    Question about menu.add_item
    12 Posts 4 Posters 961 Views 4 Watching
    • W Offline
      wikii
      amenu=UI.menu("Plugins").add_submenu("Test")
      amenu.add_item("print 1"){print 1}
      I Run each line of the codes in Ruby Console , Only a submenu "Test" has been added in plugins menu."Print 1" does not show in the submenu "Test".
      If I save the codes in a rb file and load it in Ruby Console,submenu "Test" and "Print 1" will be shown correctly.
      why?
        sahi
        amenu=Ui.menu("Plugins").add_submenu("Test") - the script execute the command executed and the variable "amenu" - forgotten
        amenu=false
        We can do this
        amenu=Ui.menu("Plugins").add_submenu("Test")**;**amenu.add_item("print 1"){print 1}
        or so
        Ui.menu("Plugins").add_submenu("Test").add_item("print 1"){print 1}
        • W Offline
          wikii
          I just want to add all my plugins to one submenu.
          I use a global variable to store the submenu.but it does not work.
          Is there a way to add defferent plugins to one submenu?
            why?
            I've noticed this before as well. Dunno why. Some kind of bug.
            • TIGT Online
              Use
              $wikii_submenu=UI.menu("Plugins").add_submenu("Wikii")
              then later
              $wikii_submenu.add_item("Print 1"){print 1} $wikii_submenu.add_item("Print 2"){print 2}
              etc, should work...
              It works in the console because the $global is remembered.
              Also setting a global reference [$] for your actual tool means that as long as the .rb file making the submenu loads first [start its file name with a ! or ###], then other scripts can access the submenu and add items to it too - that's how I manage many of my main Plugins, using submenus 0 to 9 logically named and ordered to contain similar types of tools... Other stuff lives 'loose' in Plugins menu or wherever...
              Remember to use a $ name that's unlikely to be reused by some one else - e.g. $menu = bad idea as it could easily used by someone else, but $wikii_submenu likely to be 'uncommon'...
              • W Offline
                wikii
                @tig said:
                Use
                then later
                Thank you,TIG!
                But,it does not work when I copy it to Ruby Console line by line.
                Only "Wikii" has been added to plugins menu.
                "print 1" and "print 2" do not show.
                • TIGT Online
                  WikiiI see what you me - buggy...
                  However it WILL work when scripted...
                  • W Offline
                    wikii
                    I hope it works in different scritps,means that two scripts can add items to a same submenu.
                    • TIGT Online
                      I hope it works in different scripts, means that two scripts can add items to a same submenu.
                      It does work in different scripts, if you use a $ variable - I already use it like that...
                      • W Offline
                        wikii
                        I test these two file.
                        Only 1.rb work well,2.rb can't add item into the submenu.
                        load the first
                        then this one
                        • TIGT Online
                          They DO work....
                          BUT you have to let Sketchup auto-load them as it starts.
                          You can't push a new item into a submenu by manually loading script files later on, or typing the commands into the console.
                          If I put both of your .rb files into my Plugins folder and restart Sketchup then I get the ../Plugins/Wikii/ submenu with the two specified items added - each one created by their separate script using the $ global ref...
                          • W Offline
                            wikii
                            I see.
                            Thank you,Tig!
