    Making interactive 360 degrees videos
    extensions
    13 Posts 6 Posters 5.2k Views 6 Watching
      That's pretty cool actually. There are panoramic images that can be exported from SU (or some compatible render engines) but I have never seen a video (with moving things in these panoramas).
      Indeed it would be neat too!
      • Chris FullmerC Offline
        Well, exporting the needed images for thet type of video is quite do-able. I've wanted to make aplugin for that after I saw a little handheld camera that shoots in that format using a reflective ball attachment. But it is a matter of having the software to stitch together the 4 (or more?) video streams and putting them together into the actual movie.
          JAP
          I found this tutorial to make interactive panoramic video's with Pano2VR, which I aready have. But now I have to find a way to automate the CubicPano out-plugin, to make pictures for each frame. Does anybody know if there's a way to do this?
            Yeah, we can make that easy enough. What exactly so you need? Cubic pano out writes out 6 images, correct? You would just need it to write out 6 images for every frame of the sketchup animation, right?
              JAP
              Yeah, I think so. If I understand the tutorial correctly I have to make a 360 pic for every frame, reframe them to the video-format, convert them to video and then reframe the video to a interactive video-swf-file. The only thing is I don't have QT pro, as they use in the tutorial. So I have to find similar (freeware) software to convert the picture sequence to a video. I assume that won't be a problem.
              It would be a cool experiment!
                Virtual Dub will convert sequenced images to video.
                • mitcorbM Offline
                  mitcorb
                  Go put on some pants.
                    Aaaaaahhhhh!
                    http://1.bp.blogspot.com/_kng9nNTclfs/Srt6FUjC2gI/AAAAAAAAA0w/l7tuIh9mftQ/s400/Y-front+ad.jpg
                      Cubic pano out plugin will create an image (and optionally a scene) for each 6 sides of a cube you are "inside". All you have to do is to stitch these images together in an external application (a lot easier than how you described). What platform are you on? (It would be worth adding your OS and SU version to your profile). I do not have QT Pro either but could make a panorama in about 5-10 minutes (depending on export size).
                        JAP
                        Hi Gaieus, it ain't about making a panorama, it's about making a sequence of panoramic pictures. In other words it will be an interactive panoramic video. See the example in my first post (and your reaction).
                          A damn, sorry. I even posted after your first post. Really sorry about that.
                          • VinceALPV Offline
                            VinceALP
                            Hi JAP,
                            I found this topic 4 years after you opened it. Did you find a way to make these 360 degrees videos in your sketchup model? Is there now some rendering programs able to do that? My purpose is to use this video with a VR headseat device like cardboard or oculus.
