    How would I model this bridge?
    12 Posts 5 Posters 1.1k Views 5 Watching
      tallbridgeguy
      This the new Calgary Peace pedestrian bridge by Santiago Calatrava. It is scheduled to open this summer.
      How would I model something like this?
      Thanks for the help!
      S
      http://www.cbc.ca/gfx/images/news/photos/2009/07/28/cgy-peace-bridge-full-size.jpg
      The video is also cool and well done.
      http://www.youtube.com/watch?v=8HvaOo0wtL4
      Nielsen
      http://www.tallbridgeguy.com/
        Jim
        That reminded me of this tutorial: Modeling a Carbon Nanotube
        • numbthumbN Offline
          numbthumb
          TIGΒ΄s Lattice Maker? http://forums.sketchucation.com/viewtopic.php?f=323&t=28223&hilit=plugin
          Comfortably numb...
            Four seasons πŸ‘
            • jeff hammondJ Offline
              there's a lot more to it than what i've shown but here's a rough idea to get started with the skeleton..
              it seems like a sweet bridge to draw but it's going to be a lot more work than i've shown here and/or have time to commit right now.
              bridge_shell_rough.skp
              [edit -- oops.. the step that says 'note side extension' --- the first part of that step is to push/pull the 1/2 cylinder up which surfaces everything.. then the middle faces are just selected/deleted.]
              good luck
                tallbridgeguy
                Thanks, I will take a look at both threads!
                The first video link is kinda choppy. Here is a slightly lower grade but more watchable version of the video.
                s
                Nielsen
                  tallbridgeguy
                  Wow, thanks for the file Jeff!
                  I doubt I would have thought of doing it that way. (I probably would draw a cylinder and try to draw on the surface.)
                  S
                  Nielsen
                    i went ahead and modeled a lot more of this thing today.. i have a modified version as well which has a slight arch when assembled but i figure since i'm going to upload it here, i'll provide the straight version in case someone newer to sketchup wants to move all the pieces around and see how components etc. work without the need to align little angles..
                    still missing some details (and i just made up some of the details in this version) but i'm over it πŸ˜„
                    footbridge_jh.skp
                    click pic for bigger
                      Cool adaptation β˜€
                        tallbridgeguy
                        Wow! πŸ‘
                        The downside is now I feel pretty inferior! πŸ’š
                        s
                        Nielsen
                          @tallbridgeguy said:
                          Wow! πŸ‘
                          s
                          nah.. most of it is pretty straightforward modeling.. the two things that took a little figuring out was how to get the cutout squares on the cylinder to have rounded corners and how to make the beaded edge on the ends where the cylinder is cut off..
                          i came up with some pretty simple solutions for both so if you have any problems modeling those parts, i'll give you some ideas on how to handle it..
                            tallbridgeguy
                            Thanks Jeff! πŸ˜„
                            Nielsen
