    Default tape tool behaviour
    7 Posts 5 Posters 575 Views 5 Watching
      rabbit
      Does anyone know how to make the (SU 8)tape-measure tool start WITHOUT the + feature added?
      I can turn it off with ctrl, but why is it enabled by default? - drives me nuts!
      thanks
      rabbit
      • KrisidiousK
        Krisidious
        no... all three methods (T shortcut, Drop Down Menu and Toolbar) result in the +tape measure first.
        By: Kristoff Rand
          It is enabled by default because It was determined by a poll a few years ago that most people use the tool primarily to place construction geometry. I'm one of those folks who does. And usually, when I just want to measure something, I don't bother hit Ctrl to turn off the +. I just don't click for the second point. After I've read the dimension, I switch to another tool which I would probably do anyway.
            rabbit
            hmm...must have missed that poll!
            Thats all very well, but I find that if I don't turn off the construction line option, I usually end up with a couple around anyway by mistake..
            Well, whatever, I guess its set in stone now.
            cheers
            rabbit
              You can set up a keyboard shortcut for Edit>Delete Guides to make it easy to get rid of them when you don't need them.
              • Chris FullmerC
                I was one that voted to do it the other way....but we were the minority. Though by Google's logic, not having the + enabled by default would be more in line with other tools that use the same logic, therefore it should not have ever gone to a vote, they should have implemented it the way the other tools do it for consistency...
                • GaieusG
                  Well, when yu are measuring (without wanting to add construction geometry), you can just hover over with the tape measure tool (without clicking) and get the measurement. I think (if I remember correctly) this was the reasoning behind making the add function the default if you also click. So if you do not want to guide point, just do not click.
