    Snagit won't Snagit
    28 Posts 6 Posters 2.4k Views 6 Watching
    • boofredlayB
      boofredlay
      Thanks for the reply John.
      I have not played with the profiles yet, I just left it on "All in One". I also checked to make sure both places had the cursor checked. I will make sure I have the same settings at home tonight.
      The reason I am looking at Snagit is because I don't need many features, just a basic video screen capture. Therefore a $50 price tag is more desirable than $300. However with the lack of customer support I might look at another company all together. Customer service is big in my book. I even joined the Techsmith form and posted a question but have not gotten any response either, but it has only been 24 hours. We'll see.
      • W
        wyatt
        Hey Eric. I recently used BSR Screen Recorder to capture a Sketchy Physics animation. I only needed the animation, not mouse movements or anything like that, but I believe it has those features. It was free and relatively easy to use so it fit what I needed perfectly. You can check it out here if you're interested: http://www.thesilver.net/
        • boofredlayB
          boofredlay
          Thanks Wyatt, I will check it out.
            john.warburton
            I had problems with All-In-One myself and don't use it. I use custom settings now and it would be worth experimenting with these.
            Try setting the capture mode to Window and make sure that you select the Sketchup window before beginning the capture. The whole process of selecting the capture region in the latest version of Snagit is a pain and I did find that it would work OK for the first capture, then would only work again if I closed Snagit and re-started it.
            Life's a reach, and then you gybe.
            • boofredlayB
              boofredlay
              Thanks John. I will give it a go tonight.
                I haven't been having any problems with SnagIt. I just upgraded from 8 to 10 and everything seems to be working fine for me. Of course Eric, you already knew that. πŸ˜‰
                • boofredlayB
                  boofredlay
                  Yep, thanks Dave for the help earlier.
                  Wyatt, I tried installing BSR here at work and it failed. Must be a network thing. I will try at home.
                  I also found HyperCam2 which is free and seems to work well. However I like the Snagit interface better.
                  • boofredlayB
                    boofredlay
                    Ok, I am starting to develop a complex. I have tried every configuration in the profiles with no success.
                    I tried doing a video capture of me browsing the forums just for a check and the scroll wheel won't scroll. I checked the mouse driver and it is up to date.
                    Again, I am stumped and I am sure you guys are tired of hearing me whine and bitch about software problems. 😒
                    • KrisidiousK
                      Krisidious
                      have you tired installing that Wizmouse program to see if that fixes it?
                      404 Not Found
                      (antibody-software.com)
                      By: Kristoff Rand
                      • boofredlayB
                        boofredlay
                        I haven't no. I just don't see why it is not working here when it works just fine on my work machine. Sigh.
                        Uninstall and reinstall did not work either.
                        Edit: I can't even type into a google search. The video with cursor enabled is not allowing any other function to be recorded. 😑
                          Here's a quick example I did with SnagIt 10 i can switch to the Orbit tool and it shows and I can type in the search line for components. Eric, have you had any word at all from TechSmith's Customer Service?
                          Snag10.wmv
                          • boofredlayB
                            boofredlay
                            Mine works just like that at work, just not here.
                            I have not heard a peep from TechSmith, personally or on the Forum.
                              Strange.
                              I wonder why they haven't contacted you. Did you try tech support or customer support? (if they are different)
                              • boofredlayB
                                boofredlay
                                I don't remember actually. It was two weeks ago, then a couple days after that. Then I went on vacation... wiped my memory clean πŸ˜„
                                I did notice that when I use Photoshop on this new computer there is an visual issue when I am sliding layers around. Previously and on my work machine they move fast, no lag, but on this new machine it seems to labor just to move the layers up or down by dragging them. This is the only visual anomaly I have noticed since I got this machine. I am starting to think the two issues are related. My drivers are up to date so I don't really know what to check for.
                                  Out of curiosity, what graphics card?
                                  • boofredlayB
                                    boofredlay
                                    NVIDIA GeForce GT 220 1GB 16X PCI Expres
                                    • KrisidiousK
                                      Krisidious
                                      I know what to get you for Christmas... A man of your talents should have a better card.
                                      By: Kristoff Rand
                                      • boofredlayB
                                        boofredlay
                                        Hmmm, Pete suggested this one.
                                        • boofredlayB
                                          boofredlay
                                          The one running in my work machine is an NVIDIA Quadro FX 380. So far that is the only difference I see that could be causing the hangup with Snagit.
                                            Maybe you could borrow the card from your work machine and try it at home.
