    [Plugin] Color by Slope
    52 Posts 25 Posters 63.2k Views 25 Watching
      riboflavele
      I im trying to use this script, but i want to know its possible to change the colors and is it possible to know the slope % vs colors...? im not sure if my question is clear... Is it possible to have a legend or somthing to see for example that blue = 0% to 20% of slope and red = 40% to 60% of slope...
      Sorry for my english...
        See
        mat.color=[(255-value),value,value]
        line #56~
        Sets the face color, value is set by the angle...
        Edit it there...
        • H Offline
          halsktchup
          TIG, Chris,
          Thanks for the color by slope script. Like another person in here, I too am trying to see if I can get specific colors for specific slopes. Is there a later version to your script on smustard that contains this? For example if I need a certain red for anything above 20% slope, how do I get that?
          Thanks.
          • Chris FullmerC Offline
            Hey, so far the script does not do that. I do plan on implementing it eventually. I've got a super busy week and I do not anticipate being able to look at it right away, but it might be easy enough to just tweak some lines of code to make it work how you want. Maybe by next weekend I'll be able to look at it.
              Hope I'm not standing on any toes... πŸ˜•
              ### edited/replace the code from here................
              faces = []
              flat = []
              angle = 0.0
              sel.each do |e|
                faces << e if e.is_a? Sketchup;;Face
              end#do
              ### first set up some [r,g,b] colors for various slope angles
              ### we use them if they exist, but if not make them...
              if not color_00_20 = model.materials["color_00_20"]
                color_00_20 = model.materials.add("color_00_20")
                color_00_20.color= [120,0,0]
              end#if
              if not color_20_40 = model.materials["color_20_40"]
                color_20_40 = model.materials.add("color_20_40")
                color_20_40.color= [150,0,0]
              end#if
              if not color_40_60 = model.materials["color_40_60"]
                color_40_60 = model.materials.add("color_40_60")
                color_40_60.color= [180,0,0]
              end#if
              if not color_60_80 = model.materials["color_60_80"]
                color_60_80 = model.materials.add("color_60_80")
                color_60_80.color= [210,0,0]
              end#if
              if not color_80_90 = model.materials["color_80_90"]
                color_80_90 = model.materials.add("color_80_00")
                color_80_90.color= [240,0,0]
              end#if
              ### you can adjust the colors' rgb values to suit...
              faces.each do |e|
                enorm = e.normal
                flat = Geom;;Vector3d.new(enorm[0],enorm[1],0)
                angle = (flat.angle_between enorm).radians ### angle in in degrees
                ### now set up the tests for different angles
                ### change these test ranges etc to suit your requirements...
                if angle>=0.0 and angle<=20.0
                  color=color_00_20
                elsif angle>20.0 and angle<=40.0
                  color=color_30_40
                elsif angle>40.0 and angle<=60.0
                  color=color_40_60
                elsif angle>60.0 and angle<=80.0
                  color=color_60_80
                else ### angle>80.0
                  color=color_80_90
                end#if
                e.material = color
                e.back_material = color
              end#do
              ### end of edit/replace.................
              Make a backup copy of the original ruby script outside of the Plugins folder so it won't try load twice. If you mess up then you have the original to use again...
              Now edit/replace the version that's still in the Plugins folder, as set out above [open with Notepad.exe or equivalent plain-text editor].
              Save it and restart Sketchup - all slopes should now be colored in the angle-ranges and colors you've specified...
              πŸ€“
                Nope, not at all! Thanks TIG,
                  anilnimesh
                  Color by angle by you is amazing...
                  πŸ˜‰ rather i had changed name of the tool as 'Slope by angle' πŸ˜„
                  wow! ur work is amazing.
                  Please brief about color assignments in case of 'color by Slope'?
                  About myself, i m an Architect from India and doing practice in Delhi.
                  regards,
                  Anil Nimesh
                    Thanks for using my plugin. I'm not entirely sure what you are requesting though. Let me know if there is a feature you think should be added, thanks!
                      anilnimesh
                      Hi Chris,
                      i using sketchu pro v7.
                      while using the tool, it is bit difficult to understand, which color is applied for which slope. i need to calculate, hw the tool is working?
                      is there any color which defines slope (like 0-5% or 5%-10%) in slabs? i mean say 'red' for slope slab 0-5%
                      u wrote highest color no. is for low gradient and vice versa. u also wrote to explode the group (containing the terrain) and select color and make a new group out of those.
                      i tried but found it little tidious... πŸ˜†
                      althought it is much simplied then what we do manually.. πŸ˜„ but i need to understand more about your tool.
                      u also made a new one for v8 where it is called 'Color by slope stepped'. i found the previous one more relevant for my work.
                      so i need to know that can the tool defines colors w.r.t. slope in slabs (like 0-5% or 5%-10%) ?
                      regrds,
                        Agama
                        > faces = []
                        > flat = []
                        > angle = 0.0
                        > sel.each do |e|
                        > end#do
                        > end#if
                        > end#if
                        > end#if
                        > end#if
                        > end#if
                        > faces.each do |e|
                        >   enorm = e.normal
                        >     color=color_00_20
                        >     color=color_30_40
                        >     color=color_40_60
                        >     color=color_60_80
                        >   else ### angle>80.0
                        >     color=color_80_90
                        >   end#if
                        >   e.material = color
                        > end#do
                        πŸ€“
                        Hello,
                        Can you please explain how to do it 'step by step'? I've never used ruby script, however this tool will be very usefull for me if I can influence the slope colours.
