    SU8 and scrambled plugins
    7 Posts 3 Posters 535 Views 3 Watching
    • sdmitchS Offline
      sdmitch
      Is there a problem with SU8 and scrambled plugins? I have downloaded the ruby script scrambler and have attempted to scramble and load several plugins I have created but none of them would load. Typically the errors or simuliar to these
      load 'c:/users/public/sketchup/plugins/face2face.rbs'
      Error: #<SyntaxError: (eval):0:in load': c:/users/public/sketchup/plugins/face2face.rbs:1: no .<digit> floating literal anymore; put 0 before dot RBS1.0... ^ c:/users/public/sketchup/plugins/face2face.rbs:1: syntax error, unexpected tINTEGER RBS1.0... ^ c:/users/public/sketchup/plugins/face2face.rbs:1: Invalid char \020' in expression>
      (eval)
      (eval):0
      http://sdmitch.blogspot.com/
        Without seeing your actual code...
        Do you have un-parenthesized arguments like-
        do_this 1, 2, 3
        Or if they are parenthesized, perhaps a gap like this-
        do_this (1, 2, 3)
        The currently correct method is-
        do_this(1, 2, 3)
        Also it says you have something like a decimal-number formatted as '.1' when '0.1' is required ?
        πŸ˜•
        • sdmitchS Offline
          sdmitch
          Tig, As far as I have been able to determine, the .0 results from the RBS1.0 at the beginning of the file. When I edit the file and add a space between the RBS and 1.0, that error goes away. I have even attempted to scramble a script with nothing more than a puts statement and I get the same errors.
            Are you using the latest version of the SDK scrambler ?
            • sdmitchS Offline
              sdmitch
              I think so. I downloaded it from http://code.google.com/apis/sketchup/docs/tutorial_distributing.html again just yesterday.
              • sdmitchS Offline
                sdmitch
                Thanks Jim. I have always just used the load command in the Ruby Console or AS_loader both of which caused load errors. Sketchup.load was the answer.
                  Jim
                  You need to use Sketchup.load to load .rbs files.
                  http://code.google.com/apis/sketchup/docs/ourdoc/sketchup.html#load
