    [Plugin] SectionCutFace
    569 Posts 171 Posters 541.1k Views 170 Watching
    • F
      function
      poche is finally my friend
      thanks tig! β˜€
      • JClementsJ
        JClements
        TIG, 2.5 works fine here. Thank you.
        POSSIBLE ENHANCEMENT:
        A way to toggle the visibility of the the SU Section Cuts and the visibility of its SectionCutFace geometry automatically.
        Advantage would be to eliminate the need for the user of digging into nested sections, turning on and off section plane display, selecting a different section plane, turning on and off its active mode, etc.
        Scenario: User goes to the Outliner, searches for "CUT.", clicks on a SectionCutFace group, right-clicks for A context menu and has a choice to toggle the visibility. If the SectionCutFace geometry is visible then it is hidden (if it is locked, it is unlocked) and the SU Section Cut associated with it is no longer active and vice versa if the SectionCutFace is not visible. Possibly a warning (or a listing of other SectionCutFaces) if there is more than one SU Section Plane in the active context when activating an SU Section Cut?
        I guess for something like this to work, there would have to be someway (when the SectionCutFace geometry is created) to associate the internal object number assign to it by SU with that of the SU Section Plane.
        John
        • Z
          zaibatsu
          thanks!! you just save me a lot of precious time filling the spaces in photoshop!!!
          • I
            iPO2
            I like this plugin because it is stable πŸ˜„ had no crashes so far. Only when I tried to render with twilightrender inside SU everything rendered like a whole model without cut. Is there a possibility to render a cut model with filled faces?
            • GaieusG
              You also need to cut the "rest" of your model away with Zorro 2 (which writes itself into the section plane context menu).
              Note however that it will irreversibly modify your model so always only work on a copy or make a backup before.
              These are Twilight renders made this way:
              https://lh6.googleusercontent.com/_zcvsIuYiVbo/S9albKtTOwI/AAAAAAAAEBs/4Ui-2vCOve8/Bazilika_Metszet0000.jpg
              https://lh6.googleusercontent.com/_zcvsIuYiVbo/S9albxTYWtI/AAAAAAAAEB0/AjFAo3QTj9s/Bazilika_Metszet0001_hatter.jpg
              https://lh6.googleusercontent.com/_zcvsIuYiVbo/S9alc410jLI/AAAAAAAAEB8/h6NT0b0y_Oo/Bazilika_Metszet2_hatter.jpg
              • I
                iPO2
                Thanks a lot,it helped me, now I'll use both plugins πŸ’š . It is the coolest feature in sketchup to be able to make pictures with section cuts.
                • C
                  cgomez73
                  I put the file in plugin folder and shows this error:
                  Error Loading File SectionCutFace.rb
                  C:/Program Files/Google/Google SketchUp 7/Plugins/SectionCutFace.rb:1: syntax error
                  <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
                  C:/Program Files/Google/Google SketchUp 7/Plugins/SectionCutFace.rb:2: syntax error
                  <html xmlns="http://www.w3.org/1999/xhtml" dir="ltr" lang="en-gb" xml:lang="en-gb">
                  what can i do?
                    what can i do?
                    That is NOT the real file!
                    Somewhere along the line you have saved the linking html code and not the .rb file itself πŸ˜•
                    None of that quoted text appears in the real script's file.
                    Have you successfully Ruby scripts before ?
                    You should be able to click on the link OR right-click context-menu 'Save_as' and then give it a path/name.
                    I'll PM'd you a zipped version. Download that zip file - hopefully it won't corrupt. Extract the .rb file from the zip and put the .rb file into the Plugins folder, replacing the corrupted version you have at the moment! Restart Sketchup to see if it works.
                      JGA
                      Thanks with continuing to develop this plugin -- it comes in very handy when needed.
                      Regards,
                      JGA
                      • bmikeB
                        bmike
                        Is there a way to alter the code so that one could limit the choices for solid fill color? I typically only use 3-4 colors in my models, depending on what I'm doing. I can leave it default, and change later, but it would be nice not to have the long list pop when I do want to switch.
                        I've looked at the code, see where the materials get called, but do not know enough to enter a list of specific options.
