    Compute Rotation and Scale from Transform Object
    26 Posts 9 Posters 6.2k Views 9 Watching
      dburdick
      Hi Tig,
      I tried your transformation extension routines and everything works fine if the component is scaled uniformly. However, when you scale the component non-uniformly, (e.g. scale out in only the X direction), the rotation values return incoreectly and/or the program bombs because the acos function you use is out of range. Is there someway to appy a scaling to your extension rotation values beofre computing the acos.
        MartinRinehart
        @dburdick said:
        Is there a simple Sketchup Ruby method which returns the x,y and z rotation in degrees ...
        What's the application for this? (Scaling modifies the xform's [0,0], [1,1], [2,2] entries. Rotations modify all entries from [0,0] through [2,2]. It's not immediately obvious that you can find original operations in any non-trivial case.)
          dburdick
          Hi Martin,
          Thanks for jumping in on this. I read your wonderful web-page description of the 4 x 4 matrix - truly excellent - and serves as the inspiration behind what I'm trying to do.
          Basically, I need to get the exact rotation and scaling values of any component in world space in order to export an instance of that component. I already have figured out how to create the transformation by multiplying the stacked transformations of the component hierarchy, but I need to express the output rotational transformation in degrees - eg rotX, rotY, rotZ - and it needs to work even if the user decides to scale the component non-uniformly (e.g. skewing, shearing). In Sketchup, a user could for example scale a door component in only the Y direction. The current transform extension lib from TIG does not handle this correctly as the lib assumes all scaling is done uniformly to the component. So I need to understand how to adjust TIG's ruby code to accomodate this. Here's his code for example on returing the rotX value from a transform object:
          def rotX
              #(Math.atan2(self.to_a[9],self.to_a[10]))
              Math.acos(self.to_a[5]).radians
          This works fine when the component is uniformly scaled, but fails when for example the x dimension is scaled to a value different than Y and Z. This is because the array value[5] contains a number greater than 1.0 when non-uniform scaling is introduced. So it will return an error and bomb. I;m not sure what the commented out code is above the equation.
            I think the bits of code that're commented out [starts with a #] are perhaps the right code ?
            Swap the two around - this was a work-in-progress that stalled...
            Try
            def rotX
              ###Math.acos(self.to_a[5]).radians
            Let me know how it works...
              dburdick
              Try
              > def rotX
              > end
              Hi TIG,
              Yes, when switching to the commented code versus the original lines it works better (doesn't bomb) - but it give incorrect results when two or more rotations are involved - e.g. roation around the X followed by rotation around Z. I'm going to try to see if I can return better results by working with 2 vectors intead of the whole matrix.
                dburdick
                I think I found a more foolproof way of doing this by using transform object axis vectors. It turns out, that the 4 x 4 matrix needs to be normalized first (e.g. sans any non-uniform scaling) before computing the rotation angles. So the way to do this is to use the already normalized axis vectors (x-axis, yaxis, etc.). So here's the revised code which returns the rotation angles in degrees:
                  def rotX
                     Math.atan2(self.yaxis.z,self.yaxis.y).radians
                  def rotY
                	Math.atan2(self.xaxis.z,self.xaxis.x).radians
                  def rotZ
                	Math.atan2(self.xaxis.y,self.xaxis.x).radians
                Update: Sorry I jumped the gun here a bit - this isn't correct. The scaling issues now work but the multi rotation problem is still here
                  dburdick
                  Okay, I got it working to return nice clean Euler angles from a transform object. Here's the code (note - it returns right-handed angles in degrees):
                  def euler
                  	m = self.xaxis.to_a + self.yaxis.to_a + self.zaxis.to_a
                  	if m[6] != 1 and m[6]!= 1
                  		ry = -Math.asin(m[6])
                  		rx = Math.atan2(m[7]/Math.cos(ry),m[8]/Math.cos(ry))
                  		rz = Math.atan2(m[3]/Math.cos(ry),m[0]/Math.cos(ry))
                  	else
                  		rz = 0
                  		phi = Math.atan2(m[1],m[2])
                  		if m[6] == -1
                  			ry = Math;;PI/2
                  			rx = rz + phi
                  		else
                  			ry = -Math;;PI/2
                  			rx = -rz + phi
                  	return -rx.radians, -ry.radians, -rz.radians
                    Thanks for the input...
                    Here's my revised code using you ideas - it's still in radians and I have tried not to clash with your method naming etc - it now finds x/y/z rotations and [x,y,z] rotation as an array and has extra methods to set rotations from a 3 item array, referring either to the model axes or object's axes...
