    [NEW]Sketchup 2 Vue
    extensions
    164 Posts 28 Posters 45.9k Views 28 Watching
    • KrisidiousK Offline
      Krisidious
      does anyone know how to make the buttons or toolbars smaller in Vue?
      By: Kristoff Rand
        d12dozr
        You can drag the right pane left/right to change its size, but the toolbars aren't adjustable. Alt+Enter will toggle full-screen if that helps...
        http://goo.gl/f7ooYh
        • Chris FullmerC Offline
          Hey, I finally made something in Vue that I thought was worth showing. I've finally got approval (after nearly 2 years of false starts) to buy VUE for the office, but for now I am still just playing with the PLE. So please forgive my watermarks.
          When I made the ecosystem and added the little rocks, I couldn't figure out a way to make them stick to the overhangs of the cliff. Any ideas how to make that work?
          • soloS Offline
            Chris, there are many ways to do it, the easiest would be to use the material brush in the terrain editor and define the areas where you want the various materials, see image.
            You can also control this using a mixed material and setting the influence and conditions in the material editor.
            Alternatively you can do it the slow but accurate way and use the 'paint ecosystem' option found in edit menu to hand paint where you want your grass and stones.
              Well, what I did was made that cliff as a matablob. And then I applied an eco system material to it that I made. But in making the material and adding the rock element to the ecosystem, I couldn't get the rock to adhere to an overhang. It seems that the material ecosystem forces objects to contraint to a slope somewherre between flat and perfectly vertical, and does not allow ecosystems to populate objects on slopes that are overhangs.
              I know I could just paint it on the overhang, but I really wanted it to be an automated population process because I clear it and re-populate it so many times through my process. I didn't want to have to keep repainting the overhang. Plus I was atempting to use a map to vary the density, so that the rocks would add themselves in seems throughout the mud, but I never could tell if it was working since they refused to populate ontot he overhangs. Oh well, unless you have a cure, I'm not that worried about it I suppose.
                d12dozr
                I noticed that this latest version of the exporter (Version 1.1) places the pivot point of all groups and components at the origin of the global axes in the Sketchup model. When I open the file in Vue and try to swap out imported proxies as described here, all of the plants are placed on top of each other at the origin. (Please see attached pictures)
                This bug is new to V 1.1 -- V 1.0 kept the pivot point of each component at the Component axes from Sketchup, which is the correct behavior. Its not a big deal for only a few plants, but if there are 20 or more precisely placed, then it becomes a problem.
                  dburdick
                  Hi Marcus,
                  This is the way Vue has always handled imported objects. I will check on this and see if there is a fix.
                  Regards,
                  Dave
                    d12dozr
                    @dburdick said:
                    Hi Marcus,
                    Regards,
                    Dave
                    That's weird, I believe it worked the way I needed when I first swapped proxies here (date 11/26/10, Version 1.0): http://forums.sketchucation.com/viewtopic.php?p=290374#p290374 I still have that file if comparison with the new one will help.
                    Pivots placed at component axes are also nice for animating imported objects - like vehicles - so that tires rotate correctly without lots of extra work.
                    Thanks, Dave!
                      samo8076
                      anybody else got any more renders to show using vue and sketchup? Im on the fence about getting the export plugin for sketchup and would like to see more renders etc to give me an idea whats achievable.
                        d12dozr
                        Search the forum for Solo's Vue renders...
                          Krisidious
                          here are some...
                          By: Kristoff Rand
                            ok, question. I don't fully understand displacement maps. Here's what I would like to do. I thought it was possible, but perhaps it is not.
                            I would like to have a simple shape, a cube, and apply one of the default displacement materials to it - limestone. But when I render it, the faces are all displaced, and the edges do not meet up. I had thought that UV mapping would somehow fix that so that the edges would know how to align with eachother and not leave large gaps between them.
                            Am I just trying to make this more simple than it really is? Do I need to do something special? I've never really noticed the gap between faces on other objects (olike a sphere for example). But when I do it on a cube, it always leaves a gap.
                            This image shows how the sphere seems to map and displace correctly, but the cubes are all lame. The cubes measure 5' x 5' x 3'. The cube on the left is a series of 1" faces (all triangles in VUE) and the cube on the right is a single face on each side of the cube. I applied a material to them in SketchUp and made sure it was aligned how I wanted it. I replaced that material with a displacement rock one in VUE.
                            So, what do I need to do? Let me have it, Thanks,
                              alpro
                              Hey Chris I don't have Vue so I don't know what options are available but I know displacement works best in other rendering apps if you sub-divide and smooth your model first and sometimes even slightly round the corners so they aren't that sharp.
                              Mike
                                perperilipio
                                Hi guys!
                                Just a simple question....I actually don“t know if is the right place to ask but....anyway
                                here it goes.....I“m a urban planning and as you know urban=huge massing=huge terrains=huge
                                vegetation areas.....I have always done my entire models with sketchup but most of the time
                                I have serious troubles with vegetation and landsacaping, because usually there are a lot of
                                it....and I usually use 2d face me components for landscaping, but there are not enough real
                                to present to some of our clients....so I“m wondering if Vue is a great solution and complent
                                for skethcup models?
                                I“m asking this in terms of rendering...becuase I“ve tried many render engines and not had great
                                results....so maybe VUE is what I“ve been looking for...
                                thns a lot!
                                  Krisidious
                                  @perperilipio said:
                                  Hi guys!
                                  thns a lot!
                                  exactly what you've been looking for... it's awesome. make your planning in SU and use simply proxies for vegetation and then replace them in Vue and get stunning realistic plants trees water and well you get the idea. try it, it's free.
                                  By: Kristoff Rand
                                    perperilipio
                                    wow!! that`s sound terrific!!!
                                    I'll give it a try and see what happend!
                                    thanks a lot!
                                    With your input, this post could be even better šŸ’—
                                    • 8 / 9
