Trim command
High Guys
Just started with Sketchup, been using AutoCad for a while.
Can anybody tell me if there is a Trim command for tidying up
a bit.
Cheers Dodge
Hi Dodge,
What would you "trim" with this plugin?
There are a bunch of really useful clean-up plugins like ThomThom's (well) "Cleanup".
(It needs an additional library, read the instructions carefully) -
@dodge said:
High Guys
a bit.
Cheers Dodge
Trim is build into the SketchUP -
http://www.screencast.com/users/dedmin/folders/Jing/media/b54c8102-aabb-4909-8bca-81307edf8863 -
My 2Dtools contains a Fillet/Chamfer tool, with the radius set to 0 it trims/extends the two selected intersecting edges rather than fillet/chamfer them... In fact using AutoCAD's Fillet tool with a 0 radius is a way of doing the same thing.
2Dtools also has 'Adjust' which lets you select sets of edges to trim/extend to and then sets of edges to 'adjust', you can pick individually or use a 'wiping action' to do multiples...