                    ### transformation.extensions.rb (c) TIG 2009
                    ### From original ideas by TBD and others ? ### TIG 20091010
                    ### The euler rotation ideas from Dave Burdick 20100324
                    ### It extends the methods for Geom;;Transformation...
                    ### The built-in method "object.transformation.origin" return a point3d
                    ###   that is the object's origin/insertion; the new method
                    ###   object.transformation.getX etc returns the X location of the
                    ###   object [or Y or Z].
                    ### The setX(x) resets the X value of the object [or Y or Z]; it
                    ###   returns a new transformation that can then be used to reset the
                    ###   original transformation; thus;
                    ###   object.transformation=object.transformation.setX(another_object.transformation.getX)
                    ###   - here it makes the object's X = another_object's X ;
                    ###     it also could be given a float, e.g. 12.345 or a 'variable'...
                    ### The object.transformation.scaleX etc returns the scale on that axis.
                    ### The object.transformation.rotX etc returns the rotation on that axis
                    ###   in radians; use ... .rotX.radians to get it in degrees...
                    ### It uses different names to TBD's, e.g. 'rotZ' instead of 'zrot' etc.
                    ### Note the capitalization... this is because some 'compiled scripts'
                    ### use 'rotz' already etc - [and they return the rotation in degrees!]
                    ### object.transformation.rotXYZ
                    ###   returns a 3 item array giving the rotations in x/y/z
                    ### object.transformation.rot_a
                    ###   returns an 11 item array of the transformation's rotation/scaling
                    ###   - it can be used to extract some data more easily or as below...
                    ### object.transformation=object.transformation.rotation_from_rot_a(another_object.transformation.rot_a)
                    ###   this applies another_object's 'rot_a' to change the object.
                    ### object.transformation=object.transformation.rotation_from(another_object.transformation)
                    ###   this applies another_object's rotation/scaling to the object.
                    ###   it returns a new transformation that can then be used to reset the original...
                    ### object.transformation=object.transformation.origin_from(another_object.transformation)
                    ###   this applies another_object's origin/location to the object.
                    ### object.transformation=object.transformation.rotation_from_xyz([xrot,yrot,zrot])
                    ###   this applies a 3 item array of x/y/z rotations about the model's x/y/z-axes,
                    ###   this could also be the array returned by rotXYZ.
                    ### object.transformation=object.transformation.rotation_from_xyz_locally([xrot,yrot,zrot])
                    ###   this applies a 3 item array of x/y/z rotations about the objects's x/y/z-axes,
                    class Geom;;Transformation
                        def euler_angle(xyz=[])
                           else
                              rz = 0
                              if m[6] == -1
                                 ry = Math;;PI/2
                                 rx = rz + phi
                              else
                                 ry = -Math;;PI/2
                                 rx = -rz + phi
                           return -rx if xyz==0
                           return -ry if xyz==1
                           return -rz if xyz==2
                           return [-rx,-ry,-rz] if xyz==[]
                      def getX
                        self.to_a[12]
                      def getY
                        self.to_a[13]
                      def getZ
                        self.to_a[14]
                      def setX(x)
                        if not x.class==Float and not x.class==Integer
                          puts "Transformation;;setX( ) expects a Float or Integer."
                          return nil
                        end#if
                        x=x.to_f
                        t=self.to_a
                        t[12]=x
                        return self.set!(t)
                      def setY(y)
                        if not y.class==Float and not y.class==Integer
                          puts "Transformation;;setY( ) expects a Float or Integer."
                          return nil
                        end#if
                        y=y.to_f
                        t=self.to_a
                        t[13]=y
                        return self.set!(t)
                      def setZ(z)
                        if not z.class==Float and not z.class==Integer
                          puts "Transformation;;setZ( ) expects a Float or Integer."
                          return nil
                        end#if
                        z=z.to_f
                        t=self.to_a
                        t[14]=z
                        return self.set!(t)
                      def scaleX
                        Math.sqrt(self.to_a[0]**2+self.to_a[1]**2+self.to_a[2]**2)
                      def scaleY
                        Math.sqrt(self.to_a[4]**2+self.to_a[5]**2+self.to_a[6]**2)
                      def scaleZ
                        Math.sqrt(self.to_a[8]**2+self.to_a[9]**2+self.to_a[10]**2)
                      def rotX
                         euler_angle(0)
                      def rotY
                        #(Math.arcsin(self.to_a[8]))
                        #Math.acos(self.to_a[0])
                        euler_angle(1)
                      def rotZ
                        #(-Math.atan2(self.to_a[4],self.to_a[0]))
                        #Math.asin(self.to_a[4])
                        euler_angle(2)
                      def rotXYZ
                        euler_angle
                      def rot_a ### rotation matrix 4x3 3 and 7 are nil
                        t=self.to_a
                        r=[]
                        [0,1,2,3,4,5,6,7,8,9,10].each{|i|r[i]=t[i]}
                        r[3]=nil
                        r[7]=nil
                        return r
                      def rotation_from_xyz(xyz)
                        if not xyz.class==Array and not xyz[2] and not xyz[0].class==Float and not xyz[1].class==Float and not xyz[2].class==Float
                          puts "Transformation;;rotation_from_xyz( ) expects a 3 Item Array of Angles [as Floats]."
