    Advice on taking this one step further.
    30 Posts 8 Posters 5.9k Views 8 Watching
    • daleD Offline
      dale
      Although Kerkythea, and Thea have the same developer in common (Giannis), they are actually totally different engines. Kerkythea is also free, while Thea is not, although it is available still for the beta price until I believe the 21 of this month, (which is an incredible deal for this software).
      • pietervP Offline
        pieterv
        And which one of those would be the best/ most intuitive? Kerky, Thea or Maxwell?
        This is my website:
        Citypixels - 3d Visualisatie Architectuur
        • soloS Offline
          I'm gonna say Thea and Maxwell are about the same on learning curve, Kerky is more complicated, Thea is faster at rendering unbiased and also has biased render options.
          Then price, Thea is 20% the price of Maxwell.
          • daleD Offline
            dale
            I have no experience with Maxwell. But I agree with Pete on Thea. Kerkythea is great, but Thea is awesome.
            • pietervP Offline
              pieterv
              Ok, thanks. Would it make a difference for those renderers if your computer is running a 64-bit version of Windows and has more then 4GB of RAM?
              This is my website:
                AndriyG81
                yep, most render engines now days have 64 bit versions, and it does make a difference.
                http://andriyg.com
                • brodieB Offline
                  brodie
                  I've used Kerky for a short time and have been using Maxwell for a couple years now. From my experience the learning curve was pretty similar. In general unbiased engines tend to have an easier learning curve than biased renderers. I really like Maxwell, but I have nothing bad to say about Kerky and Thea seems to be great as well.
                  -Brodie
                    If you are planning to render extremely large images, I would suggest to go 64 bit and invest into some more RAM (RAM is pretty cheap actually).
                    As far as I remember, Kerky does not have a 64 bit version (only as an internal Beta) although can handle billions of polygons but Thea does. And Thea can do region rendering (i.e. you can split your final image into smaller portions and finally put those together) which means that the size will only depend on your patience.
                    Also the SU-to-Thea exporter plugin will soon (before the February 21 release date) be able to do object export (i.e. export based not only material but groups/components) so you can build your models at any complexity level (even in separate files) in SU and then merge the whole thing in Thea.
                    I do not know Maxwell (nor many of the other dozens of engines) so cannot advise on that (those).
                    • daleD Offline
                      dale
                      There is a discussion on new features coming up in Thea over on the Thea forum. It looks like a future upgrade will incorporate Motiva Colimo. An application that allows for the alteration of colors, textures and lighting in post pro from a single scene using raytraced reflections, refractions, so not just graphical like photoshop. This also sounds like it would give a backward compatabilty with SketchUp
                      http://www.motivacg.com/colimo_en.php
                      This sounds amazing, and makes Thea even more inviting.
                      • N Offline
                        notareal
                        @pieterv said:
                        Artlantis is definitly worth a try then. I don't understand very well why you guys make the difference between Kerky en Thea. I thought it was one program "Kerkythea". Isn't it?
                        Kerkythea is a free render. Thea Render is a commercial renderer from the same developer. They have different engines, material systems, UI... basically only what's similar is that they share same philosophical approach - biased and unbiased engine in one studio. Thea Render can import Kerkythea scenes, not other way around.
                        Anyhow, in this case, Thea Render will be much more useful, it does have a 64-Bit studio and region rendering (these are not available it kerkythea), so only limiting factor is available RAM. And even RAM is not a great factor, as you always can render scene in parts using region render.
                        • pietervP Offline
                          pieterv
                          Hey Guys,
                          Thanks a lot for the replies. I'm going to give them a try but I'll probably go for Thea in the end. Region rendering sounds very promising. Also, the Motiva Colima application looks very cool and promising. Something more "What you see is what you get." Could be very handy.
                          This is my website:
                          • N Offline
                            notareal
                            Motiva Colimo is pretty unique. Certainly worth to look on and if you need to jump on "larger" modeller in some point, 3DS Max to Thea Render exporter is made by Motiva. 😉
                            • brodieB Offline
                              brodie
                              Maxwell works pretty much the same way. You can do region renders. Export various parts and merge them in Maxwell Studio, etc. Maxwell has a Right-Click menu that allows you to Export by Selection which seems to be sort of like what I think you're suggesting Thea is getting into.
                              -Brodie
                                Ah, OK, thanks. So I do not know much about Maxwell.
                                • brodieB Offline
                                  brodie
                                  Keep in mind that with Motiva Colimo, that unless it's changed since the last time I looked at it, it requires more renders to be done, which if you're using an unbiased renderer can be prohibitive.
                                  You have to know up front which objects you may want to change later on. Then what it does is renders out your normal scene as well as a separate pass for each object you select where that object is a black diffuse material. So if you decide you want to be able to change a light and 2 objects, you'll end up having to do 4 renders all. In my experience, it's hard to justify that time when you can typically get very similar results via photoshop in a small fraction of the time. (It's a cool program and may have it's uses, particularly for biased renderers or in special cases where clients are deciding colors, I just doubt its applicability for general use with unbiased renderers)
                                  -Brodie
                                  • V Offline
                                    Victor.Feliz
                                    -Brodie
                                    This is the main change, you only need to render once if you use Thea Render, the limit of changeable objects is fixed by the amount of memory on your GPU but it has almost no time penalty over a regular render.
                                    Anyway there will be released a working demo at the same time as the comercial version.
                                    Regards, Víctor.
                                    • brodieB Offline
                                      brodie
                                      Interesting. Does it only work that way with Thea? How does it do that with only 1 render?
                                      -Brodie
                                      • soloS Offline
                                        -Brodie
                                        Colimo has been integrated into Thea as a studio plugin, so when you set up your render you select (check box) the materials you want changeable then render and after render you save as a colimo file and it opens up another window (Colimo) and you can change colors, textures, UV's etc and save all changes as needed.
                                        • brodieB Offline
                                          brodie
                                          Hrm, very cool. Does it add render time? Is it running a separate render pass for each object behind the scene as you'd need to do normally?
                                          -Brodie
                                          • soloS Offline
                                            No increased render times.
                                            edit from my tests so far I have not seen any at least, then again I'd have to render out unbiased first then render again to know, so it's hard to guage.
