    If else
    15 Posts 4 Posters 1.0k Views 4 Watching
    • B
      borg.stef
      Can the following be written in ruby? because it does not seem to work correctly
      if counter % 4 == 0
      			machine = "#{a[counter]"
      		elsif counter % 4 == 0.25
      			x = a[counter].to_f
      		elsif counter % 4 == 0.5
      			y = a[counter].to_f
      		elsif counter % 4 == 0.75
      			rot = a[counter].to_i
      • Dan RathbunD
        Dan Rathbun
        Your missing a closing "}" in the String assignment:
        should be:
        machine = "#{a[counter]}"
        You can also use:
        machine = a[counter].to_s
        I'm not here much anymore.
        • B
          borg.stef
          yes that's ok because i mistyped here..but still not working. Can decimal points be used in elsif?
            You can test if x==0.678 BUT your code [probably] never returns a decimal value ?????
            What is 'a' ? An array ??
            What is 'counter' - a float or an integer ?
            If it's an integer you'll never get a decimal result as the answer is always an integer ?
            Assuming counter is an integer as 0,1,2,3,4 etc
            if 'counter' is 4 then counter % 4 is 0
            But
            if 'counter' is 0 then counter % 4 is 0
            if 'counter' is 1 then counter % 4 is 1
            if 'counter' is 2 then counter % 4 is 1
            if 'counter' is 3 then counter % 4 is 3
            You will never get a decimal value like 0.5 unless counter ends with 0.5 !
            So you can't rely on this as you get the same % answer for 0,4,8,12 etc - unless that is acceptable in your coding ??
            To test these things simple type into the Ruby Console 0%4 and get 0, 4%4 and get 0 etc etc.., without making a complex test that does NOT give the results you 'assumed'...
            • Dan RathbunD
              Dan Rathbun
              Try this:
              if counter % 4.0 == 0.0
              elsif counter % 4.0 == 0.25
              	x = a[counter].to_f
              elsif counter % 4.0 == 0.5
              	y = a[counter].to_f
              elsif counter % 4.0 == 0.75
              Or this:
              if counter / 4.0 == 0.0
              elsif counter / 4.0 == 0.25
              	x = a[counter].to_f
              elsif counter / 4.0 == 0.5
              	y = a[counter].to_f
              elsif counter / 4.0 == 0.75
              You need to use a Float as the divisor to get a Float result.
              • B
                borg.stef
                a = []
                	counter = 0
                	file = File.new("trial.txt", "r")
                	while (line = file.gets)
                		a[counter] = line
                		if counter % 4 == 0     # lines 0 , 4, 8 etc
                		elsif counter % 4 == 0.25      # lines 1, 5, 9 etc
                			x = a[counter].to_f
                		elsif counter % 4 == 0.5    # lines 2, 6, 10 etc
                      			y = a[counter].to_f
                		elsif counter % 4 == 0.75     # lines 3, 7, 11 etc
                • Dan RathbunD
                  Dan Rathbun
                  This should work:
                  a = []
                  counter = 0
                  	a[counter] = line
                  	if counter % 4 == 0.0     # lines 0 , 4, 8 etc
                  	elsif counter % 4 == 1.0      # lines 1, 5, 9 etc
                  		x = a[counter].to_f
                  	elsif counter % 4 == 2.0    # lines 2, 6, 10 etc
                        		y = a[counter].to_f
                  	elsif counter % 4 == 3.0     # lines 3, 7, 11 etc
                    You haven't understood what I said several posts back
                    will never return true as it returns '1' NOT '0.25'... to test this simply type 1%4 or 5%4 in the Ruby Console and you'll get '1' NOT '0.25' !
                    Also note how 1/4 will return 0 because dividing an integer by an integer gives an integer [and 5/4 gives 1 !]... BUT 1/4.0 gives 0.25 as you have divided an integer by a float and you get a float.
                    SO your test is elsif counter % 4 == 1 # lines 1, 5, 9 etc πŸ˜’
                    • B
                      borg.stef
                      hmmm this worked now...but I didn't understand why you did 1% 4 = 1.0 etc?
                      • Dan RathbunD
                        Dan Rathbun
                        You may wish to use the 3rd line as:
                        file = IO.readlines("trial.txt")
                        .. then change the while loop to an array each iterator:
                        ` file.each_with_index do |line,counter|
                        code
                        end`
                        • Dan RathbunD
                          Dan Rathbun
                          Because I did what TIG said, I tested it at the console, and saw it returned 1,2,3, ...
                          • B
                            borg.stef
                            ok sorry TIG i saw your post now 😳
                            • Dan RathbunD
                              Dan Rathbun
                              code
                              end`
                              If you do this, you do not need a = [], because the var file is the array ( IO.readlines returns an array of textlines.)
                              • B
                                borg.stef
                                ok thanks both!!
                                • C
                                  Cleverbeans
                                  From the looks of your code you're interested specifically in blocks of four lines, in which case you may gain some mileage out of the array.slice method by doing the following.
                                  for i in 0..a.length/4 #there are i blocks of four lines
                                      machine,x,y,rot = a.slice(i*4,4)
                                      #more code
