    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
    • fredo6F Offline
      These bugsplats may be related to the fact that when you copy a group, it behaves as a component until it is edited or modified. Normally FredoScale makes them unique, but there may be problem for these type of copy-cat groups.
      Also, having the outliner open is usually not recommended, especially with version 6 and 7.
      fredo
        mac1
        Thanks fredo
        I heed the previous warnings and roll it up before doing any thing.
        It appears I am at 2.0i so will update and look for diff
        Update: 2.1a gives same result
          tulacong
          http://forums.sketchucation.com/download/file.php?id=49290
          With FredoScale 2.1 you can orientate the selection box around a set of objects and interactively apply a number of geometric transformations, such as Scaling, Tapering, Stretching, Plane Shear, Twisting, Bending and Rotation. By extension, some transformation can be done without a selection box.
          [attachment=4:3vnwzr1a]<!-- ia4 -->FredoScale%202.jpg<!-- ia4 -->[/attachment:3vnwzr1a]
          http://forums.sketchucation.com/download/file.php?id=49286
          [attachment=2:3vnwzr1a]<!-- ia2 -->FredoScale User Manual - English - v2.0 - 28 Mar 09.pdf<!-- ia2 -->[/attachment:3vnwzr1a]
          [attachment=3:3vnwzr1a]<!-- ia3 -->FredoScale User Manual - French - v2.0 - 28 Mar 09.pdf<!-- ia3 -->[/attachment:3vnwzr1a]
          • Language: English, French, Spanish, German, Italian, Japanese, Korean, Chinese, German (thanks to all kind translators)
          • Menus: by default, it is installed in Tools > Fredo6 Collection > FredoScale
          • Icon toolbar: by Default ‘FredoScale’. many icons are available, but you can configure which ones to display (menu Default Parameters…)
          • The plugin is free, for private and commercial usage. There is a donation menu however.
          http://forums.sketchucation.com/download/file.php?id=49287
          1. Download and Open the archive
          2. Select All (Ctrl A)
          3. Extract into the Sketchup Plugin Directory
          4. Answer YES to overwrite all existing files if any
          The footprint in the SU Plugin Directory must be:
          [attachment=1:3vnwzr1a]<!-- ia1 -->Fredoscale 2.1 footprint.jpg<!-- ia1 -->[/attachment:3vnwzr1a]
          On Mac the SU plugin directory should be:
          Macintosh HD/Library/Application Support/Google SketchUp 8/SketchUp/plugins
          CAUTION: NEVER rename or move files from their folders. If you are unsure of your unzip operation, do it in a neutral folder and check that you reconstruct the right footprint. Then transfer the folders and files to the SU Plugin Directory.
          http://forums.sketchucation.com/download/file.php?id=49285
          DOWNLOAD FredoScale 2.1a – 12 Jan 11
          [attachment=0:3vnwzr1a]<!-- ia0 -->FredoScale 2.1a.zip<!-- ia0 -->[/attachment:3vnwzr1a]
          IMPORTANT: Requires to download LibFredo6 3.6 or higher if not already installed.
          http://forums.sketchucation.com/download/file.php?id=49284
          [flash=425,344:3vnwzr1a]http://www.youtube.com/v/WN-nV5VsoRY&hl[/flash:3vnwzr1a]
          [flash=425,344:3vnwzr1a]http://www.youtube.com/v/bPbb8PPGtVg&hl[/flash:3vnwzr1a]
          Pour les utilisateurs francais voir aussi l’excellente video de Laurent Brixius
          http://www.arch-image.com/wordpress/2010/04/06/plugin-sketchup-fredoscale/
          http://forums.sketchucation.com/download/file.php?id=49288
          • Select one or several objects (faces, edges, groups or components)
          • Click on the icon of one tool, for instance Scaling
          • You can orientate the selection box:
          • Arrow Upwill align on model axes
          • Arrow Leftand Arrow Rightwill cycle through axes of components at highest level
          • Arrow Downwill restore the initial alignment when selecting
          • Gently click and drag on the handles to perform the deformation. Toggle the CTRL key to perform the deformation from the center.
