    If else
    15 Posts 4 Posters 1.0k Views 4 Watching
    • B
      borg.stef
      a = []
      	counter = 0
      	file = File.new("trial.txt", "r")
      	while (line = file.gets)
      		a[counter] = line
      		if counter % 4 == 0     # lines 0 , 4, 8 etc
      			machine = "#{a[counter]}"
      		elsif counter % 4 == 0.25      # lines 1, 5, 9 etc
      			x = a[counter].to_f
      		elsif counter % 4 == 0.5    # lines 2, 6, 10 etc
            			y = a[counter].to_f
      		elsif counter % 4 == 0.75     # lines 3, 7, 11 etc
      			rot = a[counter].to_i
      • Dan RathbunD
        Dan Rathbun
        This should work:
        a = []
        counter = 0
        	a[counter] = line
        	if counter % 4 == 0.0     # lines 0 , 4, 8 etc
        	elsif counter % 4 == 1.0      # lines 1, 5, 9 etc
        		x = a[counter].to_f
        	elsif counter % 4 == 2.0    # lines 2, 6, 10 etc
              		y = a[counter].to_f
        	elsif counter % 4 == 3.0     # lines 3, 7, 11 etc
        I'm not here much anymore.
          You haven't understood what I said several posts back
          will never return true as it returns '1' NOT '0.25'... to test this simply type 1%4 or 5%4 in the Ruby Console and you'll get '1' NOT '0.25' !
          Also note how 1/4 will return 0 because dividing an integer by an integer gives an integer [and 5/4 gives 1 !]... BUT 1/4.0 gives 0.25 as you have divided an integer by a float and you get a float.
          SO your test is elsif counter % 4 == 1 # lines 1, 5, 9 etc πŸ˜’
          • B
            borg.stef
            hmmm this worked now...but I didn't understand why you did 1% 4 = 1.0 etc?
            • Dan RathbunD
              Dan Rathbun
              You may wish to use the 3rd line as:
              file = IO.readlines("trial.txt")
              .. then change the while loop to an array each iterator:
              ` file.each_with_index do |line,counter|
              code
              end`
              • Dan RathbunD
                Dan Rathbun
                Because I did what TIG said, I tested it at the console, and saw it returned 1,2,3, ...
                • B
                  borg.stef
                  ok sorry TIG i saw your post now 😳
                  • Dan RathbunD
                    Dan Rathbun
                    code
                    end`
                    If you do this, you do not need a = [], because the var file is the array ( IO.readlines returns an array of textlines.)
                    • B
                      borg.stef
                      ok thanks both!!
                      • C
                        Cleverbeans
                        From the looks of your code you're interested specifically in blocks of four lines, in which case you may gain some mileage out of the array.slice method by doing the following.
                        for i in 0..a.length/4 #there are i blocks of four lines
                            machine,x,y,rot = a.slice(i*4,4)
                            #more code
