    [Tutorial > Modeling] Helical Dome
    21 Posts 16 Posters 13.4k Views 16 Watching
    • N Offline
      nlx
      Can someone tell me how to make an helicoidal stairs ?
        And if you want make in the same time Size, Rotate, Movement, take a look to GROW by Tig
        http://www.pushpullbar.com/forums/attachment.php?attachmentid=45449&stc=1&d=1223644800
        http://www.pushpullbar.com/forums/attachment.php?attachmentid=51795&stc=1&d=1239204608
          Here's a helical [spiral] stair step-by-step example using 'Grow'. [Sorry for the terrible pun on 'step' !]
          However, you can do it all by hand - if you have the patience. First make a component tread, rotate+copy it around the required angle/times [15degrees x 15nr], then select all treads except the original [tread1] and move them up by the riser height [in the example it's 170mm], then de-select tread2 and move the rest up by the next riser, de-select tread3 and move the rest up etc etc, until they are all at the desired heights. All 'Grow' does [in this example] is copy/rotate/move-in-Z - all in one-step which will save you time...
          GrowHelicalSteps.skp
          • N Offline
            nlx
            I find this method incridbly usefull but i will check your plugin too…
            Error 404 (Not Found)!!1
            (sketchup.google.com)
              August
              That 3D Warehouse file is from an Official Google SketchUp Blog entry from July 3, 2009, at http://sketchupdate.blogspot.com/2008/07/building-spiral-stairs.html
              Nearly all of the comments on that Blog item are spam.
              Does anyone know how, who, or where to report such spam and get it cleaned up? I ran the Chinese post through babelfish and it's clearly advertising adult content, on the blog site since November.
              “An idea, like a ghost, must be spoken to a little before it will explain itself.”
              [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                You can try to report it in the Beta forum (I have done it a couple of times). Those blogs should be maintained much more regularly and better.
                  August
                  Ah, the Beta Forum! Good idea. Not exactly public access though.
                  On the Blog pages next to all the spam is the note "We're interested in your comments" that turns out to be a link to the main Google Group. I figured it would not get any more attention there than on the Blog page itself, so why bother.
                  Thanks,
                  August
                    tigerobj
                    good thank
                      duc24101986
                      cool man
                        ckodok
                        Love it..
                        • 2 / 2
