    What's your beginners tip?
    305 Posts 169 Posters 453.9k Views 169 Watching
    • E
      EWWinterbach
      As a newby - Myself - best is to play and pracice and keep playing playing playing - its such an easy program and once youve played a bit - ask question from the guys here that know it thru and thru
      by the way - do u know how to make fabric - like as in fold of fabric in random
      I dunno and its doing my head in
      can u help
      i see it has been done in Library
      if so please email me : info@in2interiors.co.za
      regards from : Cape Town South Africa
      • T
        Trogluddite
        Learn to think more negatively!
        In my first few attempts at making my own objects, I found that I was trying to make lots of little 'construction kit' parts, and then ending up with nasty overlaps and internal faces when I tried to 'build' my object.
        But, it is often better to think more like like a sculptor - don't 'build' an object, rather 'carve' it from a solid block to remove the bits you don't want. The push/pull tool is your biggest friend for this.
        Using 'intersect faces' (or Solid Tools if you have SU Pro) makes light work of 'carving' even the most complex 'negative shapes'.
        For example, I needed to make some realistic screws with nice rounded 'mushroom' heads. But constructing the slots for a Phillps screwdriver into a curved surface isn't easy (and concave areas are always a bit awkward, even with X-ray view or wireframe).
        Far easier to construct a nice easy convex 'screwdriver' component, and then use that to carve out the slots using subtraction.
        This is as much about how you see the objects around you, as it is about SU technique (just as in painting or sculpture) - so it's worth training your eye to see the shapes of the 'nothingness' in objects as much as the solid matter.
          mics_54
          my attempt at fabricfabric.skp
          • E
            EWWinterbach
            @mics_54 said:
            my attempt at fabric[attachment=0:1kogs4cp]<!-- ia0 -->fabric.skp<!-- ia0 -->[/attachment:1kogs4cp]
            thank you so much for this example
            it open up my world to the fabric thing that was holding my back
            your example has helped heaps
            now i am creating some awesome stuff
            See it just needs one person to lead the way and the rest of us learn so much
            bravo !!!!!
            • DanielD
              Daniel
              Whatever your modeling, pay attention to how things are made, and model accordingly. And, pay attention to how you position your textures.
              My avatar is an anachronism.
              • X
                xphatjunkie
                My beginner tip (in landscape practice) : always save many scenes for every match perspectives, plan, detail, and section
                a Landscape Architect. Born in Indonesia. Live in Hong Kong
                  DanYHKim
                  Two-sided Faces
                  I don't usually deal with materials and faces, but this is a useful characteristic. Faces have two different sides, and are usually colored differently. It is possible to make one face transparent, while the other side is opaque. I use this when modeling a house, so I can see the interior of the house when looking through the top, but a solid ceiling shows when I have POV inside the house.
                  Here's a video of this:
                  http://www.youtube.com/watch?v=ivv4qcdX6lM
                  [flash=425,344:32vbof82]http://www.youtube.com/v/ivv4qcdX6lM[/flash:32vbof82]
                  Related video done by someone else:
                  http://www.youtube.com/watch?v=wBcI7Rzo6yU
                    DanYHKim
                    I always set up custom keyboard shortcuts, then save them to a file. I keep this file in a USB Flash drive that I carry with me, so it's handy. I also use the "Large Tool Set" instead of the "Getting Started" set, and set buttons small.
                    My department has computers in the lab with SketchUp installed, but students do not have Admin rights. They cannot install plugins or components into the usual places. It turns out that you can copy the program folder for SketchUp to a Flash drive, and run it from there, if the host computer also has SketchUp installed. It may require that the same or higher version be installed, but haven't tested that yet.
                    So, I have told students that they can install SketchUp on their home computers, install plugins and component bonus packs, and then copy the program folder to a USB drive. If they run the program from there, it will give them access to the plugin and components folders, which is very handy. Not exactly "portable" SketchUp, but close.
                    I have a video of this:
                    http://www.youtube.com/watch?v=0VQmkz-MraA
                    The relevant portion of this video begins at 5:25
                    [flash=425,344:2tby5oj2]http://www.youtube.com/v/0VQmkz-MraA[/flash:2tby5oj2]
                    In truth, there's probably no real reason why SketchUp can't be reconfigured to run as a portable app. Only a few minor changes would do it I'm sure.
                    • GaieusG
                      Yes, that's a good trick. I also did it here where I painted the back face of the thick wall transparent so that windows "seem" to cut through those thick walls:
                      • B
                        bestmate
                        If i may ,can i give you our future experts ( trust me it won't take long ) tips to help them along
                        1/ Accurate inferencing, To me is the corner stone to clean non hair pulling out experiences in sketchup ( Zoom zoom to see were your putting that line)
                        2/ COPLANER If that face will not fill in after 10 minutes ( and i have been there) its not flat ! If there are two lines very close together where there should be one ( you know, those lines that look alittle thicker that the other lines), then the party on its the way to pair shape city Ha ha.
