    Instructor content
    84 Posts 8 Posters 16.1k Views 8 Watching
      @dan rathbun said:
      So it's either webdialog or native Win32 dialog (I'm leaning toward the latter... if Google is not going to bring the Mac Ruby up to date.. then screw it.. sorry Apple lovers.)
      What does the rube core got to do with the webdialog?
      I had been thinking of adding an Instructor for a couple of tools - but it'd not been high on the list. I was about to add it to Vertex Tools - but due to the way I made the sub-tool system I could not. (should be way to force refresh the instructor window with other content.)
      @dan rathbun said:
      I have never tried it, but had some ideas I wanted to use the instructor because it's "snappy" and has the small toolwindow caption bar.
      How would you use it? You can't use it to communicate back to Ruby... 😞
      I've been playing with the idea of using Win32API to change the window style of the webdialogs. But I'm not sure if I can manage it without getting a flicker of the original window frame first...
        I have already written an 'Instructor' set of index.html/css/gif files etc for my new FreeRotate4.1 [not yet released] BUT it simply doesn't work... no matter what I do πŸ˜’
        At the moment it only works if you open the ../FreeRotate/index.html file in your web-browser...
        The Instructor never recognizes the tool as being active/current...
        I was thinking that perhaps you need to add a global_variable - setting it in the activate() and resume() methods, e.g.
        $instructorContentDirectory = self.getInstructorContentDirectory()
        BUT what that global_variable might be is a mystery... πŸ˜•
        I there a way to puts a list of global_variables ?
        If you start FreeRotate whilst in Line tool the Instructor sticks on Line, then if you Orbit it changes to Orbit, until you exit and pick another tool ???
        I've tried tool_id/pop/push et al with no positive results.
        It is as if my tool isn't registering as the active/current tool at all...
          Anyone contacted Google yet?
            Not me...
            TT - it's your turn... πŸ˜‰
              I think they still have a backlog on all my issues πŸ˜’ - but I can nag them about this one as well.
              • B
                bentleykfrog
                seems like the response is relative to the help directory on pc 😲
                writing the following brings up the eraser tool
                def getInstructorContentDirectory
                  return "\\21019\\"
                so looks like relative paths it is
                • B
                  bentleykfrog
                  hmmmm the following works well on pc too
                    return "../../../../Tools/etc/instructor/"
                  • Chris FullmerC
                    Woohoo! That totally does it. that works in 7.1 also, I did not test anything earlier than that. Here is my code that uses it and points to a directory inside the plugins folder:
                    ` class Clf_instructor
                    return "..\..\..\..\Plugins\doc\"
                    Sketchup.active_model.select_tool Clf_instructor.new`
                    (that is just a snippet I was running from the webconsole, not actually part of a full file).
                    Thanks for coming back and posting that,
                      The instructor works??? πŸ˜„
                      Nice find!
                        This'll be useful for Bezier Surface. πŸ˜„
                        • Dan RathbunD
                          Dan Rathbun
                          Another example of how the API docs (and a poorly written example,) have thrown us all off course for months!
                          I'm not here much anymore.
                            It does smell like a bug though. It doesn't sound right that they intended people to add custom Instructor content to the SU Instructor content folder.
                            • B
                              bentleykfrog
                              Its unusual that they document absolute paths but only go with relative paths, not that relative paths are bad by any means.
                                It's awkward though. I run my plugins I develop from custom locations because I use Mercurial for revision control. So providing a path to a custom location from the hard coded instructor folder isn't ideal. (does it even work across drive letters?)
                                And because some OSX users put their plugins in the user folder instead of the default, one can never rely to plugins to be at a fixed relative path.
                                • K
                                  kirill2008
                                  Does anyone know how to find out how many slashes and dots are needed at certain end user comp ("..\..\..\..\"). I mean if someone has installed sketchup in a custom subdirectory it is necessary to add/remove one of "..\" I guess.
                                    I have use this successfully to get my FreeRotate Instructor to work
                                    <span class="syntaxdefault">def&nbsp;getInstructorContentDirectory</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">=</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">expand_path</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">File</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">dirname</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">__FILE__</span><span class="syntaxkeyword">),</span><span class="syntaxstring">"FreeRotate"</span><span class="syntaxkeyword">)).</span><span class="syntaxdefault">split</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'/'</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">0.upto</span><span class="syntaxkeyword">(</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">length</span><span class="syntaxkeyword">-</span><span class="syntaxdefault">3</span><span class="syntaxkeyword">){|</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">|&nbsp;</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">[</span><span class="syntaxdefault">i</span><span class="syntaxkeyword">]=</span><span class="syntaxstring">'..'&nbsp;</span><span class="syntaxkeyword">}<br />&nbsp;&nbsp;&nbsp;if&nbsp;[</span><span class="syntaxdefault">PLATFORM</span><span class="syntaxkeyword">].</span><span class="syntaxdefault">grep</span><span class="syntaxkeyword">(/</span><span class="syntaxdefault">mswin</span><span class="syntaxkeyword">/)==[</span><span class="syntaxdefault">PLATFORM</span><span class="syntaxkeyword">]&nbsp;</span><span class="syntaxcomment">###&nbsp;PC<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'/'</span><span class="syntaxkeyword">)+</span><span class="syntaxstring">'/'<br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxstring">'/'</span><span class="syntaxkeyword">+</span><span class="syntaxdefault">path</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">join</span><span class="syntaxkeyword">(</span><span class="syntaxstring">'/'</span><span class="syntaxkeyword">)+</span><span class="syntaxstring">'/'<br />&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">end</span>
                                    It should work cross platform?
                                      My method 2 posts before this uses the absolute path of the calling script to construct a relative path to the important folders ?
                                      How do we allow for MAC users with their plugins 'in the wrong place' OR even my uni students who have to install their PC 3rd party scripts in their persona H:/Sketchup_Plugins/ folder, with a script added by their IT guys in the main Plugins to add that path to their $LOAD_PATH array... Would these still work with my idea ??
                                        Can we get the path of the resource folder?
                                        If so, then we could add ../ back references until we're back at the root, then apply the absolute path.
                                        Though, how does one deal with different drive letters under Windows?
                                          Ah - didn't see bentleykfrog's reply.
                                            >   plugin_folder = Sketchup.find_support_file test_file.html, "Tools/My Plugin/"
                                            >   plugin_folder = plugin_folder.split("test_file.html")
                                            >   plugin_folder_array = plugin_folder[0].split("/")
                                            >   if(plugin_folder_array[1] == "Library")
                                            >     #so the plugin/tool is stored in the main library
                                            >     return "../../../../Tools/My Plugin/Instructor/"
                                            >   elseif (plugin_folder_array[1] == "Program Files" || plugin_folder_array[1] == "Program Files (x86)")
                                            >     #the operating system is PC, so only 1 location for tools/plugins
                                            >     #there's probably a better way to do this
                                            >   else
                                            >     #not sure about this, especially since it could be traversing drives
                                            >     return "../../../../../../../../../"+plugin_folder+"Instructor/"
                                            >   end
                                            > end
                                            This is not reliable way to find the location of where your plugin is installed. This is what breaks under OSX when users place them in incorrect locations - and it will also throw errors is people install plugins to custom locations, like TIG and I do.
                                            To get the path of your plugin:
                                            plugin_path = File.dirname( __FILE__ )
                                            To get SU Plugins path:
                                            su_plugin_folder = Sketchup.find_support_file( 'Plugins' )
                                            We can get the Resource folder by using:
                                            plugin_folder = Sketchup.find_support_file( 'Resources' )
                                            But then there's a folder named after the current locale...
                                            • 2 / 5
