)
                      What issues do you have with this method?
                        Pierreden
                        Thanks for all comments, kind words, crits and suggestions! Uploaded a new version 0.6.3 and tries to solve a number of issues and suggestions.
                        @Earthmover: BRILLIANT! I guess this goes for everyone, but if you got some nice looking leafs, flowers or Ivy'ish stuff, im more than willing to include it in the releases (or maybe organize it somehow, website?) 💭
                        @driven: Added the breaks in the html. Hope this is better for all mac users. Added formatting to h4 headings 🤓
                        @driven/solo: I can confirm that i is 73 (thats on my scandinavian keyboard). Added 105 to the "reset ivy" key mapping on advice from you guys 👍
                        @sadyo: The tool code is rewritten (after shameless spying on thomthoms Selection_toys code. Hopefully i handle mouse events right this time 😒 )
                        @Rodrigonotor: awesome! Will include this soon.
                        @srx: Thank you! The components have now been switched with SU 7 components. Hopefulle this works!
                        @thomthom: I guess its expected behaviour, but if you try to classify a point on a face which is inside a group, the point is classified as not on the face. The result is this.The second problem is that some branches in the plugin sometimes manage to "break through" faces. Im not sure if this is a classify_point issue. or plugin algorithm which sometimes break, but cant solve the problem 100%.
                          Have you taken into account the transformation of the group? If you pick a point on a face inside a group you get a point for the current context, and then you need to apply the transformation for the group(s) which the face is within.
                          For handling Shift, Ctrl etc?
                          I think you might want check a more recent plugin, like Select Curve: http://forums.sketchucation.com/viewtopic.php?t=31091
                          I'm not sure if Selection Toys does it 100% correct. I can have a look in the code and compare against Vertex Tools (which I have tested on Windows and OSX).
                            Pierreden
                            No I haven't. If i make a single face and grows an ivy on it, without grouping the face first, there's no problem at all. But if i group the face before growing an ivy on it, adhesion doesn't work, a consequence of classify_point not returning 1. Unless a transformation is applied to a group by the very act of grouping, transformations itself cant explain this behaviour.
                            Can it be that Sketchup interprets this situation as if the point not being on the face itself, but "on" the group? ❓
                            PM 👍
                              I couldn't find classify_point anywhere in the code... not in the current version?
                              How do you obtain the point you test against classify_point, an InputPoint?
                                Pierreden
                                Look in livevector_core.rb. line 187.
                                classify_point is used to find the closest face to a new node on a branch, so the points tested against classify_point is the last point on each branch.
                                  When you test your point against a face nested inside groups/faces you must trasnform that point to the co-ordinates of the face's containing face.
                                  So if you have a face nested inside a Group1 > ComponentInstance1 > Face, then you must add up the transformation of Group1 and ComponentInstance1 and apply that to the point to send to face.classify point.
                                    Pierreden
                                    Thank you, get it! But i dont understand what transformations are applied to a new group (aka what happens when you group entities)?
                                      When you group, or make a component, out of existing entities they get their own local co-ordinates within the new group/component. (Within the ComponentDefinition)
                                      The group/component is inserted at the bottom front left corner of the boundingbox of the selected entities. To the grouped entities, this point becomes [0,0,0].
                                      (Though, when you add a group via Ruby API I think the group's origin is set to the current context's origin.)
                                        EarthMover
                                        Here is an English Ivy leaf that works well.
                                        • leedeeteeL Offline
                                          leedeetee
                                          This is probably a ridiculously stupied question but how do I get the ivy leafs to actually show up?! What am I doing wrong?!
                                            EarthMover
                                            CTRL click to bring up the red "+" symbols to indicate where the leaves will go and then SHIFT click to apply and create the leaves.
                                            Instructions are in the last section of the User Interface.
                                            • 36
                                            • 37
                                            • 8 / 37
