    [Plugin] Superglue
    81 Posts 18 Posters 49.2k Views 18 Watching
      arjunmax09
      About the glue πŸ’š
      http://bruxelles.blogs.liberation.fr/coulisses/images/2008/12/10/haddock_2.jpg
      LOL!!! πŸ˜† πŸ˜† πŸ˜† ultimate man..TINTIN IS ONE OF MY FAVOURITE CARTOON SERIES..used to watch it everyday on cartoon network when i was in class VI πŸ˜†
      when you fail at something....you haven't really failed...you've found one way the thing will not work out
        I have find a use of Super Glue πŸ˜„
        and at last understood the use πŸ’š
        • FletchF Offline
          Fletch
          @gaieus said:
          @thomthom said:
          HAve you a little animation of what must the glue's pot must do?
          A video of the plugin in use? Yes I'll make one once I make v1.1.0.
          Here you go sir (especially, with the annotations it is pretty fast so pause it when needed):
          OH! Thanks so much Gaius, I was very confused what the point of this plugin was... so now, when I copy lights on the ceiling and they don't cut the opening in the face, the "Superglue" will "fix" it so that they DO cut the opening... BRILLIANT! β˜€
          Thanks for sharing, ThomThom!
          Fletch
            Provided that the axes are correct for the component you try to glue on - if the axis isn't aligned to match the face you try to glue on it won't do anything.
              No more need glue for the plug Component Punch!!!
              Tig found just add a # at the line 186 and all works fine! πŸ‘
              My bottle of glue will be full at the end of the week πŸ’š
              Sorry Thomthom πŸ˜†
              Edit Ah damned , this modify works only on the same face!
              My bottle of glue will be empty at the end of the week πŸ’š
                Edit Curious this morning all works fine! 😲
                http://forums.sketchucation.com/download/file.php?id=54488
                • free agentF Offline
                  free agent
                  hey thom thom just tried this ruby and works great. thanx alot πŸ‘
                    Sean! πŸŽ‰
                    Long time no see. How are you?
                    What have you been up to? Are you completely Max person now? Got some new work to show off?
                      free agent
                      Im good, you? and nope, i speak max and sketchup πŸ˜„ sketchups just too easy to completely throw out of ones workflow.
                      check out the company blog http://www.constructmedia.co.uk/news πŸ˜„ will post some new stuff soon
                      • E Offline
                        ellen_leung
                        i dont understand how to use it, can anyone help explain to me?
                          Hi Ellen,
                          Here is a short video with captions:
                          YouTube - Superglue Plugin for SketchUp by ThomThom
                          [flash=480,385:22ve9z34]http://www.youtube.com/v/VS8-tjYTPXM?fs=1&hl=hu_HU[/flash:22ve9z34]
                          • dereiD Offline
                            derei
                            It seems to not work for me 😞
                            I made a component that makes a hole in a face, when I take the component from Components window, it cuts hole, if I copy it from model ( + Ctrl), it doesn't cut hole. I used Superglue on it, it doesn't cut hole. Am I misusing the plugin? Why that components don't cut hole when I copy them?
                              Can you post sample model?
                              • dereiD Offline
                                derei
                                can't explain myself. I saved the model as new file, it worked there. In the original one doesn't want. I copied the model in a new sketchup window, it doesn't work.
                                It looks like is a sketchup glitch, rather than model-related.
                                  Are you trying to clue the component onto a face directly, or is the face wrapped in a group/component?
                                    When you place a component from the Component-Browser it is put onto your cursor at that component's origin, this is necessary because the origin [axes] must be put down snapped onto a face so that the instance will be assigned that face which it can then 'glue' and 'cut'.
                                    If you copy an already placed instance using Move+Ctrl you need to pick a point on the face that the instance is glued to [or a corner of the instance that is on that face]; then when you pick a new face the component will again find a face to glue/cut. BUT if you pick a point that's off the original's glued face then you won't be able to snap the copy onto another face because it'll always be placed non-planar to a face.
                                    Similarly, if your cutting component has geometry [like a frame/surround or a projecting-sill] that projects in front of the plane of the wall face [and therefore the cut hole] when you use Edit>Copy and then Edit>Paste the cursor that's locked on to the copy is placed NOT always at the copy's 'origin' BUT sometimes at its bounding-box minimum extents, which isn't then going to be the component's 'origin' [especially if the source instance is itself not glued to a face] - so when you snap it onto a face it will not find any face that is coincident with its origin, so there's no gluing and therefore no cut. I suspect that SuperGlue - like other '[re]gluing' tools - looks for a face below the instance's origin and if it can't then find one then there's no gluing and therefore no cutting. A component that's located with its origin a few mm away a face is just as 'unconnected' to that face as if it were placed meters away in empty space.
                                    Conversely, if you have a 'flush' cutting component with no projections in front of the wall face it will Copy/Paste quite satisfactorily, as in this case the cursor will be in the same plane as the component's origin [even if it's perhaps not on the origin itself] and so subsequent snapping of it onto a face will this time find that face coincident with the origin, and which it can then use to glue/cut...
                                    Hence you can get seemingly odd behavior across different types of gluing/cutting components when they are copied, IF you fail to appreciate what is happening with the object's geometry and the cursor...
                                    To see it in action try making a completely flush cutting component and also another version with very large projecting sill [500mm!], use the Component-Browser to place instances of both into a wall and then watch where the cursor is located during subsequent copy/paste operations and the success/failure to glue/cut for the copies, and copies of copies, or copies of non-glued instances etc πŸ€“
                                    • dereiD Offline
                                      derei
                                      My last thought is that in original model was some small deviation from "coplanar" ... because as i said before, I wrapped everything in a component, I saved as new file, then opened and it cut hole by copying and by placing from Component Browser.
                                      In original model it did not cut hole by copying, just by placing new component from Component Browser. When I copied I was on face with the cursor. I tested that by exploding the component and it merged with the face.
                                        If the component has non-coplanar parts you might get the cursor no longer being in the face when the copy is snapped.
                                        Can you save_as the component and post it so we can have a better idea of what's going on... πŸ˜•
                                        • brewskyB Offline
                                          brewsky
                                          Great little plugin! πŸ˜„
                                          Found it thanks to the new Extention Warehouse, should have seen this years ago!
                                          It would be great if you could add a "glue" option to the context menu(below the standard "unglue" option).
                                          Cheers!
                                          Jan
                                          Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
                                            Good idea!
                                            • 4 / 5