                          return nil
                        end#if
                        tx=Geom;;Transformation.rotation(self.origin,X_AXIS,xyz[0])
                        ty=Geom;;Transformation.rotation(self.origin,Y_AXIS,xyz[1])
                        tz=Geom;;Transformation.rotation(self.origin,Z_AXIS,xyz[2])
                        t=(tx*ty*tz)
                        return self.set!(t)
                      def rotation_from_xyz_locally(xyz)
                          puts "Transformation;;rotation_from_xyz_locally( ) expects a 3 Item Array of Angles [as Floats]."
                          return nil
                        end#if
                        tx=Geom;;Transformation.rotation(self.origin,self.xaxis,xyz[0])
                        ty=Geom;;Transformation.rotation(self.origin,self.yaxis,xyz[1])
                        tz=Geom;;Transformation.rotation(self.origin,self.zaxis,xyz[2])
                        t=(tx*ty*tz)
                        return self.set!(t)
                      def rotation_from_rot_a(rot_a)
                        if not rot_a.class==Array and not rot_a[10]
                          puts "Transformation;;rotation_from_rot_a( ) expects an 11 Item Array."
                          return nil
                        end#if
                        t=self.to_a
                        [0,1,2,4,5,6,8,9,10].each{|i|t[i]=rot_a[i].to_f}
                        return self.set!(t)
                      def rotation_from(trans)
                        if not trans.class==Geom;;Transformation
                          puts "Transformation;;rotation_from( ) expects a Sketchup;;Transformation."
                          return nil
                        end#if
                        t=self.to_a
                        tt=trans.to_a
                        [0,1,2,4,5,6,8,9,10].each{|i|t[i]=tt[i].to_f}
                        return self.set!(t)
                      def origin_from(trans)
                          puts "Transformation;;origin_from( ) expects a Sketchup;;Transformation."
                          return nil
                        end#if
                        t=self.to_a
                        tt=trans.to_a
                        [12,13,14].each{|i|t[i]=tt[i].to_f}
                        return self.set!(t)
                    end#class
                    EDIT: typo in euler code fixed TIG 20110209
                      MartinRinehart
                      @dburdick said:
                      I read your wonderful web-page description of the 4 x 4 matrix - ...
                      Very kind words, indeed. Many thanks.
                      For those not versed in the Transformation Matrix, my tutorial's Appendix T, introduces it, Appendix MM explains matrix multiplication and Chapter 16 explains how you can live without it (and includes a Matrix class, just in case).
                        Djarlo
                        >     def euler_angle(xyx=[])
                        >        else
                        >           rz = 0
                        >           if m[6] == -1
                        >              ry = Math;;PI/2
                        >              rx = rz + phi
                        >           else
                        >              ry = -Math;;PI/2
                        >              rx = -rz + phi
                        >           end
                        >        end
                        >   end
                        >   def getX
                        >     self.to_a[12]
                        >   end
                        >   def getY
                        >     self.to_a[13]
                        >   end
                        >   def getZ
                        >     self.to_a[14]
                        >   end
                        >   def setX(x)
                        >       return nil
                        >     end#if
                        >     x=x.to_f
                        >     t=self.to_a
                        >     t[12]=x
                        >     return self.set!(t)
                        >   end
                        >   def setY(y)
                        >       return nil
                        >     end#if
                        >     y=y.to_f
                        >     t=self.to_a
                        >     t[13]=y
                        >     return self.set!(t)
                        >   end
                        >   def setZ(z)
                        >       return nil
                        >     end#if
                        >     z=z.to_f
                        >     t=self.to_a
                        >     t[14]=z
                        >     return self.set!(t)
                        >   end
                        >   def scaleX
                        >   end
                        >   def scaleY
                        >   end
                        >   def scaleZ
                        >   end
                        >   def rotX
                        >      euler_angle(0)
                        >   end
                        >   def rotY
                        >     euler_angle(1)
                        >   end
                        >   def rotZ
                        >     euler_angle(2)
                        >   end
                        >   def rotXYZ
                        >     euler_angle
                        >   end
                        >     t=self.to_a
                        >     r=[]
                        >     r[3]=nil
                        >     r[7]=nil
                        >     return r
                        >   end
                        >       return nil
                        >     end#if
                        >     t=(tx*ty*tz)
                        >     return self.set!(t)
                        >   end
                        >       return nil
                        >     end#if
                        >     t=(tx*ty*tz)
                        >     return self.set!(t)
                        >   end
                        >       return nil