                        Thank you for your help:)
                          dansphere
                          Yes I'm also having trouble, I've had a shot at changing the ruby but no luck.
                          Perhaps a logarithmic function for the assignment of colour to slope angle would work well, and then being able to reverse the log direction.. ??
                          Dan
                            What are you trying to do Dan? Just use a different method of determining the color to assign?
                            • brookefoxB Offline
                              brookefox
                              Here we have a near flat creek be with sloping sides and a near flat upper terrain. Faces picked to be colored are still shown picked. Highest slope r255 g0 b0; lowest r0 g0 b255 (or something like these values). There are some blue vertical slopes elsewhere.
                              I think it would be helpful if the flats got colored, too. So everything gets a color value. I would have thought lowest slope = flat, rather than vertical, which it seems to be.color by slope-2.JPG
                              I had wanted to try to use this as a means of selecting the slopes vs. the near flats for grouping, which I did manually with not too much difficulty.
                              ~ Brooke
                                sherwood11
                                Hello,
                                The plug-in appears to load properly. However, I get this Ruby Console feedback when I run it.
                                segment 3 [60 to 90]
                                segment 2 [30 to 60]
                                segment 1 [0 to 30]
                                Error: #<ArgumentError: comparison of Float with nil failed>
                                (eval):2304:in >' (eval):2304:in update'
                                C:/Program Files/Google/Google SketchUp 8/Plugins/clf_color_by_slope.rb:230:in colorbyslope' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_color_by_slope.rb:223:in each'
                                C:/Program Files/Google/Google SketchUp 8/Plugins/clf_color_by_slope.rb:223:in colorbyslope' C:/Program Files/Google/Google SketchUp 8/Plugins/clf_color_by_slope.rb:254 (eval):2304:in call'
                                (eval):2304
                                Has anyone encountered this before ? .... any solution or direction to resolve ?
                                I have checked that faces are faces (not surfaces).
                                Segment materials appear in the list of materials.
                                The faces just don't want to color ...
                                • sdmitchS Offline
                                  sdmitch
                                  The problem appears to be associated with the progress bar.
                                  C:/Program Files/Google/Google SketchUp 8/Plugins/clf_color_by_slope.rb:230:in `colorbyslope'
                                  refers to the the statement
                                  pb.update(count)
                                  If the problem persists, then I would just comment or remove the line. The only consequence will be progressbar will never update but, unless the model is huge, you will not know the difference.
                                  http://sdmitch.blogspot.com/
                                    sherwood11
                                    Yeess, Thank You !
                                    I commented out that line ...
                                    #pb.update(count)
                                    I was/am testing it on a very small dummy file.
                                    I shall investigate my version(copy) of progressbar.rb
                                    Thanks again
                                      sherwood11
                                      sd,
                                      Based on your help, I also found that my version of progressbar.rb
                                      was affecting :
                                      clf_color_by_z.rb
                                      clf_greeble_2.rb
                                      So, it turns out to be predictable....
                                      Thanks again
                                        Do you have the current version of ' progressbar.rb' - which can be downloaded free from http://Smustard.com ?
                                          sherwood11
                                          TIG,
                                          .. I just downloaded and compared both files. They appear
                                          to be identical ... Author, date, history, no. of lines, size, etc.
                                          (by-the-way, it is in the 'plugins' folder)
                                          However, I still replaced it with the fresh download.
                                          I did a search and found another progressbar.rb
                                          in another folder ... plugins\TT_Lib2\
                                          They are different, but I can't see how it would have an affect...
                                          I temporarily renamed it.
                                          I un-commented the pb.update(count) lines in the clf_... .rb files
                                          and I still received the same Ruby Console feedback, as before. http://forums.sketchucation.com/posting.php?mode=reply&f=323&t=20635#
                                          I restored things back to working order and will continue to debug another day.
                                          I appreciate your suggestion, Thanks much
                                          I'll post when(if) I find the solution.
                                            When an author includes a file inside their own subfolder like TT's it's to keep a similar but separate code set.
                                            Don't worry about that one.
                                            Are you sure the require files are all really inside Plugins and not sidetracked by some 'Compatibility Files' OS trickery because you don't have FULL access rights to the Plugins folder ???
                                            • 2 / 3
