    Plugin Idea
    11 Posts 6 Posters 1.2k Views 6 Watching
    • W
      wolfy
      Hello Plugin Gurus,
      I was wonderng if this exists or would be a good idea for a new plugin:
      The ability to hover over a group, hold a short cut key and be able to select a face or edge inside a nested group.
      This would save TONS of time clicking in and out of nested groups/components.
      Any takers?
      P.S. Thanks to all the scripters for your gracious plugins!!! They are much appreciated.
      • Didier BurD
        Didier Bur
        There's no way of 'entering' group editing from a ruby script AFAIK...
        DB
          You CAN tunnel down using a 'pick_helper' to find everything below the cursor at the click and filter the array of objects returned to find a particular thing or kind of thing even if its inside a group. I have recently written a customized tool to swap parts inside a DC, by picking them from outside the DC. It works.
          So you could have a tool parallel to the built-in 'Select' that does it...
          However, what would you want to do with the selected face/edge inside the group. Unless you are in a group edit mode you can't Erase/Move/etc them, unless you also have parallel tools to do these actions too on nested objects as well... πŸ˜•
          Didier is right - you can't go 'into' a group edit mode through 'code' [but you can step 'out' of an edit though...] - you must do a manual edit to make the groups entities the active_entities, BEFORE running any tool on those entities... unless you write a complex set of tools editing the internals of a group. My DC click editor is straightforward as the definition of the picked object [another DC] has to be the required 'type' and is swapped with the definition of a similar one in the code.
          • W
            wolfy
            Wow, quite an explanation TIG, thank you.
            I would find this operation most useful to texture or reverse faces inside a group/component.
            I often get CAD files that have tons of nested groups and I need to texture them or reverse their faces. I thought this kind of tool would speed up the process.
            BTW, what is a "pick_helper"?
              You don't really want to know!
              ...put very simplistically... part of a Tool's coding can spot when you click the mouse and a 'pick_helper' makes a list of what you might have picked below the cursor - there are various methods to pick just faces or edges, or 'everything' - then you need to sift through the list to find the kind of thing you want and decide if it's a match... e.g. you might click a face inside a component-instance, inside a component-instance, inside a component-instance - I my recent tool I look at the component instances and check if their definition has a certain attribute assigned to it - if so then I swap it for a similar [but different] definition...
              In your case... if you want to apply the front material to the back etc there are already tools to do that, mining down into the groups/instances... If you want to do it on a selection basis and apply different materials it gets unwieldy...
              Can you outline the exact steps you might do manually so I can think if it already exists, or if it is easy to sort out otherwise.... πŸ˜•
              For example my Fix Reversed Face Materials toolset 'mine' already...
              • GaieusG
                If you want to quickly reverse back faces "digging down" in nested elements, Tomasz already has a tool:
                http://forums.sketchucation.com/viewtopic.php?t=13380
                Just activate it an "paint" through the faces. The only drawback is that it reverses curved surfaces facet by facet (as if display hidden geometry were on).
                • W
                  wolfy
                  Hmmm thanks guys. The reverse face tool looks promising.
                  It seems like the only way to dig through nested groups and paint individual faces is by clicking through them.
                  I appreciate all the feedback!
                    You misunderstand...
                    Several of these tools WILL dig through nesting and fix ALL faces' materials front-v-back... πŸ˜•
                      dedmin
                      There is such a tool - I was hopping for a long time somebody to make a plugin
                      Place Material
                      Place Material uses an Explorer type tree to select materials and place them directly on faces without having to open components and groups for edit.
                      The tool β€œdrills” into the model to determine which face, (or component or group), to change to place the material.
                      http://www.renderplus.com/wk/RpTools_w.htm#Place_Material
                      • GaieusG
                        Since I almost always carefully position my materials as well, I really cannot imagine any plugin that would do it simplerfor me than to dig down 2 or three levels.
                        ThomThom's selection toys can also dig down to select things in nested groups/components and with that selection, you can also do some transformations (like moving/rotating for instance - which can be real fun sometimes) but to precisely do all this, I would rather try to access those entities in a more straightforward, native SU way.
                          Warning: Strange gremlins might appear in SketchUp if entities outside the current context is selected. User and developers beware.
