    Exporting and section tool
    3 Posts 3 Posters 365 Views 3 Watching
    • G
      gvt2000
      Right now, when i export the section lines, it only exports the lines of the model that come into contact with the section plane. I've been looking for a way to export the visible elevation lines (everything BEHIND the section plane) when you section a model into Autocad, Is there a way to do this within sketchup or with a plugin?
      Much appreciated
        You need to make a copy of the model and then cut it in half at the section plane.
        My "SectionCutFace" tool can add the face onto the section, BUT you also need "Zorro2" to do the actual physical 'cut' through the geometry so you can erase 'half' before exporting it: search the plugins-index for it...
        • GaieusG
          Something like these (as TIG says).
          Perspective:
          https://lh6.googleusercontent.com/_zcvsIuYiVbo/S9albKtTOwI/AAAAAAAAEBs/4Ui-2vCOve8/s800/Bazilika_Metszet0000.jpg
          Parallel (still retaining that small, southern wall):
          https://lh6.googleusercontent.com/_zcvsIuYiVbo/S9albxTYWtI/AAAAAAAAEB0/AjFAo3QTj9s/s800/Bazilika_Metszet0001_hatter.jpg
          Parallel (full cut)
          https://lh6.googleusercontent.com/_zcvsIuYiVbo/S9alc410jLI/AAAAAAAAEB8/h6NT0b0y_Oo/s800/Bazilika_Metszet2_hatter.jpg