                        3/ Work cleanly and and erase those lines that should not be there ( the lines that keep flashing puppy eyes at your inference engine) ,and your clinical approach will reward you , in not wanting to get off your computer ,rather than throwing it out the window .
                        Enjoy Phil
                        • ToboboT
                          Tobobo
                          Another tip, keep coming back to this and the 'Duh' threads again and again. I keep forgetting things that people have mentioned.
                          Toby
                          Philippians 4:13
                          • peter_shawP
                            peter_shaw
                            when composing a scene for rendering, the look around tool is quite handy. you can change your eye height by simply typing in numbers while using the tool.
                            • P
                              petropix
                              Beginners tip? Use a programable multi-button mouse. I recommend Logitech Revolution VX, smallish and elegant (unfortunately discontinued). You can assign 10 functions and now you're a speed demon in SketchUp. There aren't that many makes out there which is frustrating because I've worn out four of these Logitech mice and the new Logitech iterations are cheaply made with fewer functions, although there's the option of going to a full-blown gamer's mouse.
                              • V
                                vjekobalas
                                I'm a beginner but I'll allow myself to be a bit philosophical
                                as I've come to a conclusion which may or may not mean anything
                                to you - besides going through all the sketchup videos and duplicating
                                the steps in the videos and understanding the basics of the tools, my tip
                                is that you have to stop thinking about drawing (lines, shapes etc.) and
                                start thinking creatively about geometry, components, groups
                                and how the tools can be combined in magical ways to draw what you need. β˜€ πŸ˜„
                                When you have some spare time, pick some questions on the forum on how
                                something was done and you'll further speed up filling your bag of tricks.
                                • peter_shawP
                                  peter_shaw
                                  u can shortcut any function, even plugins. as a gamer, my hand automatically rests on wasd all the time πŸ˜„ so i set up shortcuts that are easy to reach from that: q: make line, w: paintbucket, e: push pull, r: move
                                  spacebar: selection tool, x: xray mode
                                  etc.
                                  one of the best shortcuts for modelling with groups and components is view/component edit/hide rest of model.
                                  the ability to toggle that is just awesome.
                                  • opalO
                                    opal
                                    needs the how to set up shortcuts instructions
                                    ETA.. ^found it^ nm
                                    btw.. loving that icon picture of yours Peter.. can't stop looking and smiling
                                      android no. 12
                                      everything has thickness - walls, glass panes, even paper when you make a face on sketchup, it is only a 2D shape which cannot exist in real life. make sure you give every object a thickness
                                      start on components early. groups will prevent you from getting in a mess if you want to seperate 2 objects, and will enable you to select whole objects easily. components do the same, but you can copy a component around, and if you edit one all the others can change.
                                      when drawing shapes, you will often benefit from typing in the desired length. this will help you keep track of things and have regularity in your model. also don't use sill lengths like 147.43528m unless necessary
                                      Components window will allow you to keep track of all components in your model, and see which ones are in the file but not in the model. you can then delete those to speed things up. same with materials. if you use one once, it remains in the file, even if you remove it from the model
                                      soften edges to hide a line, and this will also try to smoothen the face. go to view>hidden geometry to see all lines you have hidden. a curve is actually a series of straight lines, and extruding a curve will make lots of lines.
                                      For accurate selection, you may want to use the views toolbar, and parallel projection
                                      • kingsiK
                                        kingsi
                                        Hello Everyone
                                        I am very new to this Sketchup world, but I have 2 tips narrowed down from 2000.
                                        1. Make sure you have a very clear idea of what you want to achieve with a drawing. Have the Endgame in mind at all times. Don't do a me and get distracted by overcomplicating a drawing. If you are designing something archtiectural that exists in the real world make damn certain you have decent photos to work from, from the start. Its really annoying having to go back to take more, not to mention photomatching at the end of a design is just downright depressing lol.
                                        2. Learn the Lingo. As with any new piece of software what you think some operation, action or effect should be called and what it is really called and what other people call it are often different things. I forget how many times I have rumaged about youtube, typing in all sorts of keywords to only stumble upon what I wanted to learn by accident way after the fact. From what I can tell, everything I want to do with sketchup is possible, it is only me that does not know how to do it and importantly what its bloody called.
                                        Noobtastic
                                        • rami_lpmR
                                          rami_lpm
                                          If you took time to arrange your toolbars, use 'View/Toolbars/Save Toolbar Positions'.
                                          You never know when sketchup will stumble and ruin your workspace.
                                            dark phoenix
                                            @ross macintosh said:
                                            Tip: Orbit, Pan & Zoom using the middle mouse button / scroll wheel.
                                            middle mouse button to orbit
                                            middle mouse button + shift to pan
                                            and the scroll wheel to zoom
                                            The tool buttons for orbiting, panning and zooming almost never need to be used.
                                            I had been using this program for about a week, and JUST found out this tip when you mentioned it! AWESOME! Thank you!
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 11 / 16