                          Find lines #424+:
                          colours = Sketchup::Color.names.join('|') cedges = colours ###v1.3 colours = "<Default>|<No_Face>|"+colours ###v1.3###v2.5
                          and change it thus:
                          colours = ["Red|Orange|Yellow|Green|Blue|Violet|Black|White|Gray|Brown|Pink"] cedges = colours ###v1.3 colours = "<Default>|<No_Face>|"+colours ###v1.3###v2.5
                          In the first line add whatever colors you want inside the [], inside "", always ensure there is a '|' separator between each of them as shown above - the full list of available colors is here http://code.google.com/apis/sketchup/docs/ourdoc/color.html#introduction - note the spelling must be as shown, e.g. 'gray' NOT 'grey' etc...
                          If you don't want the edges (cedges) to have the same color choices at the faces, then change the second line to be its own [] list.
                          If you don't want '<Default>' and/or '<No_Face>' options you can either put # in front of the third line to stop it loading completely, OR just remove the unwanted option - always ensure that there is a '|' separator between each of them and the rest of the colors.
                          Now later on... lines #430+
                          @@colour = Sketchup::Color.names[7] if not @@colour ### Black @@edge = Sketchup::Color.names[7] if not @@edge ### Black
                          To set the default color[s] in the dialog either work out which value to put instead of [7], remembering that the 1st item is [0] etc, and the 8th item is [7] - e.g. @@colour = colours[8] if not @@colour in the above example if the two '<>' options are also added to the colors list.
                          OR simply set it by its 'name' thus:
                          @@colour = "Black" if not @@colour
                          [that's always assuming that you have 'Black' in your color list!]
                          • bmikeB
                            bmike
                            Thanks TIG!
                            I'll look at this weekend. Big project to detail and move into LayOut next week for construction documents, so this will be helpful.
                            Yes, black is always in my model, usually my line color!
                            • G
                              gacevedo
                              Hi, just tried your plugin with zorro 2 with podium 2.5 running on sketchup 8, win64. It is a thing of beauty.
                                sam41145
                                Thanks TIG. πŸ’š
                                • P
                                  pablosyk14
                                  Very useful plugin. Thanks
                                    dragon999
                                    Thank you for sharing this ruby
                                    • pilgerP
                                      pilger
                                      Incredibly usefull plugin.
                                      I've found a very annoying bug on the new version on Sketchup 8 Pro though. It used to work great with the previous versions.
                                      It fails to create a new layer and move the group backwards a bit so it appears on the section view. I've tried several combinations of the plugin's preferences and all resulted in the same bug.
                                      Here's what i got on my ruby console window:
                                      Error; #<TypeError; reference to deleted Edge>
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;361;in `faces'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;361;in `initialize'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;359;in `each'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;359;in `initialize'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;358;in `times'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;358;in `initialize'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;476;in `new'
                                      C;/PROGRA~2/Google/GOOGLE~3/Plugins/SectionCutFace.rb;361;in `call'
                                        Can you try this [make a backup copy first outside of Plugins in case you mess up!]
                                        Edit the .rb file with Notepad or Notepad++, around line #360 there are these lines
                                           if e.class == Sketchup;;Edge and @@edges == "No" ###v2.2
                                              e.erase! if not e.faces[0]
                                           end #if
                                        change them to read
                                              e.erase! if e.valid? and not e.faces[0]
                                           end #if
                                        i.e. add in ' e.valid? and'
                                        The code should be OK as it was but this will make it more foolproof πŸ˜’
                                        Save it and retry - see if the error repeats - if not let me know and I'll issue an update, if it's still an issue can you post or PM me the SKP with the problem with a brief explanation and I'll try and see what's up... πŸ˜•
                                          Here's v2.6 http://forums.sketchucation.com/viewtopic.php?p=172583#p172583
                                          It now traps for potential rare bugs if it tries to erase an object that's already erased...
                                          [as recently raised by 'pilger']...
                                          • GaieusG
                                            Thanks TIG. I rarely use sections but when I do, I always use this plugin, too. I haven't encountered the bug you mentioned yet but it's always good to have the latest build of a plugin.
                                            πŸ‘
                                            • 28
                                            • 29
                                            • 4 / 29
