    Good Dynamic Component Examples
    Scheduled Pinned Locked Moved Dynamic Components
    13 Posts 6 Posters 7.8k Views 6 Watching
    • H
      Howard leslie
      Saladyne,
      After a quick look at the DC you posted.....
      Your DC Door looks pretty good to me - especially the different door styles. πŸ‘
      You'll have to decide if the following are any good or not as DC examples for your purposes, but some DC's I've created can be found right here on this very forum:
      DC Door Builder
      http://forums.sketchucation.com/viewtopic.php?f=289&t=21350
      DC StairCase Builder:
      http://forums.sketchucation.com/viewtopic.php?f=289&t=18545
      DC SpiralStairCase Builder:
      http://forums.sketchucation.com/viewtopic.php?f=289&t=29484
      Plus a few more - do a search in Dynamic Components Area.
      ... DC Resources ...
      As mentioned by others in this thread, DCs are poorly documented and development hasn't really changed since they were initially introduced. This is a shame because they are REALLY useful.
      Some DC info that I've used and found helpful:
      SketchUp 7 Guide (PDF) DC Development Chapter Pages 441 - 473. Download from Google SketchUp Official Website. Hopefully this chapter is still in the new Version 8 PDF Manual. Reasonable info in this Chapter. Well worth a read.
      DC Component Functions:
      http://sketchup.google.com/support/bin/answer.py?hl=en&answer=108144
      DC Reference Area:
      http://sketchup.google.com/support/bin/answer.py?hl=en&answer=115545
      And of course, this forum !
      Hope this Helps
      Regards
      Howard L'
        Saladyne
        Howard - Brilliant, thanks! This is just what I need. It's frustrating that I didn't find your models in my initial searches - but clearly I should have posted on this forum sooner!!!
        Your stairs look fantastic - I'll certainly have a look at those in more detail.
        Many thanks, S
          Saladyne
          Many thanks, Jason and Jaxcoffee, for your responses.
          I've been careful how I download/insert components and a number of DC authors mention your point, Jason, in the component descriptions.
          I'm just puzzled that door components like this; http://sketchup.google.com/3dwarehouse/details?mid=7bab89bf893fd435de650492e45fb14f&prevstart=0 are put forward as examples by 'Google' - the downloaded scale is weird, the handle position is very high and doesn't relocate to the edge when the door width is reduced (the handle can actually end up on the same side as the hinge on a narrow door), but worst of all the door opens into the door frame! Surely this is a component in urgent need of an update and not a good example for anyone?
          Jaxcoffee - It seemed a bit too big a step to learn Ruby and then try writing a Ruby Script for a simple door, but I take your point that Ruby is much more flexible... maybe that's where I need to go; especially as getting good quality info about creating DCs is proving tricky.
          Best regards, S
            Saladyne
            After playing about a bit with DC's I've managed to update my door componentDoorway03x.skpso it's a bit more flexible (still metric I'm afraid). You can now click on the frame to change its appearance and I've tidied up the facing detail to hide the part edges. Imperial version next!
            • jason_marantoJ
              jason_maranto
              Looks very good πŸ‘
              Best,
              Jason.
              • H
                Howard leslie
                Saladyne,
                Your new improved DC looks OK
                A few Observations and Notes on DC quirks:
                You don't have to design both metric and imperial versions (Good news !!!)
                ........ Flexible Units .................
                In the Component Attributes Design Area......
                I would NOT recommend using list boxes (dropdown menus) for user entered lengths / widths etc eg sizes such as door widths, heights etc eg for the Attribute LenY. (Not flexible for either you designing DCs or for your users).
                Instead consider using settings as follows:
                Units: Centimetres (Always pick this if you are UK / European - its very confusing !!! It doesn't mean your final DC Units are cm !!! NOT a good part of DCs)
                Display Rule: Users Edit Text Box
                Display Label: <Anything>
                *** Display in: End users model Units *** <do this for all your user entered attributes>
                Now users can use any units they wish - no need for you to make 2 DCs ie will work for American and European users no problem.
                ... Referencing Attributes - Relatively ............
                You can use Parent!LenY for example to reference an attribute in a parent group or component (ie a relative referencing system can be used as opposed to an absolute referencing system).
                Unfortunately you can't use Parent!Parent!LenY for a more deeply nested component. (2 levels down).
                Parent! is useful because if you rename groups / components etc it still works.
                Hope this helps
                Regards
                Howard L'
                  jster
                  I'm new to components; I'm using version 8 pro. I'd like to make both doors and windows that cut through dual-sided walls. I think that's what your multi-door is designed to do, however, it looks like it is a 2-step process, i.e., place the multi-door component, then the doorBack component. Is there any way to combine them into a single component that can be placed on a wall that corresponds to their combined thickness (in a single step)? Pardon me if this solution is described in this thread - I'm just not "gettin' it" so far.
                  Thanks!!
                  Saladyne,
                  Hope this helps
                  Regards
                  Howard L'
                    Saladyne
                    Hi jster
                    I've been pretty busy so I haven't been able to update my components following Howard's very helpful input; hopefully sometime soon!
                    I initially tried to create a component that would cut the two wall planes in one go but as far as I can tell this is just not possible. Which is why I created the 'Front' and 'Back' door components; not ideal but better, I think, than forming an opening and placing a simple door component.
                    I had to orientate both the 'Front' and 'Back' components around the same 'lengthwise' start point so that, once placed, so long as you change the size of the opening on both components the opening stays aligned. The specific sizes were to suit 'standard' British door sizes but I can see this won't suit everyone so I'm planning a suite of components from very simple openings (with variable input) to more complex specific 'real world' door sizes and types. Not sure when I'll get around to uploading all these - soon I hope!
                    Hope this helps, S.
                      jster
                      @saladyne said:
                      Hi jster
                      Hope this helps, S.
                      Hi Saladyne,
                      Thanks for the reply... Very helpful information.
                      Not being able to configure a component to cut into a 2 sided wall is a very unfortunate limitation indeed (very surprising, actually). I'll keep looking around - if I find anything I'll let you know. Until then, your 2-step solution will have to do.
                      Cheers,
                      j.
                      • fionmacoolF
                        fionmacool
                        [quote="Saladyne"] I've created a fairly simple dynamic door called 'Door Multi' (search under BaxStudio), also attached. Also it was created on the PC version of Sketchup 8 so I don't know if it will work properly on a Mac. Any positive criticism/feedback would be gratefully received. And links to 'good' examples of Dynamic Components would be greatly appreciated!
                        Hey thanks for a great component. I have just checked it out on my Mac and it seems to work fine. Its great to see a component that not only works well but looks great as well. I love Google but the components they come up with like doors, windows etc. are fairly lame. I have uploaded a DC called "block wall"
                        Bitly | Page Not Found | 404
                        (bit.ly)
                        See what you think of it. Its not perfect and anyone who would like to improve it I would be delighted to share credit- would love to partner up with people who want to make DCs commercially. Any takers?
                        Zere are still some architectes zat do not know ow to use ze SketchUp..... Zis is unbelievable....
