    Unable to save render i Vray for skp 8
    renderpluginsextensions
    3 Posts 3 Posters 3.4k Views 3 Watching
      Pelle Pelle
      Im having some problems saving my finished renders. I can enter the save dialoge by pressing the disc icon in the frame buffer. No problem nameing the file and choosing the output type, but nothing gets saved when I press save. Dosent matter what filetype I use, same result, nothing gets saved.
      If I try to presave the image in the output option Sketchup crashes after some time, but before it starts the render.
      The file is 12 mb and an external view of some buildings for a project, and my company hardware is tip top.
      Sketchup 8 Pro v. 8.0.48.11
      Vray 1.48.89
      Any advice on how to save my final render?
      Thanks - Peter
        ledisnomad
        Hi, Pelle Pelle. I once had that same problem and the solution was quite simple: upgrade VRay from 1.48 to 1.49! (I don't remember if it was 1.48.89 exactly...)
        I don't know what the problem was, so if you were looking for a solution or a work-around, I can't help. However, having had that problem, I'd guess it was a bug in that particular version.
        • pyrolunaP Offline
          pyroluna
          you could try pre-saving in the options -> output panel
