    [Plugin] CleanUp
    974 Posts 217 Posters 862.0k Views 217 Watching
      That's because one of them got a material applied to its backside. Tick the Ignore Materials checkbox and it'll merge them.
        JPMays
        I had thought something like that might be the issue, and so I selected everything and applied a uniform material. I even did Reverse Faces to make sure everything was the same. I also used cleanup to set everything to Level 0, but still couldn't get them to merge.
        Hofstadter's Law: It always takes longer than you expect, even when you take into account Hofstadter's Law.
          But you get them to merge when you tick Ignore Material, right?
          Btw, I think I've trapped the case where faces disappear. Will post an update later this week.
            JPMays
            Aha, yes it worked! Thanks Thom.
            • N Offline
              nosehair
              thank you!it's very useful!
              • F Offline
                firebert85
                i loaded this plugin into sketchup 8 and its not working, gives me an error message at startup and the plug in cant be found.
                  We are not psychics - please post the error message. So far it suggests you have not installed things properly. Can you confirm what files were put in what folders, and the TT_Lib you installed etc...
                  • utilerU Offline
                    utiler
                    You sound like I feel, TIG! Bloody big weeks' work and you still get asked silly questions..... ๐Ÿ˜ฎ
                    Just Curious...
                    • F Offline
                      firebert85
                      jesus you make it sound like its rocket science.
                      Error Loading File tt_cleanup.rb
                      no such file to load -- TT_Lib2/core.rb
                      its the one file posted on the board, and its in the google sketchup 8 plugin folder.
                      like every other plugin ive downloaded from this website.
                        It seems that TIG was right and you did nt install TT_Lib (another required plugin) as suggested in the plugin post. Please, make sure that is also installed and restart SU.
                          The error message tells you/us what is missing...
                          Many of the more complicated scripts have 'Libraries' of additional functions, that they sometimes share with other tools written by the same author. Many of thomthom's tools use his 'TT_Libs'...
                          It was explained that you need this addition stuff and clearly linked in the thread from where you got the main .rb file...
                          http://forums.sketchucation.com/viewtopic.php?p=193587#p193587 Capture.PNG
                            risoto1978
                            I tried to install the cleanup ruby file on my mac. But then starting sketchup I got this error message: "no such file to load -- TT_Lib2/core.rb" but this one was not part of the download.
                            somebody can help?
                            risoto
                              Hi Christian (and welcome),
                              Please, go back to the first post and follow the link to that TT_Libray (and additional plugin package) you also need for this (and some other) plugin(s) to work.
                                Christian
                                Follow Gaieus's advice and mine in the post just before yours ๐Ÿ˜• http://forums.sketchucation.com/viewtopic.php?p=316703#p316703 that shows the link... ๐Ÿ˜’
                                  risoto1978
                                  Thanks for the hint. Reading makes things easier. Now it works.
                                  cheers
                                  risoto
                                    JasonDoggart
                                    Thanks so much for this tool! All your hard work is greatly appreciated!
                                    • Bob JamesB Offline
                                      Bob James
                                      I wound up in a complex model with several instances of a component having two or three different names. I want to change it so that all of the components that are physically the same become just one component and one name.
                                      I tried the "similar" tool but that didn't seem to do anything (that I could tell).
                                      I can't manually fix it because SU requires unique names.
                                      Any advice?
                                        It doesn't currently handle nested components etc. It's very experimental and I've not had time to work more on it. ๐Ÿ˜ž
                                        Select the component you want in the model - then type into the Ruby Console:
                                        prototype = Sketchup.active_model.selection[0].definition
                                        Select one or more of the instances of the definition you want to replace - then:
                                        Sketchup.active_model.selection.each{|e|e.definition=prototype}
                                        (Make sure the components axis are place identically.)
                                          rocorona
                                          --Select the COMPONENT you want to replace;
                                          --Go to the Components Browser:
                                          --Right-click on the preview of the replacing component;
                                          --Choose the "Replace selection" command;
                                          Was this your goal?
                                            Bob James
                                            Was this your goal?
                                            Thank you for your idea, but I've used the workflow you describe, but it still leaves the names different.
                                            Goal: Several identical components have different names: I want consolidate all of them into one component and one name.
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 48
                                            • 49
                                            • 39 / 49