                        >     end#if
                        >     t=self.to_a
                        >     return self.set!(t)
                        >   end
                        >       return nil
                        >     end#if
                        >     t=self.to_a
                        >     tt=trans.to_a
                        >     return self.set!(t)
                        >   end
                        >       return nil
                        >     end#if
                        >     t=self.to_a
                        >     tt=trans.to_a
                        >     return self.set!(t)
                        >   end
                        > end#class
                        Hey Tig, thanks for the great code, i might be doing something wrong here but this:
                        	Selection = Sketchup.active_model.selection[0]
                        	Rotation = Selection.transformation.rotXYZ
                        Gives an error,
                        Error; #<NameError; undefined local variable or method `xyz' for #<Geom;;Transformation;0xa747534>>
                        D;/PROGRA~1/Google/GOOGLE~1/Plugins/test.rb;128;in `euler_angle'
                        D;/PROGRA~1/Google/GOOGLE~1/Plugins/test.rb;197;in `rotXYZ'
                        D;/PROGRA~1/Google/GOOGLE~1/Plugins/test.rb;64
                        Any suggestions what could be going wrong?
                          > >        else
                          > >           rz = 0
                          > >           if m[6] == -1
                          > >              ry = Math;;PI/2
                          > >              rx = rz + phi
                          > >           else
                          > >              ry = -Math;;PI/2
                          > >              rx = -rz + phi
                          > >           end
                          > >        end
                          > >   end
                          > >   def getX
                          > >     self.to_a[12]
                          > >   end
                          > >   def getY
                          > >     self.to_a[13]
                          > >   end
                          > >   def getZ
                          > >     self.to_a[14]
                          > >   end
                          > >   def setX(x)
                          > >       return nil
                          > >     end#if
                          > >     x=x.to_f
                          > >     t=self.to_a
                          > >     t[12]=x
                          > >     return self.set!(t)
                          > >   end
                          > >   def setY(y)
                          > >       return nil
                          > >     end#if
                          > >     y=y.to_f
                          > >     t=self.to_a
                          > >     t[13]=y
                          > >     return self.set!(t)
                          > >   end
                          > >   def setZ(z)
                          > >       return nil
                          > >     end#if
                          > >     z=z.to_f
                          > >     t=self.to_a
                          > >     t[14]=z
                          > >     return self.set!(t)
                          > >   end
                          > >   def scaleX
                          > >   end
                          > >   def scaleY
                          > >   end
                          > >   def scaleZ
                          > >   end
                          > >   def rotX
                          > >      euler_angle(0)
                          > >   end
                          > >   def rotY
                          > >     euler_angle(1)
                          > >   end
                          > >   def rotZ
                          > >     euler_angle(2)
                          > >   end
                          > >   def rotXYZ
                          > >     euler_angle
                          > >   end
                          > >     t=self.to_a
                          > >     r=[]
                          > >     r[3]=nil
                          > >     r[7]=nil
                          > >     return r
                          > >   end
                          > >       return nil
                          > >     end#if
                          > >     t=(tx*ty*tz)
                          > >     return self.set!(t)
                          > >   end
                          > >       return nil
                          > >     end#if
                          > >     t=(tx*ty*tz)
                          > >     return self.set!(t)
                          > >   end
                          > >       return nil
                          > >     end#if
                          > >     t=self.to_a
                          > >     return self.set!(t)
                          > >   end
                          > >       return nil
                          > >     end#if
                          > >     t=self.to_a
                          > >     tt=trans.to_a
                          > >     return self.set!(t)
                          > >   end
                          > >       return nil
                          > >     end#if
                          > >     t=self.to_a
                          > >     tt=trans.to_a
                          > >     return self.set!(t)
                          > >   end
                          > > end#class
                          Gives an error,
                          😳 There's a typo in the code that I corrected but never posted !
                          should be
                          also note what Dan said about naming conventions.....
                          Here's a link to the corrected code http://forums.sketchucation.com/viewtopic.php?p=190874#p190874
                            shirazbj
                            I am reading it too. Great job.Thanks.
