    If else
    15 Posts 4 Posters 1.1k Views 4 Watching
    • Dan RathbunD
      Dan Rathbun
      Your missing a closing "}" in the String assignment:
      machine = "#{a[counter]"
      should be:
      machine = "#{a[counter]}"
      You can also use:
      machine = a[counter].to_s
      I'm not here much anymore.
      • B
        borg.stef
        yes that's ok because i mistyped here..but still not working. Can decimal points be used in elsif?
          You can test if x==0.678 BUT your code [probably] never returns a decimal value ?????
          What is 'a' ? An array ??
          What is 'counter' - a float or an integer ?
          If it's an integer you'll never get a decimal result as the answer is always an integer ?
          Assuming counter is an integer as 0,1,2,3,4 etc
          if 'counter' is 4 then counter % 4 is 0
          But
          if 'counter' is 0 then counter % 4 is 0
          if 'counter' is 1 then counter % 4 is 1
          if 'counter' is 2 then counter % 4 is 1
          if 'counter' is 3 then counter % 4 is 3
          You will never get a decimal value like 0.5 unless counter ends with 0.5 !
          So you can't rely on this as you get the same % answer for 0,4,8,12 etc - unless that is acceptable in your coding ??
          To test these things simple type into the Ruby Console 0%4 and get 0, 4%4 and get 0 etc etc.., without making a complex test that does NOT give the results you 'assumed'...
          • Dan RathbunD
            Dan Rathbun
            @borg.stef said:
            Can the following be written in ruby? because it does not seem to work correctly
            Try this:
            if counter % 4.0 == 0.0
            elsif counter % 4.0 == 0.25
            	x = a[counter].to_f
            elsif counter % 4.0 == 0.5
            	y = a[counter].to_f
            elsif counter % 4.0 == 0.75
            	rot = a[counter].to_i
            Or this:
            if counter / 4.0 == 0.0
            elsif counter / 4.0 == 0.25
            	x = a[counter].to_f
            elsif counter / 4.0 == 0.5
            	y = a[counter].to_f
            elsif counter / 4.0 == 0.75
            You need to use a Float as the divisor to get a Float result.
            • B
              borg.stef
              a = []
              	counter = 0
              	file = File.new("trial.txt", "r")
              	while (line = file.gets)
              		a[counter] = line
              		if counter % 4 == 0     # lines 0 , 4, 8 etc
              		elsif counter % 4 == 0.25      # lines 1, 5, 9 etc
              			x = a[counter].to_f
              		elsif counter % 4 == 0.5    # lines 2, 6, 10 etc
                    			y = a[counter].to_f
              		elsif counter % 4 == 0.75     # lines 3, 7, 11 etc
              • Dan RathbunD
                Dan Rathbun
                This should work:
                a = []
                counter = 0
                	a[counter] = line
                	if counter % 4 == 0.0     # lines 0 , 4, 8 etc
                	elsif counter % 4 == 1.0      # lines 1, 5, 9 etc
                		x = a[counter].to_f
                	elsif counter % 4 == 2.0    # lines 2, 6, 10 etc
                      		y = a[counter].to_f
                	elsif counter % 4 == 3.0     # lines 3, 7, 11 etc
                  You haven't understood what I said several posts back
                  will never return true as it returns '1' NOT '0.25'... to test this simply type 1%4 or 5%4 in the Ruby Console and you'll get '1' NOT '0.25' !
                  Also note how 1/4 will return 0 because dividing an integer by an integer gives an integer [and 5/4 gives 1 !]... BUT 1/4.0 gives 0.25 as you have divided an integer by a float and you get a float.
                  SO your test is elsif counter % 4 == 1 # lines 1, 5, 9 etc πŸ˜’
                  • B
                    borg.stef
                    hmmm this worked now...but I didn't understand why you did 1% 4 = 1.0 etc?
                    • Dan RathbunD
                      Dan Rathbun
                      You may wish to use the 3rd line as:
                      file = IO.readlines("trial.txt")
                      .. then change the while loop to an array each iterator:
                      ` file.each_with_index do |line,counter|
                      code
                      end`
                      • Dan RathbunD
                        Dan Rathbun
                        Because I did what TIG said, I tested it at the console, and saw it returned 1,2,3, ...
                        • B
                          borg.stef
                          ok sorry TIG i saw your post now 😳
                          • Dan RathbunD
                            Dan Rathbun
                            code
                            end`
                            If you do this, you do not need a = [], because the var file is the array ( IO.readlines returns an array of textlines.)
                            • B
                              borg.stef
                              ok thanks both!!
                              • C
                                Cleverbeans
                                From the looks of your code you're interested specifically in blocks of four lines, in which case you may gain some mileage out of the array.slice method by doing the following.
                                for i in 0..a.length/4 #there are i blocks of four lines
                                    machine,x,y,rot = a.slice(i*4,4)
                                    #more code
