    [Plugin] Curve Maker v1.2.2 - 7 March 2011
    25 Posts 14 Posters 34.2k Views 14 Watching
    • JClementsJ Offline
      JClements
      I must have overlooked this. Thanks for the quick reply.
      • dereiD Offline
        derei
        Please help!
        I need to draw a Archimedes Spiral with this specs:
        inner radius: 15mm
        turns: 5
        distance between turns: 2mm
        I got the options panel attached here, but I get lost in it.
        What should I input there to have the desired result?
        DESIGNER AND ARTIST DEREI.UK
        • dereiD Offline
          derei
          ERROR !
          After using the plugin several times, I can't use it anymore. Every time I click OK on Parameters input box, it reappears. No error message, no error in Ruby console. It's a loop. Dialog disappear then is back... and so on.
          EDIT: -it happened in the model I was working in. It didn't fixed after close and open. But in new model it worked. It seems that something that was saved inside the model while using the plugin, caused the bug.
            max-cx
            Is this what you are trying to draw?
            Terry
            http://www.drawmetal.com
              max-cx
              The most likely reason the dialog box keeps reappearing is that you have not entered a valid point for the curve origin. SU will not accept a ~ in any coordinate in a point - each value needs to be exact. The plugin could be friendlier in this regard.
              Terry
              • dereiD Offline
                derei
                Indeed I selected a guidepoint and its coordinate was with ~ . And the worse part was that if unselected it, hoping that the spiral to appear on origin, the previous value was retained in the inputbox, so I was triked again by the plugin. Maybe some fixes on that?
                And yes, that is what I wanted to draw... after some trials and errors I got it (about one hour of playing). But I did it in a different manner, I don't know if that was the correct approach, or yours... I just changed the values until I noticed a pattern πŸ’š.
                I still don't fully understand what are all that fields in inputbox. So many radii, turns, first turns, second turns... i'm dizzy 😲 . I tried to find the answer in the manual, but I couldn't.
                  max-cx
                  By design, the plugin remembers the previous inputs - including erroneous ones.
                  Perhaps the interactive versions of these tools will be more to your liking. Have you tried the Curve Maker sub-menu on the Draw menu? They might also help you understand what the dialog boxes are prompting for and the additional degrees of control that the dialogs offer.
                  Terry
                    max-cx
                    The Curve Maker plugin has been updated. It can be downloaded from http://www.drawmetal.com/download
                    Given the current Length Units Format, if a guide point coordinate's value can only be approximated (i.e. it displays with ~), then Curve Maker will now display the coordinate value as a decimal length. This should mitigate the problem that dereeei experienced with the curve origin field in the input dialog.
                    Terry
                    • robertWanR Offline
                      robertWan
                      Does anybody have a version for SU 8?
                      The author doesn't.
                      Robert
                        JClements
                        Try the attached. Hopefully it contains all the required files.
                        ctsMaker.zip
                          robertWan
                          Thank you. πŸ˜„
                          Robert
                            swpuagui
                            Thank you so much!
                            • 2 / 2