                              Djarlo
                              Thanks to both πŸ˜„
                              heh must have missed that type too time and again i looked it all over to see whats wrong πŸ˜›
                                tomasz
                                Thank you Martin for those wonderful tutorials. I wasn't aware that transformation.to_a[15] is a divisor for a translation! As far as I am aware SketchUp itself keeps it equal to 1, but some plugins modify Wt (i.e. Component Stringer).
                                Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                  Ruts
                                  I have a question about the euler_angle method, especially about the xyz. I have searched the web and found information about this case, but it didn't result in an answer.
                                  Here's how I read this piece of code:
                                  when you call the method euler_angles you create an empty array under variable xyz as parameter. Then nothing happens with the array for the whole piece of code. At the end the array can be ==0 (contains one element which is equal to zero), ==1, ==2 or still empty. How can it be that the array can contain elements?
                                  • Dan RathbunD Offline
                                    Dan Rathbun
                                    Words in ALLCAPS are reserved for constants.
                                    Words in Titlecase are for Class and Module Identifiers, (which are also constants. Any word the starts with a capital character is a constant.)
                                    Bad:
                                    Selection = Sketchup.active_model.selection[0] Rotation = Selection.transformation.rotXYZ
                                    Good for variables:
                                    selection = Sketchup.active_model.selection[0] rotation = selection.transformation.rotXYZ
                                    πŸ˜‰
                                    I'm not here much anymore.
                                      Dan Rathbun
                                      @ruts said:
                                      ...when you call the method euler_angle you create an empty array under variable xyz as parameter.
                                      The secret is that Ruby does not really "have" variables, even though the books use that name. Ruby has references that point at objects, and a reference can be made to point at any class of object, and then later be re-assigned to point at any other object of any class, at any time.
                                      This is referred to as "weakly typed", but really Ruby references are not type locked at all.
                                      Because it (the argument) is just being used as a switch to tell the method what the coder wants as an output. An empty array object is simply the default, which tells the method the calling code expects an array as a return object.
                                      It cannot. You mis-understand. The method is not testing an array, it is testing a reference to the method argument to see if is pointing at integers 0 or 1 or 2, or still pointing at [] (the default empty array object,) and then returning either the indicated values, or an array of all three.
                                      IF you call the method with no arguments, or like euler_angle([]) you will get an array of 3 values.
                                      IF you call the method thus: euler_angle(0) you will get the x value returned.
                                      IF you call the method thus: euler_angle(1) you will get the y value returned.
                                      IF you call the method thus: euler_angle(2) you will get the z value returned.
                                      The 0, 1 and 2 subscripts come from the SketchUp API's extension of the Array class, where 3 element arrays can act like points and vectors.
                                      Still have not read the book, I see.
                                        Ruts
                                        I did delete the rotX/Y/Z methods, that's why I didn't understand where the variable xyz came from and why it could get value = 0/1/2. I do understand how methods with there variables work. Sorry was confused.
                                        On the other hand, I have been working with the euler_angle method for a while and now that I'm closely getting to a complete script I have noticed this method only partial works (for me?). Does it work for you guys? When I did draw shapes with a given rotation, the method didn't succeed to calculate the right angles for me so I did some research and made some changes. Here's the code I use:
                                        	def self.rotation(trans)
                                        		b = [trans.xaxis.to_a, trans.yaxis.to_a, trans.zaxis.to_a]
                                        		m = b.transpose.flatten!
                                        		if m[6] != 1 and m[6] != -1
                                        		else
                                        			rz = 0
                                        			phipos = Math.atan2(m[1],m[2])
                                        			phineg = Math.atan2(-m[1],-m[2])
                                        			if m[6] == -1
                                        				ry = Math;;PI/2
                                        				rx = rz + phipos
                                        			else
                                        				ry = -Math;;PI/2
                                        				rx = -rz + phineg
                                        	return [rx.radians,ry.radians,rz.radians]
                                        First I found this document (page 5) that explains the calculations the way you do it. But it seems that you miss little pieces of code to make it complete.
                                        When I did calculate the angles it yet didn't calculate the right angles. So I did try some things and found out that the angles that were calculated represent the transpose matrix of the rotation that I need. So I fixed this by transposing the rotation matrix before the calculations.
                                        With these changes this piece of code does calculate the right angles. Did your code work for you?
                                          Dan Rathbun
                                          You realize that this topic thread is like 4 and 1/2 years old ?
                                            Ruts
                                            Yes, I have seen it. That does not mean that people can't come here and look for code that works? That's how I landed here. I was looking for some code that could convert the rotation matrix to euler angles. I found out that this code didn't work for me, so I did correct it and now I share it here just in case people experience the same problem as me. I'm just excited that I finally can contribute a little instead of always asking things!
                                            Nothing wrong with that, right?
