    A question about(smoothing +) exporting 4 use in Poser
    12 Posts 4 Posters 1.5k Views 4 Watching
    • McGyverM
      McGyver
      That is probably a bad title.
      I'm going to try and ask this as clearly as I can and provide whatever info you might need to know.
      What you might need to know:
      I'm a Mac user.
      I use a lot of my models in Poser 7(and Bryce too). Generally the things I make consist of hard edges, so this problem is not really much of a problem. I generally check out/test render my models in Kerkythea (and they look 1,000 times better than any Poser render).
      I have found that to use a model that I have made, in Poser I get the best results by exporting it in 3DS format (OBJ models are completely butchered by Poser).
      I recently made a model that uses a glass dome, it looked fine in Kerky and I figured if I had to, I'd fiddle with it in Poser to smooth out any faceting that might occur (I've never actually done it, but I have a Poser book with instructions on how to "smooth polygons" using crease angle).
      I exported it in 3DS format, imported it to Poser and did some test renders... as expected it looks really faceted, but what I did not expect is that I can not smooth out those edges in Poser... changing the crease angle does nothing, nor does selecting "smooth polygons".
      My question/questions:
      Why does it look fine in Kerkythea (it appears smoothing is preserved in Kerky) and why can't Poser smooth out the facets... is there a way to prevent this? Does the smoothing slider in SU just effect the look of the model in SU or is there any data from it that actually gets exported with it (I tried several different setting, 60-90° and there seem to be no difference).
      I'm guessing there is nothing to be done about this, but I figured I'd ask anyway... It's kind of a bummer, I did the model as a request and made a couple of different far more complex version, but with the glass looking so shabby it all seems like a waste.
      Anyway, thanks in advance for any help or suggestions you may provide.
      The model in question rendered using Kerkthea
      The same model Rendered in Poser 7
      Visit My ShareCG Freebie Gallery
      • K
        Khai
        ok you'll need to take some steps into account.
        the easy fix is to get UVmapper (Uvmapper.com) and use that to "split vertices" that will stop the model ballooning. (Old School fix reliable but the model's them a mass of unconnected facets)
        a better fix is to put a "micro bevel" in place - basically put an extra tiny face round the hard edges. (imagine the edge is | you put in extra edges to make ||| but as close as you can to the edge.)
        also in poser, the properties for each mesh, you'll find "Crease Angle" and "Smoothing"
        try turning Smoothing Off and adjusting the crease angle -0 = facets 100= smoothed out. I normally use 22.5 myself.
        if you do the above, don't use 3ds. that's the worst format for poser. use OBJ (it's posers native format!) Tig's exporter works great... the OBJ's are being butchered because you need to adjust the model to poser's....quirks.
        • AnssiA
          Anssi
          I haven't used Poser for a long time, but I seem to remember that OBJ from SketchUp worked best if you checked the "Triangulate all faces" option in the Export Options dialog box.
          Anssi
          • McGyverM
            McGyver
            Thank you for your fast response Khai! I did not expect on for for several days if any.
            I've been told not to use the 3DS export option, but it is really the only one that works. When I say butchered, I really mean it. I have never had a model that was even remotely usable(made in SketchUp) that I was able to export in OBJ (to Poser). Parts are distorted, with odd spikes shooting off into infinity, windows and doors are closed or distorted and sometimes textures don't apply. I gave up on it a long time ago because I just never had a good result. I'll give TIG's exporter a try though, maybe that will work better. He really seems to make better free plugins than the SU programers make as paid upgrades.
            You said "try turning Smoothing Off and adjusting the crease angle -0 = facets 100= smoothed out. I normally use 22.5 myself." Are you saying that to adjust the crease angle you have to turn off smoothing? Also the book I have says that most models should be 80-90° to not appear faceted, wouldn't 22.5° be faceted too?
            Thanks again for your reply!
            • McGyverM
              McGyver
              Anssi
              Thanks( your response came up while I was posting my previous reply)... I have tried triangulate faces also but there seems to be little difference in the result. I'll try that with TIG's plugin,if that is an option though.
              Thanks again.
              • K
                Khai
                aah
                you say you have holes closed? that's easy. you can't have concave faces in the OBJ format.
                gimme a bit to create a pic to show you.
                • K
                  Khai
                  ok here we go.
                  the problem is, the OBJ format does not support holes in a mesh unless you take some steps, namely defining the hole.
                  on the left is a mesh that will error. see how the hole is not connected to the edge, forming an Ngon round the hole. that and similar, say the letter C etc will not work.
                  on the right, I've added 4 edges in the corners. this will work correctly. it's just a matter of resolving the shape. if you were using a C shape, you'd need to just join the inner curve to the outer to fix it. (hope that's clear, if not I'll draw a pic)
                  • K
                    Khai
                    "You said "try turning Smoothing Off and adjusting the crease angle -0 = facets 100= smoothed out. I normally use 22.5 myself." Are you saying that to adjust the crease angle you have to turn off smoothing? Also the book I have says that most models should be 80-90° to not appear faceted, wouldn't 22.5° be faceted too?
                    Thanks again for your reply!"
                    I think that smoothing off on the mesh will fix most for you plus the modeling tricks, but I find 22.5 or 45 is the best balance for hard/curved like your model.
                    remember, 80 is the setting they use for humans in the software..
                    • McGyverM
                      McGyver
                      Thank you for that great explanation Khai! I have been told that OBJ can not handle holes in a mesh before, but you see plenty of OBJ models with what look like holes in them... Now I understand how it is possible!
                      The addition of the illustration really helped.
                      • GaieusG
                        Do you export your model as 3ds with vertices welded? Cjeck out the export options at the bottom right of the export window.
                        • McGyverM
                          McGyver
                          Sorry to reply so late, I just wanted to thank you folks for your help.
                          I manage to get the model to a usable state... I separated the glass(actually I deleted it and made a whole new part) and exported it as a separate model. They will be two separately loading PP2 files (I don't do PZ3, since DAZ Studio users can't load them). I chose the 3ds format again because in obj the model was importing into Poser in at two different scales and 3ds was not. I also went and found TIG's obj exporter and it is WAY better than SU's native one. I took Gaieus's advice for the glass section and chose "Favor: Welding vertices" for it, although I kept "Preserving texture coordinates" for the rest of the structure out of fear of having the textures get messed up (Poser 7 has a very awkward camera movement method that makes throughly checking a model VERY slow and painful).
                          I will take all this info I received here and experiment use it to experiment further to get the optimum results.
                          Once again thank you Khai, Anssi and Gaieus for all your help!
                          • K
                            Khai
                            "I chose the 3ds format again because in obj the model was importing into Poser in at two different scales and 3ds was not."
                            ah
                            this one, when you import in poser, you'll have the choices "Percent of standard figure size 100%" and "centered"
                            turn those OFF. ok, the model will import at a huge scale,(poser scale is tiny. a legacy thing), but it will then import at the correct scale with each other and in the correct position to each other.
                            then in poser, open the Hierarchy Window, and drag the pieces together to form a single unit (eg, for your model above, drag "Dome" so it becomes a child of "Walls").
                            then select the parent and rescale that. the child parts will rescale as well.
