    Help With Export
    layout
    18 Posts 6 Posters 2.9k Views 6 Watching
    • O
      Otis
      Thanks for the quick replys.
      Dedmim, I could not seem to find size page I needed, where do you find a poster size page? Not sure what references you refer to that are missing. I downloaded it and once I zoomed out I could see the entire poster.
      Anssi, I downloaded your file but all I get is a could not render warning.
      I've never been succesful at exporting a full size templet and would dearly love to as it's something I could use in shop on a daily basis.
      • O
        Otis
        OK, went back and found the size I needed (Ad 24x36) and exported it as a pdf, but when it opened I only get a partial of the circle picture and the background has changed from yellow to black.
        • GaieusG
          There are two places to set it:
          • your template that you can control/modify under File > Document setup > Paper
          • and the actual paper size you want to print it on under File > Print setup.
          • O
            Otis
            Thanks Gaieus,
            The first part I figured out.
            The second part, I have page setup instead of print setup. Under that I have no 24x36 page size, I assume because my printer does not print to that size, ergo the reason I wish to take the file to Kinkos to have them do it. The problem is how to do that.
            • GaieusG
              OK, Page setup, true.
              I don't know... I have a printer installed that can only print A4 but I can set the page up to A0 (that would be 5 times larger)
              • O
                Otis
                Went back to "page setup" to triple check just in case I missed something. I have every option for index cards and photos known to man, but nothing approaching 24x36. Is it a function of my personal printer, or is this the options that came with LO ? If LO, how can I get the bigger sizes so I can make this work? If my printer, do I need to go buy another one just to get the size options ? I have HP Deskjet 5600 currently installed.
                • GaieusG
                  I also have PDFCreator installed. It installs in the system as a virtual printer, maybe try to install it, too:
                  http://sourceforge.net/projects/pdfcreator/
                  • O
                    Otis
                    I have the PDFCreator installed already, and it's a go. Thanks for the suggestion ! Worked perfectly, now if I can only remember it next time I need to do something similar.
                    • O
                      Otis
                      Uh oh, spoke too soon. When I convert to a pdf I get this crosshatch of lines dividing the poster into ten or so squares. What can I do to rid these lines. I have no idea where they came from as I don't have them in the LO file.
                        Slimdog
                        You probably have the grid turned on to print.
                        Go to file/document set up/grid. At the bottom there are options to print the grid or not.
                        • O
                          Otis
                          Slimdog,
                          It's not the grid setting. That's the first thing I checked. The grid is in 24 equal squares though on the pdf. I'm still baffled.
                            jhauswirth
                            Does it not work using the native File->Export->PDF (I assume you're seeing this problem with PDFCreator)?
                            • AnssiA
                              Anssi
                              John,Otis,
                              The file I posted was exported directly from LayOut. For some reason Otis has difficulties opening it - it opens OK in my Adobe Acrobat 9. File>Properties says that it is a version 7 file, so it seems that LO export into that. What version of Adobe Viewer are you using?
                              Anssi
                              • O
                                Otis
                                Yes, it does it as well in the native file-pdf method as well. When I export it as image it appears ok. I don't know if they can print the poster from such a file or not. Will ask them tomorrow.
                                • O
                                  Otis
                                  Hi Anssi,
                                  I looked and it says Adobe reader 9.