          • You can type relevant values in the VCB or via a dialog box (TAB key)
          • For Twist and Bend, F4 toggles a Slicer on and off
          • For Stretch, F4 toggles a Divider on and off
          • It is a good idea to check the contextual menu to see available options
          http://forums.sketchucation.com/download/file.php?id=49289
          FredoScale 2.1a - 12 Jan 11: Technical update along with LibFredo6, with two-phase loading. No functional change, but it is advised to upgrade for support.
          FredoScale 2.0i - 08 Apr 10: Same as 2.0h, but includes the Chinese translation.
          FredoScale 2.0h - 26 Nov 09: Stable version
          verygood thanks
          • fredo6F Offline
            @mac1 said:
            Thanks fredo
            I can reproduce the bugsplat.
            This seems definitely related to the question of Groups behaving as components when copied and not edited yet.
            I think I can do something about.
            Just in case, FredoScale includes a commande MakeUnique (icone as a 1) which applies a make unique to groups and components recursively.
            • I Offline
              ivreich
              Hi Fredo
              Thanks for this great set of tools.
              One suggestion- would it be possible to add a "uniform deformation" checkbox to the box dimension dialog box so that you can scale uniformly to a specific dimension? I can't seem to get uniform deformation when using "scale to targets" or while using the dimension dialog box, even when toggling the shift key.
              Cheers
              joel
                rock1
                great plugin fredo!. I'm really amazed by this plugin !! I found fredoscale very useful. 👍 👍
                Signature removed by SCF Admin
                  dedmin
                  • fredo6F Offline
                    @dedmin said:
                    Do you have the model.
                    The bugsplat in mirroring seems to be related to the question of unique component (again).
                      dedmin
                      BC1D1S1D.skp
                        karros
                        Found this thread (and forum) by chance while looking for some answers on google. Plugin works great, thank you!!!
                          Designmark
                          Thanks Fredo,
                          Downloaded FredoScale today, it's fantastic!!
                          I really appreciate this plugin.
                          Kind regards,
                          Mark.(Newby)
                            merlin7777777
                            I'm getting this error when i start SU (v 8):
                            Error Loading File bootstrap_FredoScale.rb
                            (eval):1: uninitialized constant FredoScale::T6Error Loading File ZLoader__FredoScale.rb
                            no such file to load -- LibFredo6.rbError Loading File __loader.rb
                            uninitialized constant Traductor::Plugin
                            I'm fairly certain the directory structure is as you specify. I extracted the files from the subfolders into their own folders as specified but I also extracted those files to the plugin directory just in case.
                            any thoughts?
                              Jim
                              Did you install LibFredo6, as the instructions say? It's required to run most of Fredo's plugins.
                                merlin7777777
                                ah - no. can't see that info in the OP. can you direct me where to go for it?
                                  • gillesG Offline
                                    gilles
                                    I am trying to bend a profile with precision, let say a 4000mm radius bend at 90°.
                                    the only way I found to do this is to first calculate the length of the arc: PI2000, then use the bend tool and type 6283,20 (PI2000) and bend 90°.
                                    Could it be possible to just type the desired radius in VCB ?
                                      merlin7777777
                                      OK - added the fredo6, all works ok except still egtting this error on startup:
                                      Maybe something to do with the double extraction I did?
                                        To be sure it isn't, why don't you remove anything to do with FredoScale and LibFredo and reinstall them so you know they are installed correctly.
                                        • fredo6F Offline
                                          Do you use Plugin Organizer?
                                          Another user had the same problem, which can be solved by setting Excluded Directories.
                                          • dereiD Offline
                                            derei
                                            Hello, Can I use "Stretching with orientation of scaling box" with absolute value? It seems that it works only with scale ratio.
                                            It would be nice to work like SketchUp native scale tool (where is you scale and input 500mm, it will scale the object to have 1000mm on the scaling axis. Or to scale the object adding a certain value more (example: +50mm).
                                            Thanks.
                                            • 56
                                            • 57
                                            • 2 / 57
