    SDS2 doodles
    40 Posts 14 Posters 5.0k Views 14 Watching
      Yes that is a perversion 😄
      But can be very useful for single slime design objects 😎
      • michaliszissiouM Offline
        michaliszissiou
        @pilou
        Maybe more than this, the most important is that Artisan opens the door to SU users to learn what topology means, maybe its time for google to start thinking about the limits of SU.
          Yes : limits are numbers of polygones 😉
          Just discover this that show a real mix between organic and mechanical forms by a ZBrush Master Scott Spencer
          (15 free videos) + file included ☀
          • daleD Offline
            dale
            @honoluludesktop said:
            Hmmmm........Not enough to convince me. Any SDS begins with a cubic volume then results in a model. This is OK for most, but the SDS would have to look into Michelangelo's mind to see his vision. Or, Michelangelo would have to have the ability to form the cubic volume that would result in his vision.
            No need to debate this situation, genius requires a different kind of tool. At least when it comes to carving marble. Most SDSs would be OK for me.
            Honolulu
            I think in essence Michelangelo did start with a cubic volume, it was a block of marble. And although we would have had to have a lot more knowledge about him than we do, I wonder when he walked up to the volume that contained "David" if he actually envisioned it, or if the material, and it's limitations guided him to arrive at the final work.
            I'm not so sure that a similar subtractive method could not be applied to this new tool, or if in actuality that is what we are doing in a pared down manner. Blocking out the desired form, and working with finer tools to arrive at the end result, all the while working with the inherent limitations (of the medium)
            I think Michelangelo also had another tool on his side, even aside from his genius, and one that the 21st Century is reluctant to give us. Time
            Cheers
              michaliszissiou
              honoluludesktop, dale, chippwalters, solo, liam887, stinkie, I hope I didn't forget anyone, thanks for your comments on my thread. The good and the bad ones. 🤣
              @honoluludesktop, You mentioned michelangelo, you haven't convince me either if you understand what precision means for an artist. See this Dürer's drawings here.
              I posted so many decimated versions of digital sculpts on this forum, please, precision may have a quite different meaning for me. Especially when I try to have some fun.
              • daleD Offline
                dale
                michalis
                In my above ramblings I forgot to mention how inspirational your work has been. I can't wait to see how far you push the Artisan boundary.
                  michaliszissiou
                  @dale
                  This Dürer's way is what we have to follow before going for subdivisions and more sculpting. Construction of faces, the armature of digital sculpting.
                  My problem here is SU, Please, give me a tool to disable snapping. Move parallel to camera view, move respects symmetry, this is what we need for sculpting. SU became useless for me just because of this!
                  Issues like the above is what I would like to discuss here, not what artisan does because what it really does (IMO) is to indicate the limits of SU.
                  • daleD Offline
                    dale
                    michalis
                    Have the Ruby Gurus had a shot at disabling snapping? Or does the API not allow programmers to change core processes. (probably a dumb question from a non-programmer)
                      michaliszissiou
                      Maybe so, we must have a key for enabling disabling snapping. It can't work otherwise.
                      • honoluludesktopH Offline
                        honoluludesktop
                        Wow, Guess I must have offended all the fine artist judging by the responses to my post. Sorry fellow geniuses.>_<
                        • chippwaltersC Offline
                          chippwalters
                          I think what you mean to say is "I can't make it work for projects I want to complete, otherwise." I have no problem making Artisan and SketchUp do what I need it to do.
                          Currently working with Cross-Reality technologies
                            michaliszissiou
                            I mean that I have a problem related with SU snapping methods. I always had. In fact when sculpting I don't need snapping at all.
                              chippwalters
                              Agreed.
                              • E Offline
                                Ecuadorian
                                I keep reading the thread's title as "SDS2 noodles". Yummy...
                                -Miguel Lescano
                                • N Offline
                                  nomeradona
                                  i am salivating with this artisan.
                                    andretbms
                                    Awesome work! I never figured out how to use SDS1 properly, maybe I'll give it another shot when this second comes out hehe
                                    Any ideas of how much will the plugin cost?
                                    André Thomé Barbosa
                                    Architecture and Product Ilustrator.
                                    Be sure to check my channel, plenty of SketchUp modelling videos and some tutorials.
                                    http://www.youtube.com/andretbms
                                      d12dozr
                                      http://forums.sketchucation.com/viewtopic.php?f=323&t=34868
                                      http://goo.gl/f7ooYh
                                      • 2 / 2
